HI, guys:
I am working on xavier fpdlink III camera which are 913+960.BTW,i already make the max9286 works very well.Right now, i can catch the mipi signal. but when i use v4l2-ctl to capture the frame, the dmesg print like this
[ 434.621701] ds90ub960 2-003d: num_modes=1
[ 434.636978] [RCE] Configuring VI GoS.
[ 434.636994] [RCE] VM GOS[#0] addr=0xe4900000
[ 434.637004] [RCE] VM GOS[#1] addr=0xe4901000
[ 434.637013] [RCE] VM GOS[#2] addr=0xe4902000
[ 434.637023] [RCE] VM GOS[#3] addr=0xe4903000
[ 434.637032] [RCE] VM GOS[#4] addr=0xe4904000
[ 434.637041] [RCE] VM GOS[#5] addr=0xe4905000
[ 434.637053] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 434.637071] [RCE] VI GOS[#0] set to VM GOS[4] base 0xe4904000
[ 434.669130] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 131072
[ 437.176924] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 437.177087] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 437.177245] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 437.180236] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 437.212955] [RCE] Configuring VI GoS.
[ 437.212970] [RCE] VM GOS[#0] addr=0xe4900000
[ 437.212981] [RCE] VM GOS[#1] addr=0xe4901000
[ 437.212990] [RCE] VM GOS[#2] addr=0xe4902000
[ 437.213001] [RCE] VM GOS[#3] addr=0xe4903000
[ 437.213017] [RCE] VM GOS[#4] addr=0xe4904000
[ 437.213027] [RCE] VM GOS[#5] addr=0xe4905000
[ 437.228390] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 131072
[ 439.736945] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 439.737102] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 439.737288] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 439.737446] tegra194-vi5 15c10000.vi: unexpected response from camera processor
[ 439.737573] video4linux video0: vi capture release failed
[ 439.737667] tegra194-vi5 15c10000.vi: fatal: error recovery failed
and trace print like this
[code]
tracer: nop
entries-in-buffer/entries-written: 482/482 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:0-4 [000] .... 404.384573: rtos_queue_peek_from_isr_failed: tstamp:12832381540 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 404.552560: rtos_queue_peek_from_isr_failed: tstamp:12837381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 404.720557: rtos_queue_peek_from_isr_failed: tstamp:12842381540 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 404.832543: rtos_queue_peek_from_isr_failed: tstamp:12847381540 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 405.000549: rtos_queue_peek_from_isr_failed: tstamp:12852381540 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 405.168538: rtos_queue_peek_from_isr_failed: tstamp:12857381543 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 405.336561: rtos_queue_peek_from_isr_failed: tstamp:12862381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 405.504542: rtos_queue_peek_from_isr_failed: tstamp:12867381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 405.672552: rtos_queue_peek_from_isr_failed: tstamp:12872381539 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 405.840558: rtos_queue_peek_from_isr_failed: tstamp:12877381540 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 405.952553: rtos_queue_peek_from_isr_failed: tstamp:12882381544 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 406.120546: rtos_queue_peek_from_isr_failed: tstamp:12887381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 406.288556: rtos_queue_peek_from_isr_failed: tstamp:12892381539 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 406.456549: rtos_queue_peek_from_isr_failed: tstamp:12897381539 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 406.624558: rtos_queue_peek_from_isr_failed: tstamp:12902381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 406.792561: rtos_queue_peek_from_isr_failed: tstamp:12907381537 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 406.960568: rtos_queue_peek_from_isr_failed: tstamp:12912381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 407.072554: rtos_queue_peek_from_isr_failed: tstamp:12917381537 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 407.240564: rtos_queue_peek_from_isr_failed: tstamp:12922381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 407.408615: rtos_queue_peek_from_isr_failed: tstamp:12927381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 407.576576: rtos_queue_peek_from_isr_failed: tstamp:12932381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 407.744579: rtos_queue_peek_from_isr_failed: tstamp:12937381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 407.912584: rtos_queue_peek_from_isr_failed: tstamp:12942381539 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 408.080564: rtos_queue_peek_from_isr_failed: tstamp:12947381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 408.192584: rtos_queue_peek_from_isr_failed: tstamp:12952381540 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 408.360581: rtos_queue_peek_from_isr_failed: tstamp:12957381539 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 408.528578: rtos_queue_peek_from_isr_failed: tstamp:12962381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 408.696588: rtos_queue_peek_from_isr_failed: tstamp:12967381539 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 408.864581: rtos_queue_peek_from_isr_failed: tstamp:12972381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 409.032602: rtos_queue_peek_from_isr_failed: tstamp:12977381536 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 409.200581: rtos_queue_peek_from_isr_failed: tstamp:12982381539 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 409.312595: rtos_queue_peek_from_isr_failed: tstamp:12986327964 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 434.636894: rtos_queue_send_from_isr_failed: tstamp:13778476003 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 434.636901: rtos_queue_send_from_isr_failed: tstamp:13778478522 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 434.636902: rtos_queue_send_from_isr_failed: tstamp:13778481016 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 434.636904: rtos_queue_send_from_isr_failed: tstamp:13778483470 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 434.636905: rtos_queue_send_from_isr_failed: tstamp:13778485924 queue:0x0bcbc160
kworker/0:0-4 [000] .... 434.636910: rtos_queue_peek_from_isr_failed: tstamp:13778570032 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 434.636913: rtcpu_start: tstamp:13778572287
kworker/0:0-4 [000] .... 434.636915: rtos_queue_send_from_isr_failed: tstamp:13778587917 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 434.636916: rtos_queue_send_from_isr_failed: tstamp:13778588078 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 434.636949: rtos_queue_send_from_isr_failed: tstamp:13778588237 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 434.636951: rtos_queue_send_from_isr_failed: tstamp:13778588398 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 434.636952: rtos_queue_send_from_isr_failed: tstamp:13778588555 queue:0x0bcbc160
kworker/0:0-4 [000] .... 434.636954: rtcpu_string: tstamp:13778589009 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] … 434.636986: rtcpu_string: tstamp:13778589223 id:0x04010000 str:"VM GOS[#0 ] addr=0xe4900000
kworker/0:0-4 [000] … 434.636996: rtcpu_string: tstamp:13778589490 id:0x04010000 str:"VM GOS[#1 ] addr=0xe4901000
kworker/0:0-4 [000] … 434.637006: rtcpu_string: tstamp:13778589789 id:0x04010000 str:"VM GOS[#2 ] addr=0xe4902000
kworker/0:0-4 [000] … 434.637015: rtcpu_string: tstamp:13778590032 id:0x04010000 str:"VM GOS[#3 ] addr=0xe4903000
kworker/0:0-4 [000] … 434.637025: rtcpu_string: tstamp:13778590273 id:0x04010000 str:"VM GOS[#4 ] addr=0xe4904000
kworker/0:0-4 [000] … 434.637035: rtcpu_string: tstamp:13778590516 id:0x04010000 str:"VM GOS[#5 ] addr=0xe4905000
kworker/0:0-4 [000] … 434.637044: rtcpu_string: tstamp:13778605732 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol versi”
kworker/0:0-4 [000] … 434.637046: rtcpu_string: tstamp:13778605861 id:0x04010000 str:"on 2.2
kworker/0:0-4 [000] … 434.637056: rtos_queue_send_from_isr_failed: tstamp:13778631291 queue:0x0bcb41f8
kworker/0:0-4 [000] … 434.637057: rtos_queue_send_from_isr_failed: tstamp:13778631473 queue:0x0bcb8a60
kworker/0:0-4 [000] … 434.637058: rtos_queue_send_from_isr_failed: tstamp:13778631639 queue:0x0bcba5e0
kworker/0:0-4 [000] … 434.637060: rtos_queue_send_from_isr_failed: tstamp:13778631794 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 434.637061: rtos_queue_send_from_isr_failed: tstamp:13778631951 queue:0x0bcbc160
kworker/0:0-4 [000] … 434.637062: rtcpu_string: tstamp:13778632865 id:0x04010000 str:"VI GOS[#0 ] set to VM GOS[4] base 0xe4904000
kworker/0:0-4 [000] … 434.637081: rtcpu_vinotify_error: tstamp:13778709729 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:13778706860 data:0x00000001
kworker/0:0-4 [000] … 434.692882: rtcpu_vinotify_event: tstamp:13779150332 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15714600544 data:0x10000000
kworker/0:0-4 [000] … 434.692889: rtcpu_vinotify_event: tstamp:13779150488 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15714637600 data:0x31000001
kworker/0:0-4 [000] … 434.692891: rtcpu_vinotify_event: tstamp:13779150679 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15714647776 data:0x10000000
kworker/0:0-4 [000] … 434.692892: rtcpu_vinotify_event: tstamp:13779150848 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15714656224 data:0x07020001
kworker/0:0-4 [000] … 434.692927: rtcpu_vinotify_event: tstamp:13779151019 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15714686656 data:0x31000002
kworker/0:0-4 [000] … 434.692929: rtcpu_vinotify_event: tstamp:13779151173 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:13778706860 data:0x00000001
kworker/0:0-4 [000] … 434.692930: rtcpu_vinotify_event: tstamp:13779692684 tag:FS channel:0x00 frame:3 vi_tstamp:13779683596 data:0x00000010
kworker/0:0-4 [000] … 434.692931: rtcpu_vinotify_event: tstamp:13779692837 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:13779683598 data:0x00000000
kworker/0:0-4 [000] … 434.692936: rtos_queue_send_from_isr_failed: tstamp:13779975326 queue:0x0bcb41f8
kworker/0:0-4 [000] … 434.692938: rtos_queue_send_from_isr_failed: tstamp:13779975490 queue:0x0bcb8a60
kworker/0:0-4 [000] … 434.692939: rtos_queue_send_from_isr_failed: tstamp:13779975654 queue:0x0bcba5e0
kworker/0:0-4 [000] … 434.692940: rtos_queue_send_from_isr_failed: tstamp:13779975810 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 434.692942: rtos_queue_send_from_isr_failed: tstamp:13779975967 queue:0x0bcbc160
kworker/0:0-4 [000] … 434.692943: rtcpu_vinotify_event: tstamp:13780235302 tag:FE channel:0x00 frame:3 vi_tstamp:13779956517 data:0x00000020
kworker/0:0-4 [000] … 434.692974: rtcpu_vinotify_event: tstamp:13780235474 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:3 vi_tstamp:13779956518 data:0x01000000
kworker/0:0-4 [000] … 434.692976: rtcpu_vinotify_event: tstamp:13780235667 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:15756863936 data:0x01020001
kworker/0:0-4 [000] … 434.692977: rtcpu_vinotify_event: tstamp:13780235822 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:13779956521 data:0x00000000
kworker/0:0-4 [000] … 434.748880: rtcpu_vinotify_event: tstamp:13781209447 tag:FS channel:0x00 frame:4 vi_tstamp:13780933257 data:0x00000010
kworker/0:0-4 [000] … 434.748886: rtcpu_vinotify_event: tstamp:13781209608 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:13780933260 data:0x00000000
kworker/0:0-4 [000] … 434.748888: rtcpu_vinotify_event: tstamp:13781209801 tag:FE channel:0x00 frame:4 vi_tstamp:13781206181 data:0x00000020
kworker/0:0-4 [000] … 434.748889: rtcpu_vinotify_event: tstamp:13781209954 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:4 vi_tstamp:13781206181 data:0x01000000
kworker/0:0-4 [000] … 434.748891: rtcpu_vinotify_event: tstamp:13781700483 tag:RESERVED_19 channel:0x23 frame:4 vi_tstamp:15796859104 data:0x01020001
kworker/0:0-4 [000] … 434.748892: rtcpu_vinotify_event: tstamp:13781700649 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:13781206184 data:0x00000000
kworker/0:0-4 [000] … 434.748893: rtcpu_vinotify_event: tstamp:13782243289 tag:FS channel:0x00 frame:1 vi_tstamp:13782182920 data:0x00000010
kworker/0:0-4 [000] … 434.804869: rtcpu_vinotify_event: tstamp:13782785307 tag:FE channel:0x00 frame:1 vi_tstamp:13782455838 data:0x00000020
kworker/0:0-4 [000] … 434.804874: rtos_queue_peek_from_isr_failed: tstamp:13783570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 434.804876: rtcpu_vinotify_event: tstamp:13783870924 tag:FS channel:0x00 frame:2 vi_tstamp:13783432578 data:0x00000010
kworker/0:0-4 [000] … 434.804878: rtcpu_vinotify_event: tstamp:13783871073 tag:FE channel:0x00 frame:2 vi_tstamp:13783705502 data:0x00000020
kworker/0:0-4 [000] … 434.860865: rtcpu_vinotify_event: tstamp:13784955640 tag:FS channel:0x00 frame:3 vi_tstamp:13784682241 data:0x00000010
kworker/0:0-4 [000] … 434.860870: rtcpu_vinotify_event: tstamp:13785498428 tag:FE channel:0x00 frame:3 vi_tstamp:13784955164 data:0x00000020
kworker/0:0-4 [000] … 434.916867: rtcpu_vinotify_event: tstamp:13786040469 tag:FS channel:0x00 frame:4 vi_tstamp:13785931904 data:0x00000010
kworker/0:0-4 [000] … 434.916871: rtcpu_vinotify_event: tstamp:13786583245 tag:FE channel:0x00 frame:4 vi_tstamp:13786204822 data:0x00000020
kworker/0:0-4 [000] … 434.916872: rtcpu_vinotify_event: tstamp:13787668065 tag:FS channel:0x00 frame:1 vi_tstamp:13787181561 data:0x00000010
kworker/0:0-4 [000] … 434.916874: rtcpu_vinotify_event: tstamp:13787668213 tag:FE channel:0x00 frame:1 vi_tstamp:13787454485 data:0x00000020
kworker/0:0-4 [000] … 434.972866: rtos_queue_peek_from_isr_failed: tstamp:13788570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 434.972869: rtcpu_vinotify_event: tstamp:13788753687 tag:FS channel:0x00 frame:2 vi_tstamp:13788431224 data:0x00000010
kworker/0:0-4 [000] … 434.972871: rtcpu_vinotify_event: tstamp:13788753835 tag:FE channel:0x00 frame:2 vi_tstamp:13788704146 data:0x00000020
kworker/0:0-4 [000] … 435.028867: rtcpu_vinotify_event: tstamp:13789838403 tag:FS channel:0x00 frame:3 vi_tstamp:13789680882 data:0x00000010
kworker/0:0-4 [000] … 435.028870: rtcpu_vinotify_event: tstamp:13789956283 tag:FE channel:0x00 frame:3 vi_tstamp:13789953806 data:0x00000020
kworker/0:0-4 [000] … 435.028872: rtcpu_vinotify_event: tstamp:13790978287 tag:FS channel:0x00 frame:4 vi_tstamp:13790930546 data:0x00000010
kworker/0:0-4 [000] … 435.084857: rtcpu_vinotify_event: tstamp:13791520297 tag:FE channel:0x00 frame:4 vi_tstamp:13791203469 data:0x00000020
kworker/0:0-4 [000] … 435.084859: rtcpu_vinotify_event: tstamp:13792605116 tag:FS channel:0x00 frame:1 vi_tstamp:13792180203 data:0x00000010
kworker/0:0-4 [000] … 435.084862: rtcpu_vinotify_event: tstamp:13792605265 tag:FE channel:0x00 frame:1 vi_tstamp:13792453126 data:0x00000020
kworker/0:0-4 [000] … 435.140881: rtos_queue_peek_from_isr_failed: tstamp:13793570455 queue:0x0bcbcf78
kworker/0:0-4 [000] … 435.140885: rtcpu_vinotify_event: tstamp:13793690641 tag:FS channel:0x00 frame:2 vi_tstamp:13793429865 data:0x00000010
kworker/0:0-4 [000] … 435.140887: rtcpu_vinotify_event: tstamp:13794233442 tag:FE channel:0x00 frame:2 vi_tstamp:13793702788 data:0x00000020
kworker/0:0-4 [000] … 435.196864: rtcpu_vinotify_event: tstamp:13794775461 tag:FS channel:0x00 frame:3 vi_tstamp:13794679528 data:0x00000010
kworker/0:0-4 [000] … 435.196866: rtcpu_vinotify_event: tstamp:13795318265 tag:FE channel:0x00 frame:3 vi_tstamp:13794952451 data:0x00000020
kworker/0:0-4 [000] … 435.196868: rtcpu_vinotify_event: tstamp:13796403086 tag:FS channel:0x00 frame:4 vi_tstamp:13795929185 data:0x00000010
kworker/0:0-4 [000] … 435.196869: rtcpu_vinotify_event: tstamp:13796403237 tag:FE channel:0x00 frame:4 vi_tstamp:13796202109 data:0x00000020
kworker/0:0-4 [000] … 435.252865: rtcpu_vinotify_event: tstamp:13797488709 tag:FS channel:0x00 frame:1 vi_tstamp:13797178848 data:0x00000010
kworker/0:0-4 [000] … 435.252868: rtcpu_vinotify_event: tstamp:13797488862 tag:FE channel:0x00 frame:1 vi_tstamp:13797451772 data:0x00000020
kworker/0:0-4 [000] … 435.308860: rtos_queue_peek_from_isr_failed: tstamp:13798570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 435.308862: rtcpu_vinotify_event: tstamp:13798573370 tag:FS channel:0x00 frame:2 vi_tstamp:13798428511 data:0x00000010
