Hi, I am trying to flash my Jetson Xavier Nx Developer Kit with Jetpack 5.1.3 utilizing SDK Manager directly into my Nvme ssd drive. The process finishes succesfully and the Jetson boots normally initially, however, A message with “nvidia-l4t-bootloader post install notification. reboot is required to complete the installation” keeps popping up. As I saw in a different forum, the problem could be fixed by doing sudo apt upgrade, however when I do this, The Jetson does not initalizes, stays in bash and gets really hot.
Is it a problem with how it is flashed? Do I need and extra step with an SD card? Is it not recommendable to use the ssd as the booting option for this board? Thanks in advance
