I’m trying to compile a fairly complex program using pgf90 19.4-0 LLVM on 64 bit linux.
I’ve tracked down a serve compiler bug related to use, only in modules. The smallest example to replicate the problem is below:
file 1: strDict.F90
module utilsMod
implicit none
interface
module subroutine convertToLowerCase(string)
character (len=*), intent(inout) :: string
end subroutine convertToLowerCase
end interface
contains
end module utilsMod
module strDictMod
use utilsMod, only : convertToLowerCase ! <-------- This is the error
implicit none
private
public strDict
type strDict
contains
procedure :: create
end type strDict
contains
subroutine create(d, str)
class(StrDict) :: d
character(len=*) :: str
call convertToLowerCase(str)
end subroutine create
end module strDictMod
file 2: hashTable.F90
module hashTableMod
use strDictMod
implicit none
end module hashTableMod
To Replicate:
pgf90 -c -fPIC strDict.F90
pgf90 -c -fPIC hasTable.F90
gives:
PGF90-F-0000-Internal compiler error. interf:new_symbol, symbol not found 625 (hashTable.F90: 4)
PGF90/x86-64 Linux 19.4-0: compilation aborted
I’ve determined a work-around, the import "use utilsMod, only : convertToLowerCase " can’t be at the top of the module. It can be in the individual routine. Someone most likely coded this incorrectly in the compiler. I’m 99% sure this is standard conforming as other popular fortran compilers do not have any issues.
Thanks,
Gaetan