kworker/0:0-4 [000] … 435.308864: rtcpu_vinotify_event: tstamp:13799116230 tag:FE channel:0x00 frame:2 vi_tstamp:13798701430 data:0x00000020
kworker/0:0-4 [000] … 435.308865: rtcpu_vinotify_event: tstamp:13799953569 tag:FS channel:0x00 frame:3 vi_tstamp:13799678169 data:0x00000010
kworker/0:0-4 [000] … 435.308866: rtcpu_vinotify_event: tstamp:13799953722 tag:FE channel:0x00 frame:3 vi_tstamp:13799951093 data:0x00000020
kworker/0:0-4 [000] … 435.364892: rtcpu_vinotify_event: tstamp:13800960876 tag:FS channel:0x00 frame:4 vi_tstamp:13800927833 data:0x00000010
kworker/0:0-4 [000] … 435.364896: rtcpu_vinotify_event: tstamp:13801502892 tag:FE channel:0x00 frame:4 vi_tstamp:13801200756 data:0x00000020
kworker/0:0-4 [000] … 435.420866: rtcpu_vinotify_event: tstamp:13802588508 tag:FS channel:0x00 frame:1 vi_tstamp:13802177490 data:0x00000010
kworker/0:0-4 [000] … 435.420869: rtcpu_vinotify_event: tstamp:13802588663 tag:FE channel:0x00 frame:1 vi_tstamp:13802450413 data:0x00000020
kworker/0:0-4 [000] … 435.476867: rtos_queue_peek_from_isr_failed: tstamp:13803570452 queue:0x0bcbcf78
kworker/0:0-4 [000] … 435.476870: rtcpu_vinotify_event: tstamp:13803673223 tag:FS channel:0x00 frame:2 vi_tstamp:13803427152 data:0x00000010
kworker/0:0-4 [000] … 435.476872: rtcpu_vinotify_event: tstamp:13804216030 tag:FE channel:0x00 frame:2 vi_tstamp:13803700075 data:0x00000020
kworker/0:0-4 [000] … 435.476873: rtcpu_vinotify_event: tstamp:13804758040 tag:FS channel:0x00 frame:3 vi_tstamp:13804676814 data:0x00000010
kworker/0:0-4 [000] … 435.532871: rtcpu_vinotify_event: tstamp:13805300851 tag:FE channel:0x00 frame:3 vi_tstamp:13804949738 data:0x00000020
kworker/0:0-4 [000] … 435.532873: rtcpu_vinotify_event: tstamp:13806385671 tag:FS channel:0x00 frame:4 vi_tstamp:13805926472 data:0x00000010
kworker/0:0-4 [000] … 435.532875: rtcpu_vinotify_event: tstamp:13806385858 tag:FE channel:0x00 frame:4 vi_tstamp:13806199395 data:0x00000020
kworker/0:0-4 [000] … 435.588887: rtcpu_vinotify_event: tstamp:13807471356 tag:FS channel:0x00 frame:1 vi_tstamp:13807176135 data:0x00000010
kworker/0:0-4 [000] … 435.588892: rtcpu_vinotify_event: tstamp:13807471505 tag:FE channel:0x00 frame:1 vi_tstamp:13807449058 data:0x00000020
kworker/0:0-4 [000] … 435.588894: rtcpu_vinotify_event: tstamp:13808556011 tag:FS channel:0x00 frame:2 vi_tstamp:13808425798 data:0x00000010
kworker/0:0-4 [000] … 435.588897: rtos_queue_peek_from_isr_failed: tstamp:13808570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 435.644879: rtcpu_vinotify_event: tstamp:13809098829 tag:FE channel:0x00 frame:2 vi_tstamp:13808698720 data:0x00000020
kworker/0:0-4 [000] … 435.644883: rtcpu_vinotify_event: tstamp:13809950855 tag:FS channel:0x00 frame:3 vi_tstamp:13809675455 data:0x00000010
kworker/0:0-4 [000] … 435.644885: rtcpu_vinotify_event: tstamp:13809951004 tag:FE channel:0x00 frame:3 vi_tstamp:13809948379 data:0x00000020
kworker/0:0-4 [000] … 435.700888: rtcpu_vinotify_event: tstamp:13810943477 tag:FS channel:0x00 frame:4 vi_tstamp:13810925119 data:0x00000010
kworker/0:0-4 [000] … 435.700892: rtcpu_vinotify_event: tstamp:13811486283 tag:FE channel:0x00 frame:4 vi_tstamp:13811198043 data:0x00000020
kworker/0:0-4 [000] … 435.756876: rtcpu_vinotify_event: tstamp:13812571103 tag:FS channel:0x00 frame:1 vi_tstamp:13812174776 data:0x00000010
kworker/0:0-4 [000] … 435.756880: rtcpu_vinotify_event: tstamp:13812571277 tag:FE channel:0x00 frame:1 vi_tstamp:13812447700 data:0x00000020
kworker/0:0-4 [000] … 435.756883: rtos_queue_peek_from_isr_failed: tstamp:13813570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 435.756885: rtcpu_vinotify_event: tstamp:13813655816 tag:FS channel:0x00 frame:2 vi_tstamp:13813424439 data:0x00000010
kworker/0:0-4 [000] … 435.812873: rtcpu_vinotify_event: tstamp:13814198626 tag:FE channel:0x00 frame:2 vi_tstamp:13813697363 data:0x00000020
kworker/0:0-4 [000] … 435.812876: rtcpu_vinotify_event: tstamp:13814741434 tag:FS channel:0x00 frame:3 vi_tstamp:13814674096 data:0x00000010
kworker/0:0-4 [000] … 435.812878: rtcpu_vinotify_event: tstamp:13815283501 tag:FE channel:0x00 frame:3 vi_tstamp:13814947020 data:0x00000020
kworker/0:0-4 [000] … 435.868879: rtcpu_vinotify_event: tstamp:13816369071 tag:FS channel:0x00 frame:4 vi_tstamp:13815923759 data:0x00000010
kworker/0:0-4 [000] … 435.868882: rtcpu_vinotify_event: tstamp:13816369224 tag:FE channel:0x00 frame:4 vi_tstamp:13816196683 data:0x00000020
kworker/0:0-4 [000] … 435.868883: rtcpu_vinotify_event: tstamp:13817453892 tag:FS channel:0x00 frame:1 vi_tstamp:13817173423 data:0x00000010
kworker/0:0-4 [000] … 435.868885: rtcpu_vinotify_event: tstamp:13817454040 tag:FE channel:0x00 frame:1 vi_tstamp:13817446345 data:0x00000020
kworker/0:0-4 [000] … 435.924870: rtcpu_vinotify_event: tstamp:13818538611 tag:FS channel:0x00 frame:2 vi_tstamp:13818423081 data:0x00000010
kworker/0:0-4 [000] … 435.924873: rtos_queue_peek_from_isr_failed: tstamp:13818570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 435.924874: rtcpu_vinotify_event: tstamp:13819081418 tag:FE channel:0x00 frame:2 vi_tstamp:13818696002 data:0x00000020
kworker/0:0-4 [000] … 435.980870: rtcpu_vinotify_event: tstamp:13819948143 tag:FS channel:0x00 frame:3 vi_tstamp:13819672741 data:0x00000010
kworker/0:0-4 [000] … 435.980872: rtcpu_vinotify_event: tstamp:13819948297 tag:FE channel:0x00 frame:3 vi_tstamp:13819945665 data:0x00000020
kworker/0:0-4 [000] … 435.980874: rtcpu_vinotify_event: tstamp:13820926073 tag:FS channel:0x00 frame:4 vi_tstamp:13820922401 data:0x00000010
kworker/0:0-4 [000] … 436.036875: rtcpu_vinotify_event: tstamp:13821468883 tag:FE channel:0x00 frame:4 vi_tstamp:13821195325 data:0x00000020
kworker/0:0-4 [000] … 436.036878: rtcpu_vinotify_event: tstamp:13822553699 tag:FS channel:0x00 frame:1 vi_tstamp:13822172063 data:0x00000010
kworker/0:0-4 [000] … 436.036880: rtcpu_vinotify_event: tstamp:13822553847 tag:FE channel:0x00 frame:1 vi_tstamp:13822444986 data:0x00000020
kworker/0:0-4 [000] … 436.092894: rtos_queue_peek_from_isr_failed: tstamp:13823570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 436.092897: rtcpu_vinotify_event: tstamp:13823638415 tag:FS channel:0x00 frame:2 vi_tstamp:13823421726 data:0x00000010
kworker/0:0-4 [000] … 436.092899: rtcpu_vinotify_event: tstamp:13824181225 tag:FE channel:0x00 frame:2 vi_tstamp:13823694650 data:0x00000020
kworker/0:0-4 [000] … 436.148877: rtcpu_vinotify_event: tstamp:13824724036 tag:FS channel:0x00 frame:3 vi_tstamp:13824671383 data:0x00000010
kworker/0:0-4 [000] … 436.148879: rtcpu_vinotify_event: tstamp:13825266039 tag:FE channel:0x00 frame:3 vi_tstamp:13824944307 data:0x00000020
kworker/0:0-4 [000] … 436.204865: rtcpu_vinotify_event: tstamp:13826351662 tag:FS channel:0x00 frame:4 vi_tstamp:13825921044 data:0x00000010
kworker/0:0-4 [000] … 436.204868: rtcpu_vinotify_event: tstamp:13826351815 tag:FE channel:0x00 frame:4 vi_tstamp:13826193968 data:0x00000020
kworker/0:0-4 [000] … 436.204870: rtcpu_vinotify_event: tstamp:13827436375 tag:FS channel:0x00 frame:1 vi_tstamp:13827170708 data:0x00000010
kworker/0:0-4 [000] … 436.260881: rtcpu_vinotify_event: tstamp:13827979188 tag:FE channel:0x00 frame:1 vi_tstamp:13827443632 data:0x00000020
kworker/0:0-4 [000] … 436.260884: rtcpu_vinotify_event: tstamp:13828521999 tag:FS channel:0x00 frame:2 vi_tstamp:13828420367 data:0x00000010
kworker/0:0-4 [000] … 436.260886: rtos_queue_peek_from_isr_failed: tstamp:13828570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 436.260887: rtcpu_vinotify_event: tstamp:13829064057 tag:FE channel:0x00 frame:2 vi_tstamp:13828693291 data:0x00000020
kworker/0:0-4 [000] … 436.316886: rtcpu_vinotify_event: tstamp:13829945434 tag:FS channel:0x00 frame:3 vi_tstamp:13829670031 data:0x00000010
kworker/0:0-4 [000] … 436.316888: rtcpu_vinotify_event: tstamp:13829945605 tag:FE channel:0x00 frame:3 vi_tstamp:13829942954 data:0x00000020
kworker/0:0-4 [000] … 436.316890: rtcpu_vinotify_event: tstamp:13830963451 tag:FS channel:0x00 frame:4 vi_tstamp:13830919688 data:0x00000010
kworker/0:0-4 [000] … 436.372877: rtcpu_vinotify_event: tstamp:13831505462 tag:FE channel:0x00 frame:4 vi_tstamp:13831192611 data:0x00000020
kworker/0:0-4 [000] … 436.372880: rtcpu_vinotify_event: tstamp:13832591081 tag:FS channel:0x00 frame:1 vi_tstamp:13832169351 data:0x00000010
kworker/0:0-4 [000] … 436.372882: rtcpu_vinotify_event: tstamp:13832591229 tag:FE channel:0x00 frame:1 vi_tstamp:13832442275 data:0x00000020
kworker/0:0-4 [000] … 436.428873: rtos_queue_peek_from_isr_failed: tstamp:13833570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 436.428875: rtcpu_vinotify_event: tstamp:13833675802 tag:FS channel:0x00 frame:2 vi_tstamp:13833419009 data:0x00000010
kworker/0:0-4 [000] … 436.428877: rtcpu_vinotify_event: tstamp:13834218610 tag:FE channel:0x00 frame:2 vi_tstamp:13833691932 data:0x00000020
kworker/0:0-4 [000] … 436.428878: rtcpu_vinotify_event: tstamp:13834760618 tag:FS channel:0x00 frame:3 vi_tstamp:13834668672 data:0x00000010
kworker/0:0-4 [000] … 436.484874: rtcpu_vinotify_event: tstamp:13835303436 tag:FE channel:0x00 frame:3 vi_tstamp:13834941596 data:0x00000020
kworker/0:0-4 [000] … 436.484876: rtcpu_vinotify_event: tstamp:13836388258 tag:FS channel:0x00 frame:4 vi_tstamp:13835918335 data:0x00000010
kworker/0:0-4 [000] … 436.484877: rtcpu_vinotify_event: tstamp:13836388406 tag:FE channel:0x00 frame:4 vi_tstamp:13836191253 data:0x00000020
kworker/0:0-4 [000] … 436.540900: rtcpu_vinotify_event: tstamp:13837473883 tag:FS channel:0x00 frame:1 vi_tstamp:13837167993 data:0x00000010
kworker/0:0-4 [000] … 436.540902: rtcpu_vinotify_event: tstamp:13837474035 tag:FE channel:0x00 frame:1 vi_tstamp:13837440916 data:0x00000020
kworker/0:0-4 [000] … 436.596874: rtcpu_vinotify_event: tstamp:13838558599 tag:FS channel:0x00 frame:2 vi_tstamp:13838417654 data:0x00000010
kworker/0:0-4 [000] … 436.596876: rtos_queue_peek_from_isr_failed: tstamp:13838570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 436.596878: rtcpu_vinotify_event: tstamp:13839101405 tag:FE channel:0x00 frame:2 vi_tstamp:13838690578 data:0x00000020
kworker/0:0-4 [000] … 436.596879: rtcpu_vinotify_event: tstamp:13839942708 tag:FS channel:0x00 frame:3 vi_tstamp:13839667313 data:0x00000010
kworker/0:0-4 [000] … 436.596881: rtcpu_vinotify_event: tstamp:13839942856 tag:FE channel:0x00 frame:3 vi_tstamp:13839940235 data:0x00000020
kworker/0:0-4 [000] … 436.652876: rtcpu_vinotify_event: tstamp:13840946047 tag:FS channel:0x00 frame:4 vi_tstamp:13840916975 data:0x00000010
kworker/0:0-4 [000] … 436.652879: rtcpu_vinotify_event: tstamp:13841488053 tag:FE channel:0x00 frame:4 vi_tstamp:13841189898 data:0x00000020
kworker/0:0-4 [000] … 436.708891: rtcpu_vinotify_event: tstamp:13842573676 tag:FS channel:0x00 frame:1 vi_tstamp:13842166638 data:0x00000010
kworker/0:0-4 [000] … 436.708896: rtcpu_vinotify_event: tstamp:13842573826 tag:FE channel:0x00 frame:1 vi_tstamp:13842439561 data:0x00000020
kworker/0:0-4 [000] … 436.708898: rtos_queue_peek_from_isr_failed: tstamp:13843570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 436.708899: rtcpu_vinotify_event: tstamp:13843658444 tag:FS channel:0x00 frame:2 vi_tstamp:13843416298 data:0x00000010
kworker/0:0-4 [000] … 436.764873: rtcpu_vinotify_event: tstamp:13844201200 tag:FE channel:0x00 frame:2 vi_tstamp:13843689221 data:0x00000020
kworker/0:0-4 [000] … 436.764909: rtcpu_vinotify_event: tstamp:13844744008 tag:FS channel:0x00 frame:3 vi_tstamp:13844665961 data:0x00000010
kworker/0:0-4 [000] … 436.764910: rtcpu_vinotify_event: tstamp:13845286017 tag:FE channel:0x00 frame:3 vi_tstamp:13844938878 data:0x00000020
kworker/0:0-4 [000] … 436.820892: rtcpu_vinotify_event: tstamp:13846371637 tag:FS channel:0x00 frame:4 vi_tstamp:13845915618 data:0x00000010
kworker/0:0-4 [000] … 436.820895: rtcpu_vinotify_event: tstamp:13846371786 tag:FE channel:0x00 frame:4 vi_tstamp:13846188542 data:0x00000020
kworker/0:0-4 [000] … 436.876887: rtcpu_vinotify_event: tstamp:13847456464 tag:FS channel:0x00 frame:1 vi_tstamp:13847165281 data:0x00000010
kworker/0:0-4 [000] … 436.876889: rtcpu_vinotify_event: tstamp:13847456619 tag:FE channel:0x00 frame:1 vi_tstamp:13847438205 data:0x00000020
kworker/0:0-4 [000] … 436.876891: rtcpu_vinotify_event: tstamp:13848541174 tag:FS channel:0x00 frame:2 vi_tstamp:13848414939 data:0x00000010
kworker/0:0-4 [000] … 436.876893: rtos_queue_peek_from_isr_failed: tstamp:13848570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 436.932896: rtcpu_vinotify_event: tstamp:13849083947 tag:FE channel:0x00 frame:2 vi_tstamp:13848687863 data:0x00000020
kworker/0:0-4 [000] … 436.932901: rtcpu_vinotify_event: tstamp:13849940054 tag:FS channel:0x00 frame:3 vi_tstamp:13849664602 data:0x00000010
kworker/0:0-4 [000] … 436.932903: rtcpu_vinotify_event: tstamp:13849940203 tag:FE channel:0x00 frame:3 vi_tstamp:13849937524 data:0x00000020
kworker/0:0-4 [000] … 436.988884: rtcpu_vinotify_event: tstamp:13850928638 tag:FS channel:0x00 frame:4 vi_tstamp:13850914266 data:0x00000010
kworker/0:0-4 [000] … 436.988920: rtcpu_vinotify_event: tstamp:13851471449 tag:FE channel:0x00 frame:4 vi_tstamp:13851187183 data:0x00000020
kworker/0:0-4 [000] … 437.044889: rtcpu_vinotify_event: tstamp:13852556270 tag:FS channel:0x00 frame:1 vi_tstamp:13852163923 data:0x00000010
kworker/0:0-4 [000] … 437.044892: rtcpu_vinotify_event: tstamp:13852556440 tag:FE channel:0x00 frame:1 vi_tstamp:13852436846 data:0x00000020
kworker/0:0-4 [000] … 437.044895: rtos_queue_peek_from_isr_failed: tstamp:13853570455 queue:0x0bcbcf78
kworker/0:0-4 [000] … 437.044897: rtcpu_vinotify_event: tstamp:13853640985 tag:FS channel:0x00 frame:2 vi_tstamp:13853413586 data:0x00000010
kworker/0:0-4 [000] … 437.044898: rtcpu_vinotify_event: tstamp:13854183795 tag:FE channel:0x00 frame:2 vi_tstamp:13853686509 data:0x00000020
kworker/0:0-4 [000] … 437.100892: rtcpu_vinotify_event: tstamp:13854726602 tag:FS channel:0x00 frame:3 vi_tstamp:13854663244 data:0x00000010
kworker/0:0-4 [000] … 437.100894: rtcpu_vinotify_event: tstamp:13855268611 tag:FE channel:0x00 frame:3 vi_tstamp:13854936168 data:0x00000020
kworker/0:0-4 [000] … 437.156880: rtcpu_vinotify_event: tstamp:13856354237 tag:FS channel:0x00 frame:4 vi_tstamp:13855912907 data:0x00000010
kworker/0:0-4 [000] … 437.156882: rtcpu_vinotify_event: tstamp:13856354389 tag:FE channel:0x00 frame:4 vi_tstamp:13856185826 data:0x00000020
kworker/0:0-4 [000] … 437.156884: rtcpu_vinotify_event: tstamp:13857439057 tag:FS channel:0x00 frame:1 vi_tstamp:13857162566 data:0x00000010
kworker/0:0-4 [000] … 437.156886: rtcpu_vinotify_event: tstamp:13857439206 tag:FE channel:0x00 frame:1 vi_tstamp:13857435489 data:0x00000020
kworker/0:0-4 [000] … 437.212911: rtos_queue_send_from_isr_failed: tstamp:13858350198 queue:0x0bcb41f8
kworker/0:0-4 [000] … 437.212915: rtos_queue_send_from_isr_failed: tstamp:13858350360 queue:0x0bcb8a60
kworker/0:0-4 [000] … 437.212917: rtos_queue_send_from_isr_failed: tstamp:13858350522 queue:0x0bcba5e0
kworker/0:0-4 [000] … 437.212919: rtos_queue_send_from_isr_failed: tstamp:13858350679 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 437.212920: rtos_queue_send_from_isr_failed: tstamp:13858350836 queue:0x0bcbc160
kworker/0:0-4 [000] … 437.212922: rtos_queue_send_from_isr_failed: tstamp:13858427777 queue:0x0bcb41f8
kworker/0:0-4 [000] … 437.212923: rtos_queue_send_from_isr_failed: tstamp:13858427937 queue:0x0bcb8a60
kworker/0:0-4 [000] … 437.212925: rtos_queue_send_from_isr_failed: tstamp:13858428100 queue:0x0bcba5e0
kworker/0:0-4 [000] … 437.212926: rtos_queue_send_from_isr_failed: tstamp:13858428257 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 437.212927: rtos_queue_send_from_isr_failed: tstamp:13858428415 queue:0x0bcbc160
kworker/0:0-4 [000] … 437.212931: rtcpu_string: tstamp:13858435413 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] … 437.212962: rtcpu_string: tstamp:13858435605 id:0x04010000 str:"VM GOS[#0 ] addr=0xe4900000
kworker/0:0-4 [000] … 437.212973: rtcpu_string: tstamp:13858435871 id:0x04010000 str:"VM GOS[#1 ] addr=0xe4901000
kworker/0:0-4 [000] … 437.212983: rtcpu_string: tstamp:13858436151 id:0x04010000 str:"VM GOS[#2 ] addr=0xe4902000
kworker/0:0-4 [000] … 437.212992: rtcpu_string: tstamp:13858436392 id:0x04010000 str:"VM GOS[#3 ] addr=0xe4903000
