I have already mailed them in getstarted@d3engineering.com but did not get reply. I will do with support email also…
Till then if possible can i get some reply here?
One of our engineers will be in touch with you shortly to help. I can also confirm we have received your email to support. The email to getstarted unfortunately got filtered out by mistake.
This sounds like the Ubuntu unattended-upgrade issue that we’ve seen a few times before on JP 4.4. If you disconnect the monitor that should stop the boot-loop and you’ll be able to access the system via SSH. If so, you can use the following command to see if an unattended upgrade has occurred.
# List l4t packages, exclude kernel since it follows a different version format
dpkg -l | grep nvidia-l4t | awk -F ' ' '{print $2}'
If the versions you get back don’t match what is in /etc/nv_tegra_release then unattended upgrade is very likely the issue. To fix this you can either manually roll back the packages, or re-flash and disable unattended-upgrade. Either way you’ll need to disable unattended-upgrade (see command below). If you go the “re-flash and disable” route make sure to run the command below before doing anything else on the system.
I ran the command and got the following results- dpkg -l | grep nvidia-l4t | awk -F ’ ’ '{print $2}'
nvidia-l4t-3d-core
nvidia-l4t-apt-source
nvidia-l4t-bootloader
nvidia-l4t-camera
nvidia-l4t-configs
nvidia-l4t-core
nvidia-l4t-cuda
nvidia-l4t-firmware
nvidia-l4t-graphics-demos
nvidia-l4t-gstreamer
nvidia-l4t-init
nvidia-l4t-initrd
nvidia-l4t-jetson-io
nvidia-l4t-jetson-multimedia-api
nvidia-l4t-kernel
nvidia-l4t-kernel-dtbs
nvidia-l4t-kernel-headers
nvidia-l4t-multimedia
nvidia-l4t-multimedia-utils
nvidia-l4t-oem-config
nvidia-l4t-tools
nvidia-l4t-wayland
nvidia-l4t-weston
nvidia-l4t-x11
nvidia-l4t-xusb-firmware
and for cat /etc/nv_tegra_release
R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t186ref, EABI: aarch64, DATE: Fri Oct 16 19:37:08 UTC 2020
Not sure to interpret the results.
Also if this is the issue and i need to go reflash step again so should i follow this? -
*)reflash jetpack4.4 with jetson SDK components.
*)run the command -
sudo systemctl disable --now apt-daily-upgrade.timer apt-daily.timer
*) run the command-
sudo apt update && sudo apt install
./linux-image-4.9.140+4.0.0-d3+_1_arm64.deb
./d3-jetson-util_4.0.0-1_arm64.deb
The command I provided was slightly off. If you run the command below it will give you the full output.
You should be able to see the versions after the package names, and they should start with 32.4.4 based on the contents of nv_tegra_release. If the versions are different then we are on the right track with re-flashing and disabling upgrades.
Thank you for providing that output. Since the package version numbers are 32.4.4*, and that matches nv_tegra_release I don’t think unattended upgrade is the issue. The kernel version being slightly different is expected, the important part is the 32.4.4 in there.
Looking at the contents of nv_tegra_release, I think you are installing JP 4.4.1 (L4T 32.4.4). I think it is worth-while to try installing JP 4.4 (L4T 32.4.3), even minor upgrades from NVIDIA sometimes cause problems with our release.
Thanks for the support.
As you suggested, it is working now.
One last general query-
I have D3RCM-OV10640 camera and also running with “argus_camera” utility.
I just used deepstream to check if i can run some video analytics on top of this camera with v4l utils. I am able to see the node /dev/video0 but it is not running as ffplay also not with deepstream beside providing correct parameters of camera like-
v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘BA12’
Name : 12-bit Bayer GRGR/BGBG
Size: Discrete 1280x1080
Interval: Discrete 0.033s (30.000 fps)
Index : 1
Pixel Format: 'BG12'
Name : 12-bit Bayer BGBG/GRGR
Any suggestions? if i can run this camera with Deepstream ? if not so anything there for some video analytics example to get started?
I’m glad we could get to the bottom of the setup issues. As far as streaming goes, just to confirm, you are able to stream with both v4l2 (see command) and argus_camera?
These Gstreamer examples may also be helpful: Jetson Linux
For video analytics I think Deepstream would be your best bet, though I’m not sure how much support I can provide in that area. At the camera access level Deepstream depends on Gstreamer, which is supported with our cameras. The easiest way to test Gstreamer functionality would be with nvgstcapture.
# N is the camera idx, 0 -> /dev/video0
nvgstcapture --sensor-id 0
I ran v4l-ctl command as you mentioned also as given in the Release notes, but no output no error is there. It hangs after i hit Enter.
nvgstcapture --sensor-id 0 runs but it is giving light purple video output although video is running.
If i set camera resolution in gst-launch command then it runs fine. like-
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1’ ! nvoverlaysink.