kworker/0:0-4 [000] … 437.213006: rtcpu_string: tstamp:13858436633 id:0x04010000 str:"VM GOS[#4 ] addr=0xe4904000
kworker/0:0-4 [000] … 437.213020: rtcpu_string: tstamp:13858436875 id:0x04010000 str:"VM GOS[#5 ] addr=0xe4905000
kworker/0:0-4 [000] … 437.213031: rtos_queue_send_from_isr_failed: tstamp:13858439203 queue:0x0bcb41f8
kworker/0:0-4 [000] … 437.213032: rtos_queue_send_from_isr_failed: tstamp:13858439368 queue:0x0bcb8a60
kworker/0:0-4 [000] … 437.213034: rtos_queue_send_from_isr_failed: tstamp:13858439530 queue:0x0bcba5e0
kworker/0:0-4 [000] … 437.213035: rtos_queue_send_from_isr_failed: tstamp:13858439686 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 437.213036: rtos_queue_send_from_isr_failed: tstamp:13858439841 queue:0x0bcbc160
kworker/0:0-4 [000] … 437.213039: rtcpu_vinotify_event: tstamp:13858448284 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:13973490496 data:0x10000000
kworker/0:0-4 [000] … 437.213041: rtcpu_vinotify_event: tstamp:13858448438 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:13973519904 data:0x31000001
kworker/0:0-4 [000] … 437.213042: rtcpu_vinotify_event: tstamp:13858448632 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:13973530080 data:0x10000000
kworker/0:0-4 [000] … 437.213044: rtcpu_vinotify_event: tstamp:13858448778 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:13973538528 data:0x07020001
kworker/0:0-4 [000] … 437.213046: rtos_queue_peek_from_isr_failed: tstamp:13858570439 queue:0x0bcbcf78
kworker/0:0-4 [000] … 437.213048: rtcpu_vinotify_error: tstamp:13858688039 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:13858685150 data:0x00000001
kworker/0:0-4 [000] … 437.213049: rtcpu_vinotify_event: tstamp:13858958515 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:13973658016 data:0x31000002
kworker/0:0-4 [000] … 437.213051: rtcpu_vinotify_event: tstamp:13858958672 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:13858685150 data:0x00000001
kworker/0:0-4 [000] … 437.268919: rtos_queue_send_from_isr_failed: tstamp:13859952909 queue:0x0bcb41f8
kworker/0:0-4 [000] … 437.268923: rtos_queue_send_from_isr_failed: tstamp:13859953071 queue:0x0bcb8a60
kworker/0:0-4 [000] … 437.268925: rtos_queue_send_from_isr_failed: tstamp:13859953237 queue:0x0bcba5e0
kworker/0:0-4 [000] … 437.268926: rtos_queue_send_from_isr_failed: tstamp:13859953394 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 437.268928: rtos_queue_send_from_isr_failed: tstamp:13859953551 queue:0x0bcbc160
kworker/0:0-4 [000] … 437.268930: rtcpu_vinotify_event: tstamp:13860043481 tag:FS channel:0x00 frame:3 vi_tstamp:13859661884 data:0x00000010
kworker/0:0-4 [000] … 437.268931: rtcpu_vinotify_event: tstamp:13860043638 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:13859661887 data:0x00000000
kworker/0:0-4 [000] … 437.268933: rtcpu_vinotify_event: tstamp:13860043829 tag:FE channel:0x00 frame:3 vi_tstamp:13859934808 data:0x00000020
kworker/0:0-4 [000] … 437.268934: rtcpu_vinotify_event: tstamp:13860043996 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:3 vi_tstamp:13859934808 data:0x01000000
kworker/0:0-4 [000] … 437.268967: rtcpu_vinotify_event: tstamp:13860044188 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:14021201952 data:0x01020001
kworker/0:0-4 [000] … 437.268968: rtcpu_vinotify_event: tstamp:13860044340 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:13859934811 data:0x00000000
kworker/0:0-4 [000] … 437.268969: rtcpu_vinotify_event: tstamp:13861128542 tag:FS channel:0x00 frame:4 vi_tstamp:13860911549 data:0x00000010
kworker/0:0-4 [000] … 437.268971: rtcpu_vinotify_event: tstamp:13861128693 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:13860911552 data:0x00000000
kworker/0:0-4 [000] … 437.324932: rtcpu_vinotify_event: tstamp:13861670654 tag:FE channel:0x00 frame:4 vi_tstamp:13861184472 data:0x00000020
kworker/0:0-4 [000] … 437.324936: rtcpu_vinotify_event: tstamp:13861670807 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:4 vi_tstamp:13861184472 data:0x01000000
kworker/0:0-4 [000] … 437.324937: rtcpu_vinotify_event: tstamp:13861671001 tag:RESERVED_19 channel:0x23 frame:4 vi_tstamp:14061191168 data:0x01020001
kworker/0:0-4 [000] … 437.324939: rtcpu_vinotify_event: tstamp:13861671170 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:13861184474 data:0x00000000
kworker/0:0-4 [000] … 437.324940: rtcpu_vinotify_event: tstamp:13862213463 tag:FS channel:0x00 frame:1 vi_tstamp:13862161205 data:0x00000010
kworker/0:0-4 [000] … 437.324941: rtcpu_vinotify_event: tstamp:13862436610 tag:FE channel:0x00 frame:1 vi_tstamp:13862434129 data:0x00000020
kworker/0:0-4 [000] … 437.380944: rtcpu_vinotify_event: tstamp:13863461313 tag:FS channel:0x00 frame:2 vi_tstamp:13863410870 data:0x00000010
kworker/0:0-4 [000] … 437.380947: rtos_queue_peek_from_isr_failed: tstamp:13863570455 queue:0x0bcbcf78
kworker/0:0-4 [000] … 437.380949: rtcpu_vinotify_event: tstamp:13864004124 tag:FE channel:0x00 frame:2 vi_tstamp:13863683792 data:0x00000020
kworker/0:0-4 [000] … 437.436899: rtcpu_vinotify_event: tstamp:13865088944 tag:FS channel:0x00 frame:3 vi_tstamp:13864660532 data:0x00000010
kworker/0:0-4 [000] … 437.436901: rtcpu_vinotify_event: tstamp:13865089094 tag:FE channel:0x00 frame:3 vi_tstamp:13864933455 data:0x00000020
kworker/0:0-4 [000] … 437.436903: rtcpu_vinotify_event: tstamp:13866173652 tag:FS channel:0x00 frame:4 vi_tstamp:13865910189 data:0x00000010
kworker/0:0-4 [000] … 437.492897: rtcpu_vinotify_event: tstamp:13866716466 tag:FE channel:0x00 frame:4 vi_tstamp:13866183113 data:0x00000020
kworker/0:0-4 [000] … 437.492900: rtcpu_vinotify_event: tstamp:13867259266 tag:FS channel:0x00 frame:1 vi_tstamp:13867159852 data:0x00000010
kworker/0:0-4 [000] … 437.492902: rtcpu_vinotify_event: tstamp:13867801275 tag:FE channel:0x00 frame:1 vi_tstamp:13867432776 data:0x00000020
kworker/0:0-4 [000] … 437.548890: rtos_queue_peek_from_isr_failed: tstamp:13868570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 437.548894: rtcpu_vinotify_event: tstamp:13868886893 tag:FS channel:0x00 frame:2 vi_tstamp:13868409514 data:0x00000010
kworker/0:0-4 [000] … 437.548895: rtcpu_vinotify_event: tstamp:13868887043 tag:FE channel:0x00 frame:2 vi_tstamp:13868682437 data:0x00000020
kworker/0:0-4 [000] … 437.604891: rtcpu_vinotify_event: tstamp:13869971718 tag:FS channel:0x00 frame:3 vi_tstamp:13869659173 data:0x00000010
kworker/0:0-4 [000] … 437.604893: rtcpu_vinotify_event: tstamp:13869971871 tag:FE channel:0x00 frame:3 vi_tstamp:13869932094 data:0x00000020
kworker/0:0-4 [000] … 437.604895: rtcpu_vinotify_event: tstamp:13871056405 tag:FS channel:0x00 frame:4 vi_tstamp:13870908834 data:0x00000010
kworker/0:0-4 [000] … 437.604896: rtcpu_vinotify_event: tstamp:13871599219 tag:FE channel:0x00 frame:4 vi_tstamp:13871181758 data:0x00000020
kworker/0:0-4 [000] … 437.660891: rtcpu_vinotify_event: tstamp:13872433878 tag:FS channel:0x00 frame:1 vi_tstamp:13872158492 data:0x00000010
kworker/0:0-4 [000] … 437.660892: rtcpu_vinotify_event: tstamp:13872434031 tag:FE channel:0x00 frame:1 vi_tstamp:13872431416 data:0x00000020
kworker/0:0-4 [000] … 437.660894: rtcpu_vinotify_event: tstamp:13873443852 tag:FS channel:0x00 frame:2 vi_tstamp:13873408155 data:0x00000010
kworker/0:0-4 [000] … 437.716911: rtos_queue_peek_from_isr_failed: tstamp:13873570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 437.716914: rtcpu_vinotify_event: tstamp:13873986663 tag:FE channel:0x00 frame:2 vi_tstamp:13873681079 data:0x00000020
kworker/0:0-4 [000] … 437.716916: rtcpu_vinotify_event: tstamp:13875071497 tag:FS channel:0x00 frame:3 vi_tstamp:13874657819 data:0x00000010
kworker/0:0-4 [000] … 437.716917: rtcpu_vinotify_event: tstamp:13875071645 tag:FE channel:0x00 frame:3 vi_tstamp:13874930742 data:0x00000020
kworker/0:0-4 [000] … 437.772889: rtcpu_vinotify_event: tstamp:13876157018 tag:FS channel:0x00 frame:4 vi_tstamp:13875907476 data:0x00000010
kworker/0:0-4 [000] … 437.772894: rtcpu_vinotify_event: tstamp:13876699023 tag:FE channel:0x00 frame:4 vi_tstamp:13876180399 data:0x00000020
kworker/0:0-4 [000] … 437.828909: rtcpu_vinotify_event: tstamp:13877241834 tag:FS channel:0x00 frame:1 vi_tstamp:13877157139 data:0x00000010
kworker/0:0-4 [000] … 437.828912: rtcpu_vinotify_event: tstamp:13877784640 tag:FE channel:0x00 frame:1 vi_tstamp:13877430062 data:0x00000020
kworker/0:0-4 [000] … 437.828914: rtos_queue_peek_from_isr_failed: tstamp:13878570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 437.884892: rtcpu_vinotify_event: tstamp:13878869465 tag:FS channel:0x00 frame:2 vi_tstamp:13878406797 data:0x00000010
kworker/0:0-4 [000] … 437.884894: rtcpu_vinotify_event: tstamp:13878869636 tag:FE channel:0x00 frame:2 vi_tstamp:13878679721 data:0x00000020
kworker/0:0-4 [000] … 437.884895: rtcpu_vinotify_event: tstamp:13879954277 tag:FS channel:0x00 frame:3 vi_tstamp:13879656460 data:0x00000010
kworker/0:0-4 [000] … 437.884896: rtcpu_vinotify_event: tstamp:13879954425 tag:FE channel:0x00 frame:3 vi_tstamp:13879929384 data:0x00000020
kworker/0:0-4 [000] … 437.940892: rtcpu_vinotify_event: tstamp:13881039788 tag:FS channel:0x00 frame:4 vi_tstamp:13880906123 data:0x00000010
kworker/0:0-4 [000] … 437.940894: rtcpu_vinotify_event: tstamp:13881581795 tag:FE channel:0x00 frame:4 vi_tstamp:13881179041 data:0x00000020
kworker/0:0-4 [000] … 437.996926: rtcpu_vinotify_event: tstamp:13882431182 tag:FS channel:0x00 frame:1 vi_tstamp:13882155780 data:0x00000010
kworker/0:0-4 [000] … 437.996932: rtcpu_vinotify_event: tstamp:13882431335 tag:FE channel:0x00 frame:1 vi_tstamp:13882428704 data:0x00000020
kworker/0:0-4 [000] … 437.996934: rtcpu_vinotify_event: tstamp:13883426400 tag:FS channel:0x00 frame:2 vi_tstamp:13883405443 data:0x00000010
kworker/0:0-4 [000] … 437.996937: rtos_queue_peek_from_isr_failed: tstamp:13883570435 queue:0x0bcbcf78
kworker/0:0-4 [000] … 438.052927: rtcpu_vinotify_event: tstamp:13883969250 tag:FE channel:0x00 frame:2 vi_tstamp:13883678366 data:0x00000020
kworker/0:0-4 [000] … 438.052931: rtcpu_vinotify_event: tstamp:13885054063 tag:FS channel:0x00 frame:3 vi_tstamp:13884655101 data:0x00000010
kworker/0:0-4 [000] … 438.052933: rtcpu_vinotify_event: tstamp:13885054212 tag:FE channel:0x00 frame:3 vi_tstamp:13884928025 data:0x00000020
kworker/0:0-4 [000] … 438.108900: rtcpu_vinotify_event: tstamp:13886139583 tag:FS channel:0x00 frame:4 vi_tstamp:13885904765 data:0x00000010
kworker/0:0-4 [000] … 438.108902: rtcpu_vinotify_event: tstamp:13886681588 tag:FE channel:0x00 frame:4 vi_tstamp:13886177686 data:0x00000020
kworker/0:0-4 [000] … 438.108903: rtcpu_vinotify_event: tstamp:13887224397 tag:FS channel:0x00 frame:1 vi_tstamp:13887154428 data:0x00000010
kworker/0:0-4 [000] … 438.164895: rtcpu_vinotify_event: tstamp:13887767214 tag:FE channel:0x00 frame:1 vi_tstamp:13887427346 data:0x00000020
kworker/0:0-4 [000] … 438.164899: rtos_queue_peek_from_isr_failed: tstamp:13888570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 438.164900: rtcpu_vinotify_event: tstamp:13888852039 tag:FS channel:0x00 frame:2 vi_tstamp:13888404085 data:0x00000010
kworker/0:0-4 [000] … 438.164902: rtcpu_vinotify_event: tstamp:13888852188 tag:FE channel:0x00 frame:2 vi_tstamp:13888677009 data:0x00000020
kworker/0:0-4 [000] … 438.220914: rtcpu_vinotify_event: tstamp:13889936860 tag:FS channel:0x00 frame:3 vi_tstamp:13889653748 data:0x00000010
kworker/0:0-4 [000] … 438.220918: rtcpu_vinotify_event: tstamp:13889937013 tag:FE channel:0x00 frame:3 vi_tstamp:13889926672 data:0x00000020
kworker/0:0-4 [000] … 438.276896: rtcpu_vinotify_event: tstamp:13891022375 tag:FS channel:0x00 frame:4 vi_tstamp:13890903406 data:0x00000010
kworker/0:0-4 [000] … 438.276898: rtcpu_vinotify_event: tstamp:13891565186 tag:FE channel:0x00 frame:4 vi_tstamp:13891176329 data:0x00000020
kworker/0:0-4 [000] … 438.276899: rtcpu_vinotify_event: tstamp:13892428464 tag:FS channel:0x00 frame:1 vi_tstamp:13892153069 data:0x00000010
kworker/0:0-4 [000] … 438.276901: rtcpu_vinotify_event: tstamp:13892428632 tag:FE channel:0x00 frame:1 vi_tstamp:13892425991 data:0x00000020
kworker/0:0-4 [000] … 438.332908: rtcpu_vinotify_event: tstamp:13893409841 tag:FS channel:0x00 frame:2 vi_tstamp:13893402727 data:0x00000010
kworker/0:0-4 [000] … 438.332912: rtos_queue_peek_from_isr_failed: tstamp:13893570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 438.332914: rtcpu_vinotify_event: tstamp:13893951850 tag:FE channel:0x00 frame:2 vi_tstamp:13893675651 data:0x00000020
kworker/0:0-4 [000] … 438.388898: rtcpu_vinotify_event: tstamp:13895037463 tag:FS channel:0x00 frame:3 vi_tstamp:13894652390 data:0x00000010
kworker/0:0-4 [000] … 438.388900: rtcpu_vinotify_event: tstamp:13895037616 tag:FE channel:0x00 frame:3 vi_tstamp:13894925311 data:0x00000020
kworker/0:0-4 [000] … 438.388901: rtcpu_vinotify_event: tstamp:13896122179 tag:FS channel:0x00 frame:4 vi_tstamp:13895902051 data:0x00000010
kworker/0:0-4 [000] … 438.444899: rtcpu_vinotify_event: tstamp:13896664994 tag:FE channel:0x00 frame:4 vi_tstamp:13896174974 data:0x00000020
kworker/0:0-4 [000] … 438.444939: rtcpu_vinotify_event: tstamp:13897207002 tag:FS channel:0x00 frame:1 vi_tstamp:13897151709 data:0x00000010
kworker/0:0-4 [000] … 438.444940: rtcpu_vinotify_event: tstamp:13897749806 tag:FE channel:0x00 frame:1 vi_tstamp:13897424632 data:0x00000020
kworker/0:0-4 [000] … 438.500905: rtos_queue_peek_from_isr_failed: tstamp:13898570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 438.500909: rtcpu_vinotify_event: tstamp:13898834609 tag:FS channel:0x00 frame:2 vi_tstamp:13898401372 data:0x00000010
kworker/0:0-4 [000] … 438.500910: rtcpu_vinotify_event: tstamp:13898834758 tag:FE channel:0x00 frame:2 vi_tstamp:13898674295 data:0x00000020
kworker/0:0-4 [000] … 438.556902: rtcpu_vinotify_event: tstamp:13899920143 tag:FS channel:0x00 frame:3 vi_tstamp:13899651029 data:0x00000010
kworker/0:0-4 [000] … 438.556905: rtcpu_vinotify_event: tstamp:13900462152 tag:FE channel:0x00 frame:3 vi_tstamp:13899923953 data:0x00000020
kworker/0:0-4 [000] … 438.556939: rtcpu_vinotify_event: tstamp:13901004962 tag:FS channel:0x00 frame:4 vi_tstamp:13900900692 data:0x00000010
kworker/0:0-4 [000] … 438.612908: rtcpu_vinotify_event: tstamp:13901547777 tag:FE channel:0x00 frame:4 vi_tstamp:13901173616 data:0x00000020
kworker/0:0-4 [000] … 438.612911: rtcpu_vinotify_event: tstamp:13902425757 tag:FS channel:0x00 frame:1 vi_tstamp:13902150355 data:0x00000010
kworker/0:0-4 [000] … 438.612913: rtcpu_vinotify_event: tstamp:13902425905 tag:FE channel:0x00 frame:1 vi_tstamp:13902423279 data:0x00000020
kworker/0:0-4 [000] … 438.668899: rtcpu_vinotify_event: tstamp:13903446413 tag:FS channel:0x00 frame:2 vi_tstamp:13903400013 data:0x00000010
kworker/0:0-4 [000] … 438.668902: rtos_queue_peek_from_isr_failed: tstamp:13903570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 438.668903: rtcpu_vinotify_event: tstamp:13903989219 tag:FE channel:0x00 frame:2 vi_tstamp:13903672937 data:0x00000020
kworker/0:0-4 [000] … 438.724906: rtcpu_vinotify_event: tstamp:13905074032 tag:FS channel:0x00 frame:3 vi_tstamp:13904649674 data:0x00000010
kworker/0:0-4 [000] … 438.724908: rtcpu_vinotify_event: tstamp:13905074185 tag:FE channel:0x00 frame:3 vi_tstamp:13904922597 data:0x00000020
kworker/0:0-4 [000] … 438.724910: rtcpu_vinotify_event: tstamp:13906159548 tag:FS channel:0x00 frame:4 vi_tstamp:13905899337 data:0x00000010
kworker/0:0-4 [000] … 438.724912: rtcpu_vinotify_event: tstamp:13906701557 tag:FE channel:0x00 frame:4 vi_tstamp:13906172261 data:0x00000020
kworker/0:0-4 [000] … 438.780899: rtcpu_vinotify_event: tstamp:13907244369 tag:FS channel:0x00 frame:1 vi_tstamp:13907148995 data:0x00000010
kworker/0:0-4 [000] … 438.780901: rtcpu_vinotify_event: tstamp:13907787173 tag:FE channel:0x00 frame:1 vi_tstamp:13907421919 data:0x00000020
kworker/0:0-4 [000] … 438.836909: rtos_queue_peek_from_isr_failed: tstamp:13908570455 queue:0x0bcbcf78
kworker/0:0-4 [000] … 438.836911: rtcpu_vinotify_event: tstamp:13908871991 tag:FS channel:0x00 frame:2 vi_tstamp:13908398660 data:0x00000010
kworker/0:0-4 [000] … 438.836913: rtcpu_vinotify_event: tstamp:13908872139 tag:FE channel:0x00 frame:2 vi_tstamp:13908671582 data:0x00000020
kworker/0:0-4 [000] … 438.836915: rtcpu_vinotify_event: tstamp:13909956810 tag:FS channel:0x00 frame:3 vi_tstamp:13909648318 data:0x00000010
kworker/0:0-4 [000] … 438.836916: rtcpu_vinotify_event: tstamp:13909956976 tag:FE channel:0x00 frame:3 vi_tstamp:13909921242 data:0x00000020
kworker/0:0-4 [000] … 438.892908: rtcpu_vinotify_event: tstamp:13911042331 tag:FS channel:0x00 frame:4 vi_tstamp:13910897981 data:0x00000010
kworker/0:0-4 [000] … 438.892910: rtcpu_vinotify_event: tstamp:13911584333 tag:FE channel:0x00 frame:4 vi_tstamp:13911170905 data:0x00000020
kworker/0:0-4 [000] … 438.948903: rtcpu_vinotify_event: tstamp:13912423040 tag:FS channel:0x00 frame:1 vi_tstamp:13912147638 data:0x00000010
kworker/0:0-4 [000] … 438.948936: rtcpu_vinotify_event: tstamp:13912423192 tag:FE channel:0x00 frame:1 vi_tstamp:13912420562 data:0x00000020
kworker/0:0-4 [000] … 438.948938: rtcpu_vinotify_event: tstamp:13913428979 tag:FS channel:0x00 frame:2 vi_tstamp:13913397302 data:0x00000010
kworker/0:0-4 [000] … 438.948940: rtos_queue_peek_from_isr_failed: tstamp:13913570452 queue:0x0bcbcf78
kworker/0:0-4 [000] … 439.004922: rtcpu_vinotify_event: tstamp:13913971802 tag:FE channel:0x00 frame:2 vi_tstamp:13913670225 data:0x00000020
kworker/0:0-4 [000] … 439.004925: rtcpu_vinotify_event: tstamp:13915056610 tag:FS channel:0x00 frame:3 vi_tstamp:13914646959 data:0x00000010
kworker/0:0-4 [000] … 439.004927: rtcpu_vinotify_event: tstamp:13915056759 tag:FE channel:0x00 frame:3 vi_tstamp:13914919883 data:0x00000020
kworker/0:0-4 [000] … 439.060912: rtcpu_vinotify_event: tstamp:13916142131 tag:FS channel:0x00 frame:4 vi_tstamp:13915896622 data:0x00000010
kworker/0:0-4 [000] … 439.060947: rtcpu_vinotify_event: tstamp:13916684140 tag:FE channel:0x00 frame:4 vi_tstamp:13916169546 data:0x00000020
kworker/0:1-7370 [000] … 439.117156: rtcpu_vinotify_event: tstamp:13917226951 tag:FS channel:0x00 frame:1 vi_tstamp:13917146286 data:0x00000010
kworker/0:1-7370 [000] … 439.117161: rtcpu_vinotify_event: tstamp:13917769758 tag:FE channel:0x00 frame:1 vi_tstamp:13917419207 data:0x00000020
kworker/0:1-7370 [000] … 439.117164: rtos_queue_peek_from_isr_failed: tstamp:13918570456 queue:0x0bcbcf78
kworker/0:1-7370 [000] … 439.117165: rtcpu_vinotify_event: tstamp:13918854556 tag:FS channel:0x00 frame:2 vi_tstamp:13918395943 data:0x00000010
kworker/0:1-7370 [000] … 439.117166: rtcpu_vinotify_event: tstamp:13918854704 tag:FE channel:0x00 frame:2 vi_tstamp:13918668867 data:0x00000020
kworker/0:0-4 [000] … 439.172940: rtcpu_vinotify_event: tstamp:13919939452 tag:FS channel:0x00 frame:3 vi_tstamp:13919645604 data:0x00000010
kworker/0:0-4 [000] … 439.172944: rtcpu_vinotify_event: tstamp:13919939600 tag:FE channel:0x00 frame:3 vi_tstamp:13919918528 data:0x00000020
kworker/0:0-4 [000] … 439.228919: rtcpu_vinotify_event: tstamp:13921024913 tag:FS channel:0x00 frame:4 vi_tstamp:13920895267 data:0x00000010
kworker/0:0-4 [000] … 439.228922: rtcpu_vinotify_event: tstamp:13921566921 tag:FE channel:0x00 frame:4 vi_tstamp:13921168185 data:0x00000020
kworker/0:0-4 [000] … 439.228958: rtcpu_vinotify_event: tstamp:13922420308 tag:FS channel:0x00 frame:1 vi_tstamp:13922144925 data:0x00000010
kworker/0:0-4 [000] … 439.228960: rtcpu_vinotify_event: tstamp:13922420457 tag:FE channel:0x00 frame:1 vi_tstamp:13922417849 data:0x00000020
kworker/0:0-4 [000] … 439.284920: rtcpu_vinotify_event: tstamp:13923411578 tag:FS channel:0x00 frame:2 vi_tstamp:13923394588 data:0x00000010
kworker/0:0-4 [000] … 439.284925: rtos_queue_peek_from_isr_failed: tstamp:13923570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 439.284926: rtcpu_vinotify_event: tstamp:13923954385 tag:FE channel:0x00 frame:2 vi_tstamp:13923667512 data:0x00000020
kworker/0:0-4 [000] … 439.340934: rtcpu_vinotify_event: tstamp:13925039176 tag:FS channel:0x00 frame:3 vi_tstamp:13924644245 data:0x00000010
kworker/0:0-4 [000] … 439.340937: rtcpu_vinotify_event: tstamp:13925039329 tag:FE channel:0x00 frame:3 vi_tstamp:13924917169 data:0x00000020
kworker/0:0-4 [000] … 439.396919: rtcpu_vinotify_event: tstamp:13926124714 tag:FS channel:0x00 frame:4 vi_tstamp:13925893908 data:0x00000010
kworker/0:0-4 [000] … 439.396923: rtcpu_vinotify_event: tstamp:13926667520 tag:FE channel:0x00 frame:4 vi_tstamp:13926166832 data:0x00000020
kworker/0:0-4 [000] … 439.396924: rtcpu_vinotify_event: tstamp:13927209526 tag:FS channel:0x00 frame:1 vi_tstamp:13927143570 data:0x00000010
kworker/0:0-4 [000] … 439.452935: rtcpu_vinotify_event: tstamp:13927752393 tag:FE channel:0x00 frame:1 vi_tstamp:13927416494 data:0x00000020
kworker/0:0-4 [000] … 439.452940: rtos_queue_peek_from_isr_failed: tstamp:13928570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 439.452942: rtcpu_vinotify_event: tstamp:13928837122 tag:FS channel:0x00 frame:2 vi_tstamp:13928393230 data:0x00000010
kworker/0:0-4 [000] … 439.452943: rtcpu_vinotify_event: tstamp:13928837270 tag:FE channel:0x00 frame:2 vi_tstamp:13928666153 data:0x00000020
kworker/0:0-4 [000] … 439.508951: rtcpu_vinotify_event: tstamp:13929922773 tag:FS channel:0x00 frame:3 vi_tstamp:13929642890 data:0x00000010
kworker/0:0-4 [000] … 439.508956: rtcpu_vinotify_event: tstamp:13929922926 tag:FE channel:0x00 frame:3 vi_tstamp:13929915814 data:0x00000020
kworker/0:0-4 [000] … 439.508958: rtcpu_vinotify_event: tstamp:13931007480 tag:FS channel:0x00 frame:4 vi_tstamp:13930892553 data:0x00000010
kworker/0:0-4 [000] … 439.564929: rtcpu_vinotify_event: tstamp:13931550298 tag:FE channel:0x00 frame:4 vi_tstamp:13931165472 data:0x00000020
kworker/0:0-4 [000] … 439.564933: rtcpu_vinotify_event: tstamp:13932417593 tag:FS channel:0x00 frame:1 vi_tstamp:13932142212 data:0x00000010
kworker/0:0-4 [000] … 439.564935: rtcpu_vinotify_event: tstamp:13932417760 tag:FE channel:0x00 frame:1 vi_tstamp:13932415135 data:0x00000020
kworker/0:0-4 [000] … 439.620922: rtcpu_vinotify_event: tstamp:13933394967 tag:FS channel:0x00 frame:2 vi_tstamp:13933391875 data:0x00000010
kworker/0:0-4 [000] … 439.620928: rtos_queue_peek_from_isr_failed: tstamp:13933570453 queue:0x0bcbcf78
kworker/0:0-4 [000] … 439.620929: rtcpu_vinotify_event: tstamp:13933936978 tag:FE channel:0x00 frame:2 vi_tstamp:13933664798 data:0x00000020
kworker/0:0-4 [000] … 439.676929: rtcpu_vinotify_event: tstamp:13935022598 tag:FS channel:0x00 frame:3 vi_tstamp:13934641532 data:0x00000010
kworker/0:0-4 [000] … 439.676933: rtcpu_vinotify_event: tstamp:13935022751 tag:FE channel:0x00 frame:3 vi_tstamp:13934914455 data:0x00000020
kworker/0:0-4 [000] … 439.676935: rtcpu_vinotify_event: tstamp:13936107309 tag:FS channel:0x00 frame:4 vi_tstamp:13935891195 data:0x00000010
kworker/0:0-4 [000] … 439.732915: rtcpu_vinotify_event: tstamp:13936650116 tag:FE channel:0x00 frame:4 vi_tstamp:13936164119 data:0x00000020
kworker/0:0-4 [000] … 439.732917: rtcpu_vinotify_event: tstamp:13937192126 tag:FS channel:0x00 frame:1 vi_tstamp:13937140858 data:0x00000010
kworker/0:0-4 [000] … 439.732918: rtcpu_vinotify_event: tstamp:13937734933 tag:FE channel:0x00 frame:1 vi_tstamp:13937413777 data:0x00000020
kworker/0:0-4 [000] … 439.789000: rtos_queue_send_from_isr_failed: tstamp:13938351652 queue:0x0bcb41f8
kworker/0:0-4 [000] … 439.789005: rtos_queue_send_from_isr_failed: tstamp:13938351816 queue:0x0bcb8a60
kworker/0:0-4 [000] … 439.789006: rtos_queue_send_from_isr_failed: tstamp:13938351978 queue:0x0bcba5e0
kworker/0:0-4 [000] … 439.789007: rtos_queue_send_from_isr_failed: tstamp:13938352135 queue:0x0bcbb3a0
kworker/0:0-4 [000] … 439.789009: rtos_queue_send_from_isr_failed: tstamp:13938352292 queue:0x0bcbc160
kworker/0:0-4 [000] … 439.789011: rtos_queue_peek_from_isr_failed: tstamp:13938570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 439.956978: rtos_queue_peek_from_isr_failed: tstamp:13943570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 440.068950: rtos_queue_peek_from_isr_failed: tstamp:13948570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 440.236962: rtos_queue_peek_from_isr_failed: tstamp:13953570459 queue:0x0bcbcf78
kworker/0:0-4 [000] … 440.404967: rtos_queue_peek_from_isr_failed: tstamp:13958570459 queue:0x0bcbcf78
kworker/0:0-4 [000] … 440.572958: rtos_queue_peek_from_isr_failed: tstamp:13963570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 440.740953: rtos_queue_peek_from_isr_failed: tstamp:13968570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 440.908980: rtos_queue_peek_from_isr_failed: tstamp:13973570459 queue:0x0bcbcf78
kworker/0:0-4 [000] … 441.076934: rtos_queue_peek_from_isr_failed: tstamp:13978570459 queue:0x0bcbcf78
kworker/0:0-4 [000] … 441.188953: rtos_queue_peek_from_isr_failed: tstamp:13983570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 441.356979: rtos_queue_peek_from_isr_failed: tstamp:13988570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 441.524960: rtos_queue_peek_from_isr_failed: tstamp:13993570456 queue:0x0bcbcf78
kworker/0:0-4 [000] … 441.692966: rtos_queue_peek_from_isr_failed: tstamp:13998570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 441.860998: rtos_queue_peek_from_isr_failed: tstamp:14003570460 queue:0x0bcbcf78
kworker/0:0-4 [000] … 442.028965: rtos_queue_peek_from_isr_failed: tstamp:14008570460 queue:0x0bcbcf78
kworker/0:0-4 [000] … 442.196959: rtos_queue_peek_from_isr_failed: tstamp:14013570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 442.308972: rtos_queue_peek_from_isr_failed: tstamp:14018570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 442.476972: rtos_queue_peek_from_isr_failed: tstamp:14023570435 queue:0x0bcbcf78
kworker/0:0-4 [000] … 442.644977: rtos_queue_peek_from_isr_failed: tstamp:14028570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 442.812980: rtos_queue_peek_from_isr_failed: tstamp:14033570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 442.980998: rtos_queue_peek_from_isr_failed: tstamp:14038570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 443.148992: rtos_queue_peek_from_isr_failed: tstamp:14043570459 queue:0x0bcbcf78
kworker/0:0-4 [000] … 443.316983: rtos_queue_peek_from_isr_failed: tstamp:14048570460 queue:0x0bcbcf78
kworker/0:0-4 [000] … 443.428997: rtos_queue_peek_from_isr_failed: tstamp:14053570459 queue:0x0bcbcf78
kworker/0:0-4 [000] … 443.596984: rtos_queue_peek_from_isr_failed: tstamp:14058570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 443.764980: rtos_queue_peek_from_isr_failed: tstamp:14063570457 queue:0x0bcbcf78
kworker/0:0-4 [000] … 443.932973: rtos_queue_peek_from_isr_failed: tstamp:14068570461 queue:0x0bcbcf78
kworker/0:0-4 [000] … 444.101030: rtos_queue_peek_from_isr_failed: tstamp:14073570460 queue:0x0bcbcf7
And how to config xavier mipi’s speed ? Guy,help!
What’s your v4l2-ctl command line. You may lost “–set-ctrl bypass_mode=0” in your command line.
The MIPI speed is configure by the sensor configure base on it data through put.
Hi,Shane:
My command line is
v4l2-ctl --set-fmt-video=width=1280,height=720,pixelformat=YUYV --stream-mmap --stream-count=1 -d /dev/video0
Have a try below.
v4l2-ctl --set-fmt-video=width=1280,height=720,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 -d /dev/video0
Hi Shane,I tryed,Same.But now trace changed
[code]
tracer: nop
entries-in-buffer/entries-written: 1026/1026 #P:4
_-----=> irqs-off
||| / delay
kworker/0:2-1169 [000] .... 98.457633: rtos_queue_peek_from_isr_failed: tstamp:3271753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 98.625703: rtos_queue_peek_from_isr_failed: tstamp:3276753598 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 98.793668: rtos_queue_peek_from_isr_failed: tstamp:3281753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 98.961719: rtos_queue_peek_from_isr_failed: tstamp:3286753615 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 99.073680: rtos_queue_peek_from_isr_failed: tstamp:3291753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 99.241721: rtos_queue_peek_from_isr_failed: tstamp:3296753618 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 99.409700: rtos_queue_peek_from_isr_failed: tstamp:3301753617 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 99.577753: rtos_queue_peek_from_isr_failed: tstamp:3306753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 99.745762: rtos_queue_peek_from_isr_failed: tstamp:3311753615 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 99.914027: rtos_queue_peek_from_isr_failed: tstamp:3316753618 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 100.081840: rtos_queue_peek_from_isr_failed: tstamp:3321753622 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 100.193813: rtos_queue_peek_from_isr_failed: tstamp:3326753617 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 100.361823: rtos_queue_peek_from_isr_failed: tstamp:3331753617 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 100.529866: rtos_queue_peek_from_isr_failed: tstamp:3336753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 100.697858: rtos_queue_peek_from_isr_failed: tstamp:3341753618 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 100.865882: rtos_queue_peek_from_isr_failed: tstamp:3346753617 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 101.033909: rtos_queue_peek_from_isr_failed: tstamp:3351753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 101.201918: rtos_queue_peek_from_isr_failed: tstamp:3356753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 101.313924: rtos_queue_peek_from_isr_failed: tstamp:3361753615 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 101.481917: rtos_queue_peek_from_isr_failed: tstamp:3366753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 101.649942: rtos_queue_peek_from_isr_failed: tstamp:3371753617 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 101.817960: rtos_queue_peek_from_isr_failed: tstamp:3376753615 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 101.985963: rtos_queue_peek_from_isr_failed: tstamp:3381753617 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 102.153989: rtos_queue_peek_from_isr_failed: tstamp:3386753618 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 102.322000: rtos_queue_peek_from_isr_failed: tstamp:3391753617 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 102.434008: rtos_queue_peek_from_isr_failed: tstamp:3396753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 102.602052: rtos_queue_peek_from_isr_failed: tstamp:3401753610 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 102.770044: rtos_queue_peek_from_isr_failed: tstamp:3406753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 102.938081: rtos_queue_peek_from_isr_failed: tstamp:3411753615 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 103.106119: rtos_queue_peek_from_isr_failed: tstamp:3416753619 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 103.274095: rtos_queue_peek_from_isr_failed: tstamp:3421753617 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 103.386114: rtos_queue_peek_from_isr_failed: tstamp:3425981889 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 135.531246: rtos_queue_send_from_isr_failed: tstamp:4430939249 queue:0x0bcb41f8
kworker/0:2-1169 [000] .... 135.531254: rtos_queue_send_from_isr_failed: tstamp:4430941775 queue:0x0bcb8a60
kworker/0:2-1169 [000] .... 135.531255: rtos_queue_send_from_isr_failed: tstamp:4430944269 queue:0x0bcba5e0
kworker/0:2-1169 [000] .... 135.531257: rtos_queue_send_from_isr_failed: tstamp:4430946749 queue:0x0bcbb3a0
kworker/0:2-1169 [000] .... 135.531258: rtos_queue_send_from_isr_failed: tstamp:4430949204 queue:0x0bcbc160
kworker/0:2-1169 [000] .... 135.531263: rtcpu_nvcsi_intr: tstamp:4430973748 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000089
kworker/0:2-1169 [000] .... 135.531264: rtcpu_nvcsi_intr: tstamp:4430973748 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/0:2-1169 [000] .... 135.531267: rtos_queue_peek_from_isr_failed: tstamp:4431103040 queue:0x0bcbcf78
kworker/0:2-1169 [000] .... 135.531270: rtcpu_start: tstamp:4431105293
kworker/0:2-1169 [000] .... 135.531306: rtos_queue_send_from_isr_failed: tstamp:4431116062 queue:0x0bcb41f8
kworker/0:2-1169 [000] .... 135.531308: rtos_queue_send_from_isr_failed: tstamp:4431116246 queue:0x0bcb8a60
kworker/0:2-1169 [000] .... 135.531309: rtos_queue_send_from_isr_failed: tstamp:4431116407 queue:0x0bcba5e0
kworker/0:2-1169 [000] .... 135.531311: rtos_queue_send_from_isr_failed: tstamp:4431116565 queue:0x0bcbb3a0
kworker/0:2-1169 [000] .... 135.531312: rtos_queue_send_from_isr_failed: tstamp:4431116722 queue:0x0bcbc160
kworker/0:2-1169 [000] .... 135.531315: rtcpu_string: tstamp:4431117216 id:0x04010000 str:"Configuring VI GoS.
kworker/0:2-1169 [000] … 135.531330: rtcpu_string: tstamp:4431117408 id:0x04010000 str:"VM GOS[#0 ] addr=0xe4900000
kworker/0:2-1169 [000] … 135.531336: rtcpu_string: tstamp:4431117676 id:0x04010000 str:"VM GOS[#1 ] addr=0xe4901000
kworker/0:2-1169 [000] … 135.531341: rtcpu_string: tstamp:4431117976 id:0x04010000 str:"VM GOS[#2 ] addr=0xe4902000
kworker/0:2-1169 [000] … 135.531346: rtcpu_string: tstamp:4431118218 id:0x04010000 str:"VM GOS[#3 ] addr=0xe4903000
kworker/0:2-1169 [000] … 135.531351: rtcpu_string: tstamp:4431118461 id:0x04010000 str:"VM GOS[#4 ] addr=0xe4904000
kworker/0:2-1169 [000] … 135.531355: rtcpu_string: tstamp:4431118702 id:0x04010000 str:"VM GOS[#5 ] addr=0xe4905000
kworker/0:2-1169 [000] … 135.531360: rtcpu_string: tstamp:4431134089 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol versi”
kworker/0:2-1169 [000] … 135.531362: rtcpu_string: tstamp:4431134218 id:0x04010000 str:"on 2.2
kworker/0:2-1169 [000] … 135.531367: rtos_queue_send_from_isr_failed: tstamp:4431158078 queue:0x0bcb41f8
kworker/0:2-1169 [000] … 135.531369: rtos_queue_send_from_isr_failed: tstamp:4431158265 queue:0x0bcb8a60
kworker/0:2-1169 [000] … 135.531370: rtos_queue_send_from_isr_failed: tstamp:4431158431 queue:0x0bcba5e0
kworker/0:2-1169 [000] … 135.531398: rtos_queue_send_from_isr_failed: tstamp:4431158587 queue:0x0bcbb3a0
kworker/0:2-1169 [000] … 135.531400: rtos_queue_send_from_isr_failed: tstamp:4431158742 queue:0x0bcbc160
kworker/0:2-1169 [000] … 135.531401: rtcpu_string: tstamp:4431159669 id:0x04010000 str:"VI GOS[#0 ] set to VM GOS[4] base 0xe4904000
kworker/0:2-1169 [000] … 135.531408: rtcpu_vinotify_error: tstamp:4431164860 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:4431160534 data:0x00000001
kworker/0:2-1169 [000] … 135.587221: rtcpu_vinotify_event: tstamp:4431678619 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:4431160534 data:0x00000001
kworker/0:2-1169 [000] … 135.587226: rtcpu_vinotify_event: tstamp:4431678775 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4358340864 data:0x10000000
kworker/0:2-1169 [000] … 135.587227: rtcpu_vinotify_event: tstamp:4431678974 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4358381312 data:0x31000001
kworker/0:2-1169 [000] … 135.587229: rtcpu_vinotify_event: tstamp:4431679125 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4358391392 data:0x10000000
kworker/0:2-1169 [000] … 135.587230: rtcpu_vinotify_event: tstamp:4431679314 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4358399808 data:0x07020001
kworker/0:2-1169 [000] … 135.587231: rtcpu_vinotify_event: tstamp:4431679459 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4358430272 data:0x31000002
kworker/0:2-1169 [000] … 135.587234: rtcpu_vinotify_error: tstamp:4432018344 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4432015490 data:0x00000489
kworker/0:2-1169 [000] … 135.587235: rtcpu_vinotify_event: tstamp:4432221056 tag:FS channel:0x00 frame:0 vi_tstamp:4431982748 data:0x00000010
kworker/0:2-1169 [000] … 135.587237: rtcpu_vinotify_event: tstamp:4432221206 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:4431982750 data:0x00000000
kworker/0:2-1169 [000] … 135.587238: rtcpu_vinotify_event: tstamp:4432221377 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4432015490 data:0x00000489
kworker/0:2-1169 [000] … 135.587242: rtos_queue_send_from_isr_failed: tstamp:4432756342 queue:0x0bcb41f8
kworker/0:2-1169 [000] … 135.587244: rtos_queue_send_from_isr_failed: tstamp:4432756507 queue:0x0bcb8a60
kworker/0:2-1169 [000] … 135.587245: rtos_queue_send_from_isr_failed: tstamp:4432756692 queue:0x0bcba5e0
kworker/0:2-1169 [000] … 135.587246: rtos_queue_send_from_isr_failed: tstamp:4432756849 queue:0x0bcbb3a0
kworker/0:2-1169 [000] … 135.587248: rtos_queue_send_from_isr_failed: tstamp:4432757005 queue:0x0bcbc160
kworker/0:2-1169 [000] … 135.587249: rtcpu_vinotify_event: tstamp:4432763667 tag:FE channel:0x00 frame:0 vi_tstamp:4432739757 data:0x00000020
kworker/0:2-1169 [000] … 135.587250: rtcpu_vinotify_event: tstamp:4432763842 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4432739757 data:0x01000000
kworker/0:2-1169 [000] … 135.587286: rtcpu_vinotify_event: tstamp:4432763994 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4408736384 data:0x01020001
kworker/0:2-1169 [000] … 135.587288: rtcpu_vinotify_event: tstamp:4432764168 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4432739759 data:0x00000000
kworker/0:2-1169 [000] … 135.643247: rtcpu_vinotify_error: tstamp:4433060267 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4433057246 data:0x00000489
kworker/0:2-1169 [000] … 135.643251: rtcpu_vinotify_event: tstamp:4433060808 tag:FS channel:0x00 frame:0 vi_tstamp:4433024504 data:0x00000010
kworker/0:2-1169 [000] … 135.643253: rtcpu_vinotify_event: tstamp:4433060984 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:4433024506 data:0x00000000
kworker/0:2-1169 [000] … 135.643255: rtcpu_vinotify_event: tstamp:4433061133 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4433057246 data:0x00000489
kworker/0:2-1169 [000] … 135.643256: rtcpu_vinotify_event: tstamp:4433795140 tag:FE channel:0x00 frame:0 vi_tstamp:4433781512 data:0x00000020
kworker/0:2-1169 [000] … 135.643257: rtcpu_vinotify_event: tstamp:4433795289 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:4433781513 data:0x01000000
kworker/0:2-1169 [000] … 135.643259: rtcpu_vinotify_event: tstamp:4433795482 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4442072608 data:0x01020001
kworker/0:2-1169 [000] … 135.643260: rtcpu_vinotify_event: tstamp:4433795634 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:4433781516 data:0x00000000
kworker/0:2-1169 [000] … 135.643288: rtcpu_vinotify_error: tstamp:4434101848 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4434099002 data:0x00000489
kworker/0:2-1169 [000] … 135.643289: rtcpu_vinotify_event: tstamp:4434337304 tag:FS channel:0x00 frame:0 vi_tstamp:4434066259 data:0x00000010
kworker/0:2-1169 [000] … 135.643291: rtcpu_vinotify_event: tstamp:4434337450 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4434099002 data:0x00000489
kworker/0:2-1169 [000] … 135.699205: rtcpu_vinotify_event: tstamp:4434880083 tag:FE channel:0x00 frame:0 vi_tstamp:4434823268 data:0x00000020
kworker/0:2-1169 [000] … 135.699242: rtcpu_vinotify_error: tstamp:4435143600 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4435140759 data:0x00000489
kworker/0:2-1169 [000] … 135.699244: rtcpu_vinotify_event: tstamp:4435422216 tag:FS channel:0x00 frame:0 vi_tstamp:4435108015 data:0x00000010
kworker/0:2-1169 [000] … 135.699246: rtcpu_vinotify_event: tstamp:4435422424 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4435140759 data:0x00000489
kworker/0:2-1169 [000] … 135.699247: rtcpu_vinotify_event: tstamp:4435965022 tag:FE channel:0x00 frame:0 vi_tstamp:4435865025 data:0x00000020
kworker/0:2-1169 [000] … 135.699252: rtos_queue_peek_from_isr_failed: tstamp:4436103441 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 135.699254: rtcpu_vinotify_error: tstamp:4436185406 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4436182515 data:0x00000489
kworker/0:2-1169 [000] … 135.699255: rtcpu_vinotify_event: tstamp:4436507159 tag:FS channel:0x00 frame:0 vi_tstamp:4436149772 data:0x00000010
kworker/0:2-1169 [000] … 135.699259: rtcpu_vinotify_event: tstamp:4436507306 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4436182515 data:0x00000489
kworker/0:2-1169 [000] … 135.755242: rtcpu_vinotify_event: tstamp:4437049972 tag:FE channel:0x00 frame:0 vi_tstamp:4436906781 data:0x00000020
kworker/0:2-1169 [000] … 135.755247: rtcpu_vinotify_error: tstamp:4437227115 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4437224271 data:0x00000489
kworker/0:2-1169 [000] … 135.755249: rtcpu_vinotify_event: tstamp:4437592971 tag:FS channel:0x00 frame:0 vi_tstamp:4437191529 data:0x00000010
kworker/0:2-1169 [000] … 135.755251: rtcpu_vinotify_event: tstamp:4437593142 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4437224271 data:0x00000489
kworker/0:2-1169 [000] … 135.755252: rtcpu_vinotify_event: tstamp:4437951018 tag:FE channel:0x00 frame:0 vi_tstamp:4437948537 data:0x00000020
kworker/0:2-1169 [000] … 135.811293: rtcpu_vinotify_error: tstamp:4438268881 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4438266027 data:0x00000489
kworker/0:2-1169 [000] … 135.811297: rtcpu_vinotify_event: tstamp:4438460310 tag:FS channel:0x00 frame:0 vi_tstamp:4438233284 data:0x00000010
kworker/0:2-1169 [000] … 135.811299: rtcpu_vinotify_event: tstamp:4438460455 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4438266027 data:0x00000489
kworker/0:2-1169 [000] … 135.811300: rtcpu_vinotify_event: tstamp:4439003121 tag:FE channel:0x00 frame:0 vi_tstamp:4438990293 data:0x00000020
kworker/0:2-1169 [000] … 135.811334: rtcpu_vinotify_error: tstamp:4439310673 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4439307783 data:0x00000489
kworker/0:2-1169 [000] … 135.811335: rtcpu_vinotify_event: tstamp:4439546057 tag:FS channel:0x00 frame:0 vi_tstamp:4439275040 data:0x00000010
kworker/0:2-1169 [000] … 135.811337: rtcpu_vinotify_event: tstamp:4439546228 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4439307783 data:0x00000489
kworker/0:2-1169 [000] … 135.867223: rtcpu_vinotify_event: tstamp:4440088065 tag:FE channel:0x00 frame:0 vi_tstamp:4440032049 data:0x00000020
kworker/0:2-1169 [000] … 135.867226: rtcpu_vinotify_error: tstamp:4440352385 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4440349540 data:0x00000489
kworker/0:2-1169 [000] … 135.867227: rtcpu_vinotify_event: tstamp:4440631001 tag:FS channel:0x00 frame:0 vi_tstamp:4440316796 data:0x00000010
kworker/0:2-1169 [000] … 135.867229: rtcpu_vinotify_event: tstamp:4440631146 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4440349540 data:0x00000489
kworker/0:2-1169 [000] … 135.867262: rtos_queue_peek_from_isr_failed: tstamp:4441103444 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 135.867263: rtcpu_vinotify_event: tstamp:4441173010 tag:FE channel:0x00 frame:0 vi_tstamp:4441073805 data:0x00000020
kworker/0:2-1169 [000] … 135.867265: rtcpu_vinotify_error: tstamp:4441394136 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4441391295 data:0x00000489
kworker/0:2-1169 [000] … 135.867267: rtcpu_vinotify_event: tstamp:4441715940 tag:FS channel:0x00 frame:0 vi_tstamp:4441358552 data:0x00000010
kworker/0:2-1169 [000] … 135.867268: rtcpu_vinotify_event: tstamp:4441716111 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4441391295 data:0x00000489
kworker/0:2-1169 [000] … 135.923278: rtcpu_vinotify_event: tstamp:4442258754 tag:FE channel:0x00 frame:0 vi_tstamp:4442115561 data:0x00000020
kworker/0:2-1169 [000] … 135.923282: rtcpu_vinotify_error: tstamp:4442435939 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4442433051 data:0x00000489
kworker/0:2-1169 [000] … 135.923284: rtcpu_vinotify_event: tstamp:4442800886 tag:FS channel:0x00 frame:0 vi_tstamp:4442400309 data:0x00000010
kworker/0:2-1169 [000] … 135.923286: rtcpu_vinotify_event: tstamp:4442801032 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4442433051 data:0x00000489
kworker/0:2-1169 [000] … 135.923287: rtcpu_vinotify_event: tstamp:4443343696 tag:FE channel:0x00 frame:0 vi_tstamp:4443157317 data:0x00000020
kworker/0:2-1169 [000] … 135.923288: rtcpu_vinotify_event: tstamp:4443444546 tag:FS channel:0x00 frame:0 vi_tstamp:4443442065 data:0x00000010
kworker/0:2-1169 [000] … 135.923290: rtcpu_vinotify_error: tstamp:4443477649 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4443474807 data:0x00000489
kworker/0:2-1169 [000] … 135.979244: rtcpu_vinotify_event: tstamp:4443940268 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4443474807 data:0x00000489
kworker/0:2-1169 [000] … 135.979248: rtcpu_vinotify_event: tstamp:4444483081 tag:FE channel:0x00 frame:0 vi_tstamp:4444199073 data:0x00000020
kworker/0:2-1169 [000] … 135.979250: rtcpu_vinotify_error: tstamp:4444519410 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4444516564 data:0x00000489
kworker/0:2-1169 [000] … 135.979251: rtcpu_vinotify_event: tstamp:4445025217 tag:FS channel:0x00 frame:0 vi_tstamp:4444483820 data:0x00000010
kworker/0:2-1169 [000] … 135.979253: rtcpu_vinotify_event: tstamp:4445025363 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4444516564 data:0x00000489
kworker/0:2-1169 [000] … 136.035213: rtcpu_vinotify_error: tstamp:4445561181 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4445558320 data:0x00000489
kworker/0:2-1169 [000] … 136.035217: rtcpu_vinotify_event: tstamp:4445568212 tag:FE channel:0x00 frame:0 vi_tstamp:4445240829 data:0x00000020
kworker/0:2-1169 [000] … 136.035219: rtcpu_vinotify_event: tstamp:4445568357 tag:FS channel:0x00 frame:0 vi_tstamp:4445525576 data:0x00000010
kworker/0:2-1169 [000] … 136.035258: rtcpu_vinotify_event: tstamp:4445568526 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4445558320 data:0x00000489
kworker/0:2-1169 [000] … 136.035264: rtos_queue_peek_from_isr_failed: tstamp:4446103448 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 136.035265: rtcpu_vinotify_error: tstamp:4446602924 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4446600076 data:0x00000489
kworker/0:2-1169 [000] … 136.035267: rtcpu_vinotify_event: tstamp:4446653204 tag:FE channel:0x00 frame:0 vi_tstamp:4446282586 data:0x00000020
kworker/0:2-1169 [000] … 136.035268: rtcpu_vinotify_event: tstamp:4446653377 tag:FS channel:0x00 frame:0 vi_tstamp:4446567333 data:0x00000010
kworker/0:2-1169 [000] … 136.035270: rtcpu_vinotify_event: tstamp:4446653527 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4446600076 data:0x00000489
kworker/0:2-1169 [000] … 136.091214: rtcpu_vinotify_error: tstamp:4447644675 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4447641832 data:0x00000489
kworker/0:2-1169 [000] … 136.091218: rtcpu_vinotify_event: tstamp:4447738152 tag:FE channel:0x00 frame:0 vi_tstamp:4447324342 data:0x00000020
kworker/0:2-1169 [000] … 136.091220: rtcpu_vinotify_event: tstamp:4447738300 tag:FS channel:0x00 frame:0 vi_tstamp:4447609089 data:0x00000010
kworker/0:2-1169 [000] … 136.091221: rtcpu_vinotify_event: tstamp:4447738511 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4447641832 data:0x00000489
kworker/0:2-1169 [000] … 136.091222: rtcpu_vinotify_error: tstamp:4448686626 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4448683588 data:0x00000489
kworker/0:2-1169 [000] … 136.091224: rtcpu_vinotify_event: tstamp:4448687067 tag:FE channel:0x00 frame:0 vi_tstamp:4448366098 data:0x00000020
kworker/0:2-1169 [000] … 136.091225: rtcpu_vinotify_event: tstamp:4448687238 tag:FS channel:0x00 frame:0 vi_tstamp:4448650845 data:0x00000010
kworker/0:2-1169 [000] … 136.091226: rtcpu_vinotify_event: tstamp:4448687383 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4448683588 data:0x00000489
kworker/0:2-1169 [000] … 136.147210: rtcpu_vinotify_event: tstamp:4449419898 tag:FE channel:0x00 frame:0 vi_tstamp:4449407854 data:0x00000020
kworker/0:2-1169 [000] … 136.147212: rtcpu_vinotify_error: tstamp:4449728189 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4449725344 data:0x00000489
kworker/0:2-1169 [000] … 136.147213: rtcpu_vinotify_event: tstamp:4449962833 tag:FS channel:0x00 frame:0 vi_tstamp:4449692601 data:0x00000010
kworker/0:2-1169 [000] … 136.147215: rtcpu_vinotify_event: tstamp:4449963023 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4449725344 data:0x00000489
kworker/0:2-1169 [000] … 136.147216: rtcpu_vinotify_event: tstamp:4450504834 tag:FE channel:0x00 frame:0 vi_tstamp:4450449610 data:0x00000020
kworker/0:2-1169 [000] … 136.203211: rtcpu_vinotify_error: tstamp:4450769942 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4450767100 data:0x00000489
kworker/0:2-1169 [000] … 136.203213: rtcpu_vinotify_event: tstamp:4451047775 tag:FS channel:0x00 frame:0 vi_tstamp:4450734356 data:0x00000010
kworker/0:2-1169 [000] … 136.203215: rtcpu_vinotify_event: tstamp:4451047920 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4450767100 data:0x00000489
kworker/0:2-1169 [000] … 136.203244: rtos_queue_peek_from_isr_failed: tstamp:4451103443 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 136.203246: rtcpu_vinotify_event: tstamp:4451589786 tag:FE channel:0x00 frame:0 vi_tstamp:4451491366 data:0x00000020
kworker/0:2-1169 [000] … 136.203247: rtcpu_vinotify_error: tstamp:4451811751 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4451808856 data:0x00000489
kworker/0:2-1169 [000] … 136.203249: rtcpu_vinotify_event: tstamp:4452132719 tag:FS channel:0x00 frame:0 vi_tstamp:4451776113 data:0x00000010
kworker/0:2-1169 [000] … 136.203250: rtcpu_vinotify_event: tstamp:4452132890 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4451808856 data:0x00000489
kworker/0:2-1169 [000] … 136.259214: rtcpu_vinotify_event: tstamp:4452675525 tag:FE channel:0x00 frame:0 vi_tstamp:4452533122 data:0x00000020
kworker/0:2-1169 [000] … 136.259216: rtcpu_vinotify_error: tstamp:4452853453 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4452850611 data:0x00000489
kworker/0:2-1169 [000] … 136.259217: rtcpu_vinotify_event: tstamp:4453217711 tag:FS channel:0x00 frame:0 vi_tstamp:4452817869 data:0x00000010
kworker/0:2-1169 [000] … 136.259219: rtcpu_vinotify_event: tstamp:4453217859 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4452850611 data:0x00000489
kworker/0:2-1169 [000] … 136.259220: rtcpu_vinotify_event: tstamp:4453760466 tag:FE channel:0x00 frame:0 vi_tstamp:4453574878 data:0x00000020
kworker/0:2-1169 [000] … 136.259221: rtcpu_vinotify_error: tstamp:4453895206 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4453892368 data:0x00000489
kworker/0:2-1169 [000] … 136.315222: rtcpu_vinotify_event: tstamp:4454302600 tag:FS channel:0x00 frame:0 vi_tstamp:4453859625 data:0x00000010
kworker/0:2-1169 [000] … 136.315224: rtcpu_vinotify_event: tstamp:4454302776 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4453892368 data:0x00000489
kworker/0:2-1169 [000] … 136.315226: rtcpu_vinotify_event: tstamp:4454619109 tag:FE channel:0x00 frame:0 vi_tstamp:4454616634 data:0x00000020
kworker/0:2-1169 [000] … 136.315227: rtcpu_vinotify_error: tstamp:4454937015 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4454934125 data:0x00000489
kworker/0:2-1169 [000] … 136.315229: rtcpu_vinotify_event: tstamp:4455116810 tag:FS channel:0x00 frame:0 vi_tstamp:4454901381 data:0x00000010
kworker/0:2-1169 [000] … 136.315230: rtcpu_vinotify_event: tstamp:4455116994 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4454934125 data:0x00000489
kworker/0:2-1169 [000] … 136.371213: rtcpu_vinotify_error: tstamp:4455978723 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4455975881 data:0x00000489
kworker/0:2-1169 [000] … 136.371216: rtos_queue_peek_from_isr_failed: tstamp:4456103440 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 136.371218: rtcpu_vinotify_event: tstamp:4456201718 tag:FE channel:0x00 frame:0 vi_tstamp:4455658391 data:0x00000020
kworker/0:2-1169 [000] … 136.371219: rtcpu_vinotify_event: tstamp:4456201866 tag:FS channel:0x00 frame:0 vi_tstamp:4455943137 data:0x00000010
kworker/0:2-1169 [000] … 136.371258: rtcpu_vinotify_event: tstamp:4456202055 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4455975881 data:0x00000489
kworker/0:2-1169 [000] … 136.371259: rtcpu_vinotify_event: tstamp:4456744529 tag:FE channel:0x00 frame:0 vi_tstamp:4456700146 data:0x00000020
kworker/0:2-1169 [000] … 136.371261: rtcpu_vinotify_error: tstamp:4457020473 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4457017636 data:0x00000489
kworker/0:2-1169 [000] … 136.371262: rtcpu_vinotify_event: tstamp:4457286665 tag:FS channel:0x00 frame:0 vi_tstamp:4456984894 data:0x00000010
kworker/0:2-1169 [000] … 136.371263: rtcpu_vinotify_event: tstamp:4457286810 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4457017636 data:0x00000489
kworker/0:2-1169 [000] … 136.427232: rtcpu_vinotify_event: tstamp:4457829476 tag:FE channel:0x00 frame:0 vi_tstamp:4457741902 data:0x00000020
kworker/0:2-1169 [000] … 136.427236: rtcpu_vinotify_error: tstamp:4458062286 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4458059392 data:0x00000489
kworker/0:2-1169 [000] … 136.427237: rtcpu_vinotify_event: tstamp:4458371620 tag:FS channel:0x00 frame:0 vi_tstamp:4458026649 data:0x00000010
kworker/0:2-1169 [000] … 136.427240: rtcpu_vinotify_event: tstamp:4458371792 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4458059392 data:0x00000489
kworker/0:2-1169 [000] … 136.427241: rtcpu_vinotify_event: tstamp:4458914428 tag:FE channel:0x00 frame:0 vi_tstamp:4458783658 data:0x00000020
kworker/0:2-1169 [000] … 136.427242: rtcpu_vinotify_error: tstamp:4459104012 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4459101148 data:0x00000489
kworker/0:2-1169 [000] … 136.483221: rtcpu_vinotify_event: tstamp:4459456565 tag:FS channel:0x00 frame:0 vi_tstamp:4459068405 data:0x00000010
kworker/0:2-1169 [000] … 136.483223: rtcpu_vinotify_event: tstamp:4459456718 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4459101148 data:0x00000489
kworker/0:2-1169 [000] … 136.483224: rtcpu_vinotify_event: tstamp:4459999379 tag:FE channel:0x00 frame:0 vi_tstamp:4459825414 data:0x00000020
kworker/0:2-1169 [000] … 136.483228: rtcpu_vinotify_event: tstamp:4460112640 tag:FS channel:0x00 frame:0 vi_tstamp:4460110161 data:0x00000010
kworker/0:2-1169 [000] … 136.483230: rtcpu_vinotify_error: tstamp:4460145740 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4460142905 data:0x00000489
kworker/0:2-1169 [000] … 136.483231: rtcpu_vinotify_event: tstamp:4460650735 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4460142905 data:0x00000489
kworker/0:2-1169 [000] … 136.539221: rtos_queue_peek_from_isr_failed: tstamp:4461103440 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 136.539224: rtcpu_vinotify_error: tstamp:4461187509 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4461184660 data:0x00000489
kworker/0:2-1169 [000] … 136.539226: rtcpu_vinotify_event: tstamp:4461192968 tag:FE channel:0x00 frame:0 vi_tstamp:4460867171 data:0x00000020
kworker/0:2-1169 [000] … 136.539227: rtcpu_vinotify_event: tstamp:4461193141 tag:FS channel:0x00 frame:0 vi_tstamp:4461151918 data:0x00000010
kworker/0:2-1169 [000] … 136.539229: rtcpu_vinotify_event: tstamp:4461193287 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4461184660 data:0x00000489
kworker/0:2-1169 [000] … 136.539230: rtcpu_vinotify_error: tstamp:4462229257 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4462226416 data:0x00000489
kworker/0:2-1169 [000] … 136.539232: rtcpu_vinotify_event: tstamp:4462277912 tag:FE channel:0x00 frame:0 vi_tstamp:4461908927 data:0x00000020
kworker/0:2-1169 [000] … 136.539233: rtcpu_vinotify_event: tstamp:4462278059 tag:FS channel:0x00 frame:0 vi_tstamp:4462193674 data:0x00000010
kworker/0:2-1169 [000] … 136.539264: rtcpu_vinotify_event: tstamp:4462278247 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4462226416 data:0x00000489
kworker/0:2-1169 [000] … 136.595247: rtcpu_vinotify_error: tstamp:4463271023 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4463268172 data:0x00000489
kworker/0:2-1169 [000] … 136.595254: rtcpu_vinotify_event: tstamp:4463362861 tag:FE channel:0x00 frame:0 vi_tstamp:4462950683 data:0x00000020
kworker/0:2-1169 [000] … 136.595256: rtcpu_vinotify_event: tstamp:4463363033 tag:FS channel:0x00 frame:0 vi_tstamp:4463235430 data:0x00000010
kworker/0:2-1169 [000] … 136.595258: rtcpu_vinotify_event: tstamp:4463363180 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4463268172 data:0x00000489
kworker/0:2-1169 [000] … 136.595259: rtcpu_vinotify_error: tstamp:4464312774 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4464309929 data:0x00000489
kworker/0:2-1169 [000] … 136.595260: rtcpu_vinotify_event: tstamp:4464448606 tag:FE channel:0x00 frame:0 vi_tstamp:4463992438 data:0x00000020
kworker/0:2-1169 [000] … 136.595262: rtcpu_vinotify_event: tstamp:4464448754 tag:FS channel:0x00 frame:0 vi_tstamp:4464277185 data:0x00000010
kworker/0:2-1169 [000] … 136.595263: rtcpu_vinotify_event: tstamp:4464448941 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4464309929 data:0x00000489
kworker/0:2-1169 [000] … 136.651279: rtcpu_vinotify_error: tstamp:4465354664 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4465351685 data:0x00000489
kworker/0:2-1169 [000] … 136.651284: rtcpu_vinotify_event: tstamp:4465355101 tag:FE channel:0x00 frame:0 vi_tstamp:4465034195 data:0x00000020
kworker/0:2-1169 [000] … 136.651320: rtcpu_vinotify_event: tstamp:4465355275 tag:FS channel:0x00 frame:0 vi_tstamp:4465318941 data:0x00000010
kworker/0:2-1169 [000] … 136.651321: rtcpu_vinotify_event: tstamp:4465355419 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4465351685 data:0x00000489
kworker/0:2-1169 [000] … 136.651325: rtos_queue_peek_from_isr_failed: tstamp:4466103439 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 136.651327: rtcpu_vinotify_event: tstamp:4466130419 tag:FE channel:0x00 frame:0 vi_tstamp:4466075951 data:0x00000020
kworker/0:2-1169 [000] … 136.707279: rtcpu_vinotify_error: tstamp:4466396280 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4466393440 data:0x00000489
kworker/0:2-1169 [000] … 136.707282: rtcpu_vinotify_event: tstamp:4466672547 tag:FS channel:0x00 frame:0 vi_tstamp:4466360698 data:0x00000010
kworker/0:2-1169 [000] … 136.707284: rtcpu_vinotify_event: tstamp:4466672718 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4466393440 data:0x00000489
kworker/0:2-1169 [000] … 136.707285: rtcpu_vinotify_event: tstamp:4467215363 tag:FE channel:0x00 frame:0 vi_tstamp:4467117707 data:0x00000020
kworker/0:2-1169 [000] … 136.707287: rtcpu_vinotify_error: tstamp:4467438042 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4467435196 data:0x00000489
kworker/0:2-1169 [000] … 136.707288: rtcpu_vinotify_event: tstamp:4467757503 tag:FS channel:0x00 frame:0 vi_tstamp:4467402454 data:0x00000010
kworker/0:2-1169 [000] … 136.707290: rtcpu_vinotify_event: tstamp:4467757667 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4467435196 data:0x00000489
kworker/0:2-1169 [000] … 136.763225: rtcpu_vinotify_event: tstamp:4468300319 tag:FE channel:0x00 frame:0 vi_tstamp:4468159463 data:0x00000020
kworker/0:2-1169 [000] … 136.763227: rtcpu_vinotify_error: tstamp:4468479791 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4468476953 data:0x00000489
kworker/0:2-1169 [000] … 136.763229: rtcpu_vinotify_event: tstamp:4468843255 tag:FS channel:0x00 frame:0 vi_tstamp:4468444210 data:0x00000010
kworker/0:2-1169 [000] … 136.763269: rtcpu_vinotify_event: tstamp:4468843427 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4468476953 data:0x00000489
kworker/0:2-1169 [000] … 136.763270: rtcpu_vinotify_event: tstamp:4469385254 tag:FE channel:0x00 frame:0 vi_tstamp:4469201218 data:0x00000020
kworker/0:2-1169 [000] … 136.763272: rtcpu_vinotify_error: tstamp:4469521551 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4469518709 data:0x00000489
kworker/0:2-1169 [000] … 136.819224: rtcpu_vinotify_event: tstamp:4469928174 tag:FS channel:0x00 frame:0 vi_tstamp:4469485966 data:0x00000010
kworker/0:2-1169 [000] … 136.819227: rtcpu_vinotify_event: tstamp:4469928344 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4469518709 data:0x00000489
kworker/0:2-1169 [000] … 136.819229: rtcpu_vinotify_event: tstamp:4470470197 tag:FE channel:0x00 frame:0 vi_tstamp:4470242975 data:0x00000020
kworker/0:2-1169 [000] … 136.819231: rtcpu_vinotify_error: tstamp:4470563307 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4470560465 data:0x00000489
kworker/0:2-1169 [000] … 136.819232: rtcpu_vinotify_event: tstamp:4471013134 tag:FS channel:0x00 frame:0 vi_tstamp:4470527722 data:0x00000010
kworker/0:2-1169 [000] … 136.819233: rtcpu_vinotify_event: tstamp:4471013305 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4470560465 data:0x00000489
kworker/0:2-1169 [000] … 136.819236: rtos_queue_peek_from_isr_failed: tstamp:4471103438 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 136.819238: rtcpu_vinotify_event: tstamp:4471287212 tag:FE channel:0x00 frame:0 vi_tstamp:4471284731 data:0x00000020
kworker/0:2-1169 [000] … 136.875233: rtcpu_vinotify_error: tstamp:4471605061 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4471602221 data:0x00000489
kworker/0:2-1169 [000] … 136.875236: rtcpu_vinotify_event: tstamp:4471826551 tag:FS channel:0x00 frame:0 vi_tstamp:4471569479 data:0x00000010
kworker/0:2-1169 [000] … 136.875238: rtcpu_vinotify_event: tstamp:4471826697 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4471602221 data:0x00000489
kworker/0:2-1169 [000] … 136.875239: rtcpu_vinotify_event: tstamp:4472369367 tag:FE channel:0x00 frame:0 vi_tstamp:4472326487 data:0x00000020
kworker/0:2-1169 [000] … 136.875241: rtcpu_vinotify_error: tstamp:4472646814 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4472643977 data:0x00000489
kworker/0:2-1169 [000] … 136.875242: rtcpu_vinotify_event: tstamp:4472911503 tag:FS channel:0x00 frame:0 vi_tstamp:4472611234 data:0x00000010
kworker/0:2-1169 [000] … 136.875243: rtcpu_vinotify_event: tstamp:4472911674 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4472643977 data:0x00000489
kworker/0:2-1169 [000] … 136.931223: rtcpu_vinotify_event: tstamp:4473454319 tag:FE channel:0x00 frame:0 vi_tstamp:4473368243 data:0x00000020
kworker/0:2-1169 [000] … 136.931226: rtcpu_vinotify_error: tstamp:4473688575 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4473685733 data:0x00000489
kworker/0:2-1169 [000] … 136.931228: rtcpu_vinotify_event: tstamp:4473997251 tag:FS channel:0x00 frame:0 vi_tstamp:4473652990 data:0x00000010
kworker/0:2-1169 [000] … 136.931229: rtcpu_vinotify_event: tstamp:4473997396 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4473685733 data:0x00000489
kworker/0:2-1169 [000] … 136.931231: rtcpu_vinotify_event: tstamp:4474539262 tag:FE channel:0x00 frame:0 vi_tstamp:4474409999 data:0x00000020
kworker/0:2-1169 [000] … 136.931232: rtcpu_vinotify_error: tstamp:4474730328 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4474727490 data:0x00000489
kworker/0:2-1169 [000] … 136.987222: rtcpu_vinotify_event: tstamp:4475082199 tag:FS channel:0x00 frame:0 vi_tstamp:4474694746 data:0x00000010
kworker/0:2-1169 [000] … 136.987252: rtcpu_vinotify_event: tstamp:4475082377 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4474727490 data:0x00000489
kworker/0:2-1169 [000] … 136.987253: rtcpu_vinotify_event: tstamp:4475624264 tag:FE channel:0x00 frame:0 vi_tstamp:4475451756 data:0x00000020
kworker/0:2-1169 [000] … 136.987255: rtcpu_vinotify_error: tstamp:4475772085 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4475769245 data:0x00000489
kworker/0:2-1169 [000] … 136.987257: rtos_queue_peek_from_isr_failed: tstamp:4476103439 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 136.987259: rtcpu_vinotify_event: tstamp:4476167146 tag:FS channel:0x00 frame:0 vi_tstamp:4475736502 data:0x00000010
kworker/0:2-1169 [000] … 136.987260: rtcpu_vinotify_event: tstamp:4476167294 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4475769245 data:0x00000489
kworker/0:2-1169 [000] … 136.987261: rtcpu_vinotify_event: tstamp:4476709952 tag:FE channel:0x00 frame:0 vi_tstamp:4476493511 data:0x00000020
kworker/0:2-1169 [000] … 137.043258: rtcpu_vinotify_event: tstamp:4476780743 tag:FS channel:0x00 frame:0 vi_tstamp:4476778259 data:0x00000010
kworker/0:2-1169 [000] … 137.043261: rtcpu_vinotify_error: tstamp:4476813841 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4476811001 data:0x00000489
kworker/0:2-1169 [000] … 137.043263: rtcpu_vinotify_event: tstamp:4477306530 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4476811001 data:0x00000489
kworker/0:2-1169 [000] … 137.043264: rtcpu_vinotify_event: tstamp:4477848637 tag:FE channel:0x00 frame:0 vi_tstamp:4477535267 data:0x00000020
kworker/0:2-1169 [000] … 137.043302: rtcpu_vinotify_event: tstamp:4477848825 tag:FS channel:0x00 frame:0 vi_tstamp:4477820014 data:0x00000010
kworker/0:2-1169 [000] … 137.043303: rtcpu_vinotify_error: tstamp:4477855585 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4477852757 data:0x00000489
kworker/0:2-1169 [000] … 137.043305: rtcpu_vinotify_event: tstamp:4478391472 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4477852757 data:0x00000489
kworker/0:2-1169 [000] … 137.099250: rtcpu_vinotify_error: tstamp:4478897356 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4478894514 data:0x00000489
kworker/0:2-1169 [000] … 137.099251: rtcpu_vinotify_event: tstamp:4478933711 tag:FE channel:0x00 frame:0 vi_tstamp:4478577023 data:0x00000020
kworker/0:2-1169 [000] … 137.099253: rtcpu_vinotify_event: tstamp:4478933858 tag:FS channel:0x00 frame:0 vi_tstamp:4478861770 data:0x00000010
kworker/0:2-1169 [000] … 137.099254: rtcpu_vinotify_event: tstamp:4478934047 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4478894514 data:0x00000489
kworker/0:2-1169 [000] … 137.099256: rtcpu_vinotify_error: tstamp:4479939112 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4479936269 data:0x00000489
kworker/0:2-1169 [000] … 137.099257: rtcpu_vinotify_event: tstamp:4480019436 tag:FE channel:0x00 frame:0 vi_tstamp:4479618779 data:0x00000020
kworker/0:2-1169 [000] … 137.099258: rtcpu_vinotify_event: tstamp:4480019607 tag:FS channel:0x00 frame:0 vi_tstamp:4479903526 data:0x00000010
kworker/0:2-1169 [000] … 137.099259: rtcpu_vinotify_event: tstamp:4480019755 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4479936269 data:0x00000489
kworker/0:2-1169 [000] … 137.155227: rtcpu_vinotify_error: tstamp:4480980864 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4480978025 data:0x00000489
kworker/0:2-1169 [000] … 137.155230: rtos_queue_peek_from_isr_failed: tstamp:4481103889 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 137.155232: rtcpu_vinotify_event: tstamp:4481104631 tag:FE channel:0x00 frame:0 vi_tstamp:4480660535 data:0x00000020
kworker/0:2-1169 [000] … 137.155234: rtcpu_vinotify_event: tstamp:4481104778 tag:FS channel:0x00 frame:0 vi_tstamp:4480945282 data:0x00000010
kworker/0:2-1169 [000] … 137.155235: rtcpu_vinotify_event: tstamp:4481104951 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4480978025 data:0x00000489
kworker/0:2-1169 [000] … 137.211233: rtcpu_vinotify_error: tstamp:4482022763 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4482019781 data:0x00000489
kworker/0:2-1169 [000] … 137.211236: rtcpu_vinotify_event: tstamp:4482023185 tag:FE channel:0x00 frame:0 vi_tstamp:4481702291 data:0x00000020
kworker/0:2-1169 [000] … 137.211238: rtcpu_vinotify_event: tstamp:4482023357 tag:FS channel:0x00 frame:0 vi_tstamp:4481987038 data:0x00000010
kworker/0:2-1169 [000] … 137.211239: rtcpu_vinotify_event: tstamp:4482023501 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4482019781 data:0x00000489
kworker/0:2-1169 [000] … 137.211240: rtcpu_vinotify_event: tstamp:4482786210 tag:FE channel:0x00 frame:0 vi_tstamp:4482744047 data:0x00000020
kworker/0:2-1169 [000] … 137.211242: rtcpu_vinotify_error: tstamp:4483064383 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4483061537 data:0x00000489
kworker/0:2-1169 [000] … 137.211245: rtcpu_vinotify_event: tstamp:4483328343 tag:FS channel:0x00 frame:0 vi_tstamp:4483028794 data:0x00000010
kworker/0:2-1169 [000] … 137.211247: rtcpu_vinotify_event: tstamp:4483328511 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4483061537 data:0x00000489
kworker/0:2-1169 [000] … 137.267223: rtcpu_vinotify_event: tstamp:4483871155 tag:FE channel:0x00 frame:0 vi_tstamp:4483785803 data:0x00000020
kworker/0:2-1169 [000] … 137.267226: rtcpu_vinotify_error: tstamp:4484106133 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4484103293 data:0x00000489
kworker/0:2-1169 [000] … 137.267227: rtcpu_vinotify_event: tstamp:4484414092 tag:FS channel:0x00 frame:0 vi_tstamp:4484070550 data:0x00000010
kworker/0:2-1169 [000] … 137.267228: rtcpu_vinotify_event: tstamp:4484414239 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4484103293 data:0x00000489
kworker/0:2-1169 [000] … 137.267230: rtcpu_vinotify_event: tstamp:4484956107 tag:FE channel:0x00 frame:0 vi_tstamp:4484827559 data:0x00000020
kworker/0:2-1169 [000] … 137.267231: rtcpu_vinotify_error: tstamp:4485147886 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4485145049 data:0x00000489
kworker/0:2-1169 [000] … 137.267233: rtcpu_vinotify_event: tstamp:4485499095 tag:FS channel:0x00 frame:0 vi_tstamp:4485112306 data:0x00000010
kworker/0:2-1169 [000] … 137.267234: rtcpu_vinotify_event: tstamp:4485499266 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4485145049 data:0x00000489
kworker/0:2-1169 [000] … 137.323231: rtcpu_vinotify_event: tstamp:4486041058 tag:FE channel:0x00 frame:0 vi_tstamp:4485869315 data:0x00000020
kworker/0:2-1169 [000] … 137.323234: rtos_queue_peek_from_isr_failed: tstamp:4486103443 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 137.323236: rtcpu_vinotify_error: tstamp:4486189649 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4486186805 data:0x00000489
kworker/0:2-1169 [000] … 137.323237: rtcpu_vinotify_event: tstamp:4486583991 tag:FS channel:0x00 frame:0 vi_tstamp:4486154062 data:0x00000010
kworker/0:2-1169 [000] … 137.323238: rtcpu_vinotify_event: tstamp:4486584139 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4486186805 data:0x00000489
kworker/0:2-1169 [000] … 137.323240: rtcpu_vinotify_event: tstamp:4487126802 tag:FE channel:0x00 frame:0 vi_tstamp:4486911071 data:0x00000020
kworker/0:2-1169 [000] … 137.323241: rtcpu_vinotify_error: tstamp:4487231404 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4487228561 data:0x00000489
kworker/0:2-1169 [000] … 137.379227: rtcpu_vinotify_event: tstamp:4487668939 tag:FS channel:0x00 frame:0 vi_tstamp:4487195818 data:0x00000010
kworker/0:2-1169 [000] … 137.379229: rtcpu_vinotify_event: tstamp:4487669134 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4487228561 data:0x00000489
kworker/0:2-1169 [000] … 137.379230: rtcpu_vinotify_event: tstamp:4487955306 tag:FE channel:0x00 frame:0 vi_tstamp:4487952827 data:0x00000020
kworker/0:2-1169 [000] … 137.379232: rtcpu_vinotify_error: tstamp:4488273154 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4488270317 data:0x00000489
kworker/0:2-1169 [000] … 137.379233: rtcpu_vinotify_event: tstamp:4488483156 tag:FS channel:0x00 frame:0 vi_tstamp:4488237574 data:0x00000010
kworker/0:2-1169 [000] … 137.379234: rtcpu_vinotify_event: tstamp:4488483301 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4488270317 data:0x00000489
kworker/0:2-1169 [000] … 137.435235: rtcpu_vinotify_event: tstamp:4489025132 tag:FE channel:0x00 frame:0 vi_tstamp:4488994583 data:0x00000020
kworker/0:2-1169 [000] … 137.435238: rtcpu_vinotify_error: tstamp:4489314912 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4489312074 data:0x00000489
kworker/0:2-1169 [000] … 137.435240: rtcpu_vinotify_event: tstamp:4489568103 tag:FS channel:0x00 frame:0 vi_tstamp:4489279330 data:0x00000010
kworker/0:2-1169 [000] … 137.435241: rtcpu_vinotify_event: tstamp:4489568291 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4489312074 data:0x00000489
kworker/0:2-1169 [000] … 137.435242: rtcpu_vinotify_event: tstamp:4490110110 tag:FE channel:0x00 frame:0 vi_tstamp:4490036340 data:0x00000020
kworker/0:2-1169 [000] … 137.435244: rtcpu_vinotify_error: tstamp:4490356668 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4490353829 data:0x00000489
kworker/0:2-1169 [000] … 137.435245: rtcpu_vinotify_event: tstamp:4490653043 tag:FS channel:0x00 frame:0 vi_tstamp:4490321087 data:0x00000010
kworker/0:2-1169 [000] … 137.435247: rtcpu_vinotify_event: tstamp:4490653190 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4490353829 data:0x00000489
kworker/0:2-1169 [000] … 137.491273: rtos_queue_peek_from_isr_failed: tstamp:4491103440 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 137.491279: rtcpu_vinotify_event: tstamp:4491195860 tag:FE channel:0x00 frame:0 vi_tstamp:4491078095 data:0x00000020
kworker/0:2-1169 [000] … 137.491281: rtcpu_vinotify_error: tstamp:4491398426 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4491395585 data:0x00000489
kworker/0:2-1169 [000] … 137.491283: rtcpu_vinotify_event: tstamp:4491737972 tag:FS channel:0x00 frame:0 vi_tstamp:4491362842 data:0x00000010
kworker/0:2-1169 [000] … 137.491284: rtcpu_vinotify_event: tstamp:4491738143 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4491395585 data:0x00000489
kworker/0:2-1169 [000] … 137.491285: rtcpu_vinotify_event: tstamp:4492280792 tag:FE channel:0x00 frame:0 vi_tstamp:4492119851 data:0x00000020
kworker/0:2-1169 [000] … 137.491287: rtcpu_vinotify_error: tstamp:4492440180 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4492437341 data:0x00000489
kworker/0:2-1169 [000] … 137.547260: rtcpu_vinotify_event: tstamp:4492822924 tag:FS channel:0x00 frame:0 vi_tstamp:4492404598 data:0x00000010
kworker/0:2-1169 [000] … 137.547264: rtcpu_vinotify_event: tstamp:4492823077 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4492437341 data:0x00000489
kworker/0:2-1169 [000] … 137.547266: rtcpu_vinotify_event: tstamp:4493365729 tag:FE channel:0x00 frame:0 vi_tstamp:4493161607 data:0x00000020
kworker/0:2-1169 [000] … 137.547267: rtcpu_vinotify_event: tstamp:4493448815 tag:FS channel:0x00 frame:0 vi_tstamp:4493446354 data:0x00000010
kworker/0:2-1169 [000] … 137.547269: rtcpu_vinotify_error: tstamp:4493481937 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4493479097 data:0x00000489
kworker/0:2-1169 [000] … 137.547270: rtcpu_vinotify_event: tstamp:4493962322 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4493479097 data:0x00000489
kworker/0:2-1169 [000] … 137.603233: rtcpu_vinotify_event: tstamp:4494505245 tag:FE channel:0x00 frame:0 vi_tstamp:4494203364 data:0x00000020
kworker/0:2-1169 [000] … 137.603236: rtcpu_vinotify_event: tstamp:4494505419 tag:FS channel:0x00 frame:0 vi_tstamp:4494488111 data:0x00000010
kworker/0:2-1169 [000] … 137.603237: rtcpu_vinotify_error: tstamp:4494523685 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4494520853 data:0x00000489
kworker/0:2-1169 [000] … 137.603239: rtcpu_vinotify_event: tstamp:4495047269 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4494520853 data:0x00000489
kworker/0:2-1169 [000] … 137.603269: rtcpu_vinotify_error: tstamp:4495565454 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4495562609 data:0x00000489
kworker/0:2-1169 [000] … 137.603271: rtcpu_vinotify_event: tstamp:4495590302 tag:FE channel:0x00 frame:0 vi_tstamp:4495245120 data:0x00000020
kworker/0:2-1169 [000] … 137.603273: rtcpu_vinotify_event: tstamp:4495590468 tag:FS channel:0x00 frame:0 vi_tstamp:4495529866 data:0x00000010
kworker/0:2-1169 [000] … 137.603274: rtcpu_vinotify_event: tstamp:4495590656 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4495562609 data:0x00000489
kworker/0:2-1169 [000] … 137.659239: rtos_queue_peek_from_isr_failed: tstamp:4496103441 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 137.659243: rtcpu_vinotify_error: tstamp:4496607201 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4496604365 data:0x00000489
kworker/0:2-1169 [000] … 137.659245: rtcpu_vinotify_event: tstamp:4496675253 tag:FE channel:0x00 frame:0 vi_tstamp:4496286875 data:0x00000020
kworker/0:2-1169 [000] … 137.659246: rtcpu_vinotify_event: tstamp:4496675425 tag:FS channel:0x00 frame:0 vi_tstamp:4496571622 data:0x00000010
kworker/0:2-1169 [000] … 137.659248: rtcpu_vinotify_event: tstamp:4496675575 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4496604365 data:0x00000489
kworker/0:2-1169 [000] … 137.659249: rtcpu_vinotify_error: tstamp:4497648961 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4497646122 data:0x00000489
kworker/0:2-1169 [000] … 137.659251: rtcpu_vinotify_event: tstamp:4497760205 tag:FE channel:0x00 frame:0 vi_tstamp:4497328631 data:0x00000020
kworker/0:2-1169 [000] … 137.659289: rtcpu_vinotify_event: tstamp:4497760350 tag:FS channel:0x00 frame:0 vi_tstamp:4497613378 data:0x00000010
kworker/0:2-1169 [000] … 137.659290: rtcpu_vinotify_event: tstamp:4497760537 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4497646122 data:0x00000489
kworker/0:2-1169 [000] … 137.715271: rtcpu_vinotify_error: tstamp:4498690857 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4498687878 data:0x00000489
kworker/0:2-1169 [000] … 137.715275: rtcpu_vinotify_event: tstamp:4498691294 tag:FE channel:0x00 frame:0 vi_tstamp:4498370388 data:0x00000020
kworker/0:2-1169 [000] … 137.715277: rtcpu_vinotify_event: tstamp:4498691465 tag:FS channel:0x00 frame:0 vi_tstamp:4498655134 data:0x00000010
kworker/0:2-1169 [000] … 137.715315: rtcpu_vinotify_event: tstamp:4498691612 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4498687878 data:0x00000489
kworker/0:2-1169 [000] … 137.715317: rtcpu_vinotify_event: tstamp:4499441971 tag:FE channel:0x00 frame:0 vi_tstamp:4499412144 data:0x00000020
kworker/0:2-1169 [000] … 137.771317: rtcpu_vinotify_error: tstamp:4499732469 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4499729633 data:0x00000489
kworker/0:2-1169 [000] … 137.771321: rtcpu_vinotify_event: tstamp:4499984908 tag:FS channel:0x00 frame:0 vi_tstamp:4499696891 data:0x00000010
kworker/0:2-1169 [000] … 137.771323: rtcpu_vinotify_event: tstamp:4499985078 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4499729633 data:0x00000489
kworker/0:2-1169 [000] … 137.771325: rtcpu_vinotify_event: tstamp:4500526919 tag:FE channel:0x00 frame:0 vi_tstamp:4500453900 data:0x00000020
kworker/0:2-1169 [000] … 137.771326: rtcpu_vinotify_error: tstamp:4500774231 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4500771389 data:0x00000489
kworker/0:2-1169 [000] … 137.771327: rtcpu_vinotify_event: tstamp:4501069860 tag:FS channel:0x00 frame:0 vi_tstamp:4500738646 data:0x00000010
kworker/0:2-1169 [000] … 137.771329: rtcpu_vinotify_event: tstamp:4501070004 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4500771389 data:0x00000489
kworker/0:2-1169 [000] … 137.771334: rtos_queue_peek_from_isr_failed: tstamp:4501103419 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 137.827261: rtcpu_vinotify_event: tstamp:4501612652 tag:FE channel:0x00 frame:0 vi_tstamp:4501495655 data:0x00000020
kworker/0:2-1169 [000] … 137.827266: rtcpu_vinotify_error: tstamp:4501815988 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4501813146 data:0x00000489
kworker/0:2-1169 [000] … 137.827268: rtcpu_vinotify_event: tstamp:4502154839 tag:FS channel:0x00 frame:0 vi_tstamp:4501780403 data:0x00000010
kworker/0:2-1169 [000] … 137.827269: rtcpu_vinotify_event: tstamp:4502155009 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4501813146 data:0x00000489
kworker/0:2-1169 [000] … 137.827270: rtcpu_vinotify_event: tstamp:4502697600 tag:FE channel:0x00 frame:0 vi_tstamp:4502537411 data:0x00000020
kworker/0:2-1169 [000] … 137.827272: rtcpu_vinotify_error: tstamp:4502857788 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4502854902 data:0x00000489
kworker/0:2-1169 [000] … 137.883263: rtcpu_vinotify_event: tstamp:4503239734 tag:FS channel:0x00 frame:0 vi_tstamp:4502822158 data:0x00000010
kworker/0:2-1169 [000] … 137.883268: rtcpu_vinotify_event: tstamp:4503239886 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4502854902 data:0x00000489
kworker/0:2-1169 [000] … 137.883269: rtcpu_vinotify_event: tstamp:4503782544 tag:FE channel:0x00 frame:0 vi_tstamp:4503579168 data:0x00000020
kworker/0:2-1169 [000] … 137.883271: rtcpu_vinotify_error: tstamp:4503899498 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4503896658 data:0x00000489
kworker/0:2-1169 [000] … 137.883272: rtcpu_vinotify_event: tstamp:4504324701 tag:FS channel:0x00 frame:0 vi_tstamp:4503863915 data:0x00000010
kworker/0:2-1169 [000] … 137.883274: rtcpu_vinotify_event: tstamp:4504324873 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4503896658 data:0x00000489
kworker/0:2-1169 [000] … 137.883275: rtcpu_vinotify_event: tstamp:4504623461 tag:FE channel:0x00 frame:0 vi_tstamp:4504620924 data:0x00000020
kworker/0:2-1169 [000] … 137.939240: rtcpu_vinotify_error: tstamp:4504941259 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4504938414 data:0x00000489
kworker/0:2-1169 [000] … 137.939243: rtcpu_vinotify_event: tstamp:4505138907 tag:FS channel:0x00 frame:0 vi_tstamp:4504905671 data:0x00000010
kworker/0:2-1169 [000] … 137.939244: rtcpu_vinotify_event: tstamp:4505139054 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4504938414 data:0x00000489
kworker/0:2-1169 [000] … 137.939245: rtcpu_vinotify_event: tstamp:4505680931 tag:FE channel:0x00 frame:0 vi_tstamp:4505662680 data:0x00000020
kworker/0:2-1169 [000] … 137.939247: rtcpu_vinotify_error: tstamp:4505983007 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4505980169 data:0x00000489
kworker/0:2-1169 [000] … 137.939251: rtos_queue_peek_from_isr_failed: tstamp:4506103438 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 137.939253: rtcpu_vinotify_event: tstamp:4506223868 tag:FS channel:0x00 frame:0 vi_tstamp:4505947427 data:0x00000010
kworker/0:2-1169 [000] … 137.939255: rtcpu_vinotify_event: tstamp:4506224039 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4505980169 data:0x00000489
kworker/0:2-1169 [000] … 137.995252: rtcpu_vinotify_event: tstamp:4506766681 tag:FE channel:0x00 frame:0 vi_tstamp:4506704435 data:0x00000020
kworker/0:2-1169 [000] … 137.995255: rtcpu_vinotify_error: tstamp:4507024769 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4507021926 data:0x00000489
kworker/0:2-1169 [000] … 137.995257: rtcpu_vinotify_event: tstamp:4507308811 tag:FS channel:0x00 frame:0 vi_tstamp:4506989182 data:0x00000010
kworker/0:2-1169 [000] … 137.995258: rtcpu_vinotify_event: tstamp:4507308974 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4507021926 data:0x00000489
kworker/0:2-1169 [000] … 137.995260: rtcpu_vinotify_event: tstamp:4507851617 tag:FE channel:0x00 frame:0 vi_tstamp:4507746192 data:0x00000020
kworker/0:2-1169 [000] … 137.995261: rtcpu_vinotify_error: tstamp:4508066543 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4508063682 data:0x00000489
kworker/0:2-1169 [000] … 138.051261: rtcpu_vinotify_event: tstamp:4508393755 tag:FS channel:0x00 frame:0 vi_tstamp:4508030939 data:0x00000010
kworker/0:2-1169 [000] … 138.051263: rtcpu_vinotify_event: tstamp:4508393932 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4508063682 data:0x00000489
kworker/0:2-1169 [000] … 138.051265: rtcpu_vinotify_event: tstamp:4508936621 tag:FE channel:0x00 frame:0 vi_tstamp:4508787948 data:0x00000020
kworker/0:2-1169 [000] … 138.051267: rtcpu_vinotify_error: tstamp:4509108278 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4509105438 data:0x00000489
kworker/0:2-1169 [000] … 138.051268: rtcpu_vinotify_event: tstamp:4509479502 tag:FS channel:0x00 frame:0 vi_tstamp:4509072695 data:0x00000010
kworker/0:2-1169 [000] … 138.051269: rtcpu_vinotify_event: tstamp:4509479668 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4509105438 data:0x00000489
kworker/0:2-1169 [000] … 138.107264: rtcpu_vinotify_event: tstamp:4510021494 tag:FE channel:0x00 frame:0 vi_tstamp:4509829704 data:0x00000020
kworker/0:2-1169 [000] … 138.107266: rtcpu_vinotify_event: tstamp:4510116931 tag:FS channel:0x00 frame:0 vi_tstamp:4510114451 data:0x00000010
kworker/0:2-1169 [000] … 138.107267: rtcpu_vinotify_error: tstamp:4510150033 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4510147193 data:0x00000489
kworker/0:2-1169 [000] … 138.107269: rtcpu_vinotify_event: tstamp:4510618081 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4510147193 data:0x00000489
kworker/0:2-1169 [000] … 138.107271: rtos_queue_peek_from_isr_failed: tstamp:4511103440 queue:0x0bcbcf78
kworker/0:2-1169 [000] … 138.107273: rtcpu_vinotify_event: tstamp:4511160999 tag:FE channel:0x00 frame:0 vi_tstamp:4510871460 data:0x00000020
kworker/0:2-1169 [000] … 138.107274: rtcpu_vinotify_event: tstamp:4511161172 tag:FS channel:0x00 frame:0 vi_tstamp:4511156207 data:0x00000010
kworker/0:2-1169 [000] … 138.107276: rtcpu_vinotify_error: tstamp:4511191787 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4511188950 data:0x00000489
kworker/0:2-1169 [000] … 138.107277: rtcpu_vinotify_event: tstamp:4511703829 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4511188950 data:0x00000489
kworker/0:2-1169 [000] … 138.163285: rtcpu_vinotify_error: tstamp:4512233545 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4512230706 data:0x00000489
kworker/0:2-1169 [000] … 138.163287: rtcpu_vinotify_event: tstamp:4512246067 tag:FE channel:0x00 frame:0 vi_tstamp:4511913216 data:0x00000020
kworker/0:2-1169 [000] … 138.163289: rtcpu_vinotify_event: tstamp:4512246215 tag:FS channel:0x00 frame:0 vi_tstamp:4512197962 data:0x00000010
kworker/0:2-1169 [000] … 138.163291: rtcpu_vinotify_event: tstamp:4512246403 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4512230706 data:0x00000489
kworker/0:2-1169 [000] … 138.163292: rtcpu_vinotify_error: tstamp:4513275304 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4513272462 data:0x00000489
kworker/0:2-1169 [000] … 138.163293: rtcpu_vinotify_event: tstamp:4513331019 tag:FE channel:0x00 frame:0 vi_tstamp:4512954972 data:0x00000020
kworker/0:2-1169 [000] … 138.163295: rtcpu_vinotify_event: tstamp:4513331210 tag:FS channel:0x00 frame:0 vi_tstamp:4513239719 data:0x00000010
kworker/0:2-1169 [000] … 138.163296: rtcpu_vinotify_event: tstamp:4513331356 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:4513272462 data:0x00000489
kworker/0:2-1169 [000] … 138.219330: rtos_queue_send_from_isr_failed: tstamp:4514034314 queue:0x0bcb41f8
kworker/0:2-1169 [000] … 138.219335: rtos_queue_send_from_isr_failed: tstamp:4514034479 queue:0x0bcb8a60
kworker/0:2-1169 [000] … 138.219337: rtos_queue_send_from_isr_failed: tstamp:4514034642 queue:0x0bcba5e0
kworker/0:2-1169 [000] … 138.219338: rtos_queue_send_from_isr_failed: tstamp:4514034799 queue:0x0bcbb3a0
kworker/0:2-1169 [000] … 138.219370: rtos_queue_send_from_isr_failed: tstamp:4514034955 queue:0x0bcbc160
kworker/0:2-1169 [000] … 138.219372: rtos_queue_send_from_isr_failed: tstamp:4514162597 queue:0x0bcb41f8
kworker/0:2-1169 [000] … 138.219374: rtos_queue_send_from_isr_failed: tstamp:4514162758 queue:0x0bcb8a60
kworker/0:2-1169 [000] … 138.219375: rtos_queue_send_from_isr_failed: tstamp:4514162918 queue:0x0bcba5e0
kworker/0:2-1169 [000] … 138.219377: rtos_queue_send_from_isr_failed: tstamp:4514163076 queue:0x0bcbb3a0
kworker/0:2-1169 [000] … 138.219378: rtos_queue_send_from_isr_failed: tstamp:4514163231 queue:0x0bcbc160
kworker/0:2-1169 [000] … 138.219383: rtcpu_string: tstamp:4514170189 id:0x04010000 str:"Configuring VI GoS.
kworker/0:2-1169 [000] … 138.219406: rtcpu_string: tstamp:4514170381 id:0x04010000 str:"VM GOS[#0 ] addr=0xe4900000
kworker/0:2-1169 [000] … 138.219441: rtcpu_string: tstamp:4514170647 id:0x04010000 str:"VM GOS[#1 ] addr=0xe4901000
kworker/0:2-1169 [000] … 138.219446: rtcpu_string: tstamp:4514170926 id:0x04010000 str:"VM GOS[#2 ] addr=0xe4902000
kworker/0:2-1169 [000] … 138.219451: rtcpu_string: tstamp:4514171167 id:0x04010000 str:"VM GOS[#3 ] addr=0xe4903000
kworker/0:2-1169 [000] … 138.219456: rtcpu_strin
Hi,Shane:
i have tried boost.looks same.
Right now trace print like this: whats mean of CHANSEL_NOMATCH?
kworker/0:0-4 [000] .... 101.243137: rtos_queue_peek_from_isr_failed: tstamp:3358091303 queue:0x0bcbcf78
│ kworker/0:0-4 [000] .... 101.243141: rtcpu_vinotify_event: tstamp:3358119666 tag:FE channel:0x00 frame:1 vi_tstamp:3357850162 data:0x00000020
│ kworker/0:0-4 [000] .... 101.243143: rtcpu_vinotify_error: tstamp:3358126024 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:3358125339 data:0x00000569
│ kworker/0:0-4 [000] .... 101.243144: rtcpu_vinotify_event: tstamp:3358432603 tag:FS channel:0x00 frame:2 vi_tstamp:3358123023 data:0x00000010
│ kworker/0:0-4 [000] .... 101.243146: rtcpu_vinotify_event: tstamp:3358432773 tag:CHANSEL_NOMATCH channel:0x01 frame:2 vi_tstamp:3358125339 data:0x00000569
│ kworker/0:0-4 [000] .... 101.243147: rtcpu_vinotify_event: tstamp:3359371624 tag:FE channel:0x00 frame:2 vi_tstamp:3359099816 data:0x00000020
│ kworker/0:0-4 [000] .... 101.243149: rtcpu_vinotify_error: tstamp:3359375678 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:3359374999 data:0x00000569
│ kworker/0:0-4 [000] .... 101.243150: rtcpu_vinotify_event: tstamp:3359376033 tag:FS channel:0x00 frame:3 vi_tstamp:3359372685 data:0x00000010
│ kworker/0:0-4 [000] .... 101.243151: rtcpu_vinotify_event: tstamp:3359376181 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:3359374999 data:0x00000569
│ kworker/0:0-4 [000] .... 101.299164: rtcpu_vinotify_event: tstamp:3360373250 tag:FE channel:0x00 frame:3 vi_tstamp:3360349477 data:0x00000020
│ kworker/0:0-4 [000] .... 101.299168: rtcpu_vinotify_error: tstamp:3360625346 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:3360624657 data:0x00000569
│ kworker/0:0-4 [000] .... 101.299170: rtcpu_vinotify_event: tstamp:3360686270 tag:FS channel:0x00 frame:4 vi_tstamp:3360622347 data:0x00000010
│ kworker/0:0-4 [000] .... 101.299171: rtcpu_vinotify_event: tstamp:3360686440 tag:CHANSEL_NOMATCH channel:0x01 frame:4 vi_tstamp:3360624657 data:0x00000569
│ kworker/0:0-4 [000] .... 101.355147: rtcpu_vinotify_event: tstamp:3361625296 tag:FE channel:0x00 frame:4 vi_tstamp:3361599136 data:0x00000020
│ kworker/0:0-4 [000] .... 101.355150: rtcpu_vinotify_error: tstamp:3361875007 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:3361874319 data:0x00000569
│ kworker/0:0-4 [000] .... 101.355152: rtcpu_vinotify_event: tstamp:3361938324 tag:FS channel:0x00 frame:1 vi_tstamp:3361872003 data:0x00000010
│ kworker/0:0-4 [000] .... 101.355154: rtcpu_vinotify_event: tstamp:3361938472 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:3361874319 data:0x00000569
│ kworker/0:0-4 [000] .... 101.355155: rtcpu_vinotify_event: tstamp:3362877257 tag:FE channel:0x00 frame:1 vi_tstamp:3362848798 data:0x00000020
and when i use
v4l2-ctl --set-fmt-video=width=1280,height=719,pixelformat=YUYV --stream-mmap --stream-count=1 --set-ctrl bypass_mode=0 -d /dev/video0
to capture,the kernel print
[ 437.228390] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 6, err_data 131072
[ 439.736945] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 439.737102] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 439.737288] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 439.737446] tegra194-vi5 15c10000.vi: unexpected response from camera processor
[ 439.737573] video4linux video0: vi capture release failed
[ 439.737667] tegra194-vi5 15c10000.vi: fatal: error recovery failed
and then Ctrl-c ,kernel print oops like this:
[ 485.051300] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 485.051468] Mem abort info:
[ 485.051527] ESR = 0x96000005
[ 485.051637] Exception class = DABT (current EL), IL = 32 bits
[ 485.051739] SET = 0, FnV = 0
[ 485.051798] EA = 0, S1PTW = 0
[ 485.051855] Data abort info:
[ 485.051907] ISV = 0, ISS = 0x00000005
[ 485.052004] CM = 0, WnR = 0
[ 485.052123] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc3b225f000
[ 485.052249] [0000000000000000] *pgd=0000000000000000, *pud=0000000000000000
[ 485.052398] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 485.052546] Modules linked in: overlay nvs_bmi160 nvs nvgpu binfmt_misc bluedroid_pm ip_tables x_tables
[ 485.052840] CPU: 0 PID: 7000 Comm: v4l2-ctl Not tainted 4.9.140 #117
[ 485.052954] Hardware name: jetson-xavier (DT)
[ 485.053120] task: ffffffc385527000 task.stack: ffffffc3b33ec000
[ 485.053599] PC is at exit_creds+0x2c/0x78
[ 485.053914] LR is at __put_task_struct+0x4c/0x140
[ 485.054263] pc : [<ffffff80080def84>] lr : [<ffffff80080b01ac>] pstate: 60400045
[ 485.058862] sp : ffffffc3b33efa10
[ 485.062195] x29: ffffffc3b33efa10 x28: 0000000000000008
[ 485.067813] x27: ffffff8008f62000 x26: ffffffc3b33efde8
[ 485.073560] x25: ffffffc3b3b242e8 x24: ffffffc3d8024598
[ 485.078741] x23: 0000000000000001 x22: ffffffc3d964f718
[ 485.084604] x21: ffffffc3a952b830 x20: 0000000000000000
[ 485.089584] x19: ffffffc3a952b800 x18: 0000000000000609
[ 485.095101] x17: 0000007f9f843698 x16: 0000000000012995
[ 485.100696] x15: 00000000000110e2 x14: 0000000000001fbe
[ 485.106634] x13: 0000000000000b7d x12: 0000000000000000
[ 485.111896] x11: 0000000000000400 x10: 0000000000000a20
[ 485.117921] x9 : ffffffc3b33ef860 x8 : ffffffc385527a80
[ 485.123696] x7 : 0000000000000218 x6 : 000000039326cdff
[ 485.129214] x5 : 0000000000000400 x4 : 0000000000000000
[ 485.134553] x3 : 00000000000000cb x2 : 0000000000000000
[ 485.139633] x1 : 0000000000000000 x0 : 00000000ffffffff
[ 485.146376] Process v4l2-ctl (pid: 7000, stack limit = 0xffffffc3b33ec000)
[ 485.153273] Call trace:
[ 485.155456] [<ffffff80080def84>] exit_creds+0x2c/0x78
[ 485.160466] [<ffffff80080b01ac>] __put_task_struct+0x4c/0x140
[ 485.165820] [<ffffff80080dca44>] kthread_stop+0x1e4/0x1e8
[ 485.170875] [<ffffff8008b30220>] vi5_channel_stop_kthreads+0x40/0x58
[ 485.176990] [<ffffff8008b302c4>] vi5_channel_stop_streaming+0x8c/0xa8
[ 485.182862] [<ffffff8008b233a4>] tegra_channel_stop_streaming+0x34/0x48
[ 485.189099] [<ffffff8008b1b724>] __vb2_queue_cancel+0x34/0x188
[ 485.194934] [<ffffff8008b1cc4c>] vb2_core_queue_release+0x2c/0x58
[ 485.200535] [<ffffff8008b1f2cc>] _vb2_fop_release+0x84/0xa0
[ 485.205872] [<ffffff8008b255f0>] tegra_channel_close+0x58/0x130
[ 485.211561] [<ffffff8008af88d8>] v4l2_release+0x48/0xa0
[ 485.216899] [<ffffff800825e528>] __fput+0x90/0x1d0
[ 485.221724] [<ffffff800825e6e0>] ____fput+0x20/0x30
[ 485.226270] [<ffffff80080d9bfc>] task_work_run+0xbc/0xd8
[ 485.232032] [<ffffff80080b9674>] do_exit+0x2c4/0xa08
The root cause should be the sensor output not as expect.
kworker/0:0-4 [000] .... 434.692974: rtcpu_vinotify_event: tstamp:13780235474 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:3 vi_tstamp:13779956518 data:0x01000000
Hi,Shane:
What should be the expect. I am super confused. my sensor is 1280 *720 25fps UVYV, and the dts is config to 4 lane, Any idea can help me?
The output size may not as your sensor driver report. You can have driver report the height increase one by one to try. Like 1280722, 1280 724, …
Hi,Shane:
Right now the log changed
kernel print like this:
[ 719.830723] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 512
[ 719.870728] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 512
[ 719.910711] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 512
[ 719.950736] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 512
[ 719.990741] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 512
[ 720.030663] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 512
[ 720.070657] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 512
[ 720.110654] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 512
[ 720.150692] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 512
[ 720.190675] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 512
[ 720.230657] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 512
[ 720.270685] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 512
kworker/0:4-2239 [000] .... 761.312984: rtcpu_vinotify_event: tstamp:23986778771 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:24530673600 data:0x07020013
kworker/0:4-2239 [000] .... 761.312985: rtcpu_vinotify_event: tstamp:23986778959 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:24530781408 data:0x10000000
kworker/0:4-2239 [000] .... 761.312987: rtcpu_vinotify_event: tstamp:23986779133 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:24530815040 data:0x31000014
kworker/0:4-2239 [000] .... 761.312988: rtcpu_vinotify_event: tstamp:23986779281 tag:FS channel:0x00 frame:2 vi_tstamp:23986522318 data:0x00000010
kworker/0:4-2239 [000] .... 761.312989: rtcpu_vinotify_event: tstamp:23986779452 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:23986522320 data:0x00000000
kworker/0:4-2239 [000] .... 761.312991: rtcpu_vinotify_event: tstamp:23986779597 tag:CHANSEL_PXL_SOF channel:0x23 frame:2 vi_tstamp:23986523279 data:0x00000001
kworker/0:4-2239 [000] .... 761.312992: rtcpu_vinotify_event: tstamp:23986779785 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:24539407040 data:0x08020013
kworker/0:4-2239 [000] .... 761.312993: rtcpu_vinotify_event: tstamp:23986779929 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:23986523459 data:0x00000200
kworker/0:4-2239 [000] .... 761.312995: rtcpu_vinotify_event: tstamp:23986780117 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:24539433440 data:0x01020013
kworker/0:4-2239 [000] .... 761.312997: rtos_queue_peek_from_isr_failed: tstamp:23986830647 queue:0x0bcbcf78
kworker/0:4-2239 [000] .... 761.368872: rtcpu_vinotify_event: tstamp:23987502363 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:23987499051 data:0x02cf0202
kworker/0:4-2239 [000] .... 761.368875: rtcpu_vinotify_event: tstamp:23987502547 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:24570635264 data:0x01020013
kworker/0:4-2239 [000] .... 761.368877: rtcpu_vinotify_event: tstamp:23987502698 tag:ATOMP_FRAME_DONE channel:0x23 frame:2 vi_tstamp:23987499081 data:0x00000000
kworker/0:4-2239 [000] .... 761.368878: rtcpu_vinotify_event: tstamp:23987502889 tag:RESERVED_19 channel:0x23 frame:2 vi_tstamp:24570640160 data:0x02020013
kworker/0:4-2239 [000] .... 761.368879: rtcpu_vinotify_event: tstamp:23987503041 tag:FE channel:0x00 frame:2 vi_tstamp:23987499112 data:0x00000020
kworker/0:4-2239 [000] .... 761.368880: rtcpu_vinotify_event: tstamp:23987503230 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:23987499115 data:0x00000000
kworker/0:4-2239 [000] .... 761.368882: rtcpu_vinotify_event: tstamp:23987503374 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:24570656768 data:0x07020014
Is that means my frame size is ok ?
My early comment should be decrease report the height for the short frame error. Have a try 719, 718 …
Hi, Shane:
I tried from 700 to 1000 one by one…
When i set 720 or less 720,it shows CHANSEL_FAULT
When i set 721 or more than 721, it shows SHORT_FRAME
I think i can not set 721.5. I wanna cry…
What’s the log for CHANSEL_FAULT without SHORT_FRAME? If the data is 0x02cf0202 that could be the line was shorter than expected you need to adjust the width.
CHANSEL_FAULT data bit field
bit 16:31 LINE_NUMBER
bit 15 DTYPE_MISMATCH
bit 14 EMBED_INFRINGE
bit 13 EMBED_LONG_LINE
bit 12 EMBED_SPURIOUS
bit 11 EMBED_RUNAWAY
bit 10 EMBED_MISSING_LE
bit 9 PIXEL_SHORT_LINE
bit 8 PIXEL_LONG_LINE
bit 7 PIXEL_SPURIOUS
bit 6 PIXEL_RUNAWAY
bit 5 PIXEL_MISSING_LE
bit 4 PIXEL_LINE_TIMER
bit 3 EMBED_EOF
bit 2 EMBED_SOF
bit 1 PIXEL_EOF
bit 0 PIXEL_SOF
Hi,Shane:
Thank you very much! I got it! The problem is my camera’s FV and LV not met at first line,so i discard the first line and i can got the frames. Thanks very much for Nvidia team too!
Dear xuhui1.wang,
I faced a similar problem ? How do you change your camera’s FV and LV ? Can you give some advices? I’m using GMSL cameras(1280x720).
When i set 719 or less than 719,it shows CHANSEL_FAULT
When i set 720 or more than 720,it shows CHANSEL_SHORT_FRAME
Thanks so much.
Dear xuhui1.wang,
Thanks so much.
Hi,dennis_Leetop,
Only FPDLink looks have FV LV problem, i can not find this in GMSL. I think your problem not like mine.
Hi xuhui1.wang,
Thanks for your information, I’m still working on it maybe other issue cause.
