I saw the sample app deepstream_image_meta_test, but I didn’t succeed to extract image with it, I don’t want to save processed image or cropped image, only raw frame
Frame Saved Corrupted On Jetson Orin But Not On dGPU
• Jetson Orin Nano
• Deepstream 7.0
• JetPack 6.0
• 8.6.2.3-1+cuda12.2
• bugs
• Adding this code snippet in a callback probe on a usb camera sample
• c++ 17; openCv
I’m building a Deepstream app on c++ where I want to save a frame (without any cropping) in JPG format every 10 second , My app is available on x86 dGPU and jetson Orin.
When I use my application on dGPU, the image is correct:
But when I use it on my Orin I get discontigous image :
Here the code I use inside the loop of my Callback Probe Function :
#include <string>
#include <sstream>
#include <unordered_map>
#include <utility> // For std::pair
#include <cstdlib> // For exit
#include <ctime> // For localtime
#include <iomanip> // For std::setw and std::setfill
#include <chrono> // For time calculations
#include <cstring>
#include <iostream>
#include <filesystem>
#include <system_error>
// System headers
#include <sys/file.h> // For flock
#include <sys/stat.h> // For stat
#include <fcntl.h> // For open
#include <unistd.h> // For close
// CUDA headers
#include <cuda_runtime_api.h>
// GStreamer and DeepStream headers
#include <gst/gst.h>
#include <gst/video/video.h>
#include "gstnvdsmeta.h"
#include "nvdsmeta_schema.h"
#include "nvds_roi_meta.h"
#include <nvds_obj_encode.h>
// NVIDIA headers
#include <nvbufsurface.h>
#include <nvbufsurftransform.h>
// OpenCV headers
#include <opencv2/opencv.hpp>
* @brief Converts NvBufSurface to cv::Mat using CUDA.
* @param surface Pointer to the NvBufSurface.
* @param batch_id Batch ID.
* @return A cv::Mat object containing the image data.
cv::Mat NvBufSurfaceToCvMat(NvBufSurface *surface, int batch_id) {
//surface->memType = NVBUF_MEM_DEFAULT; // Ensure the memory type is set to surface array no
//surface memtype is array
// Map the surface for reading
if (NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ_WRITE) != 0) {
std::cerr << "Failed to map NvBufSurface" << std::endl;
return cv::Mat(); // Return an empty cv::Mat on failure
// Sync the surface memory for CPU access
NvBufSurfaceSyncForDevice(surface, batch_id, 0);
NvBufSurfaceParams params = surface->surfaceList[0]; // Get the surface parameters for the specified batch ID
cv::Mat img(params.height, params.width, CV_8UC4, params.dataPtr, params.pitch);
// Unmap the surface after reading
NvBufSurfaceUnMap(surface, 0, 0);
return img; // Return the created cv::Mat
* @brief Saves a frame image to a file.
* @param buf Pointer to the GstBuffer.
* @param logDir Directory where the image file will be saved.
* @param filename The filename to save the image.
void saveFrameImage(GstBuffer* buf, const std::string& logDir, const std::string& filename) {
NvBufSurface* surface = nullptr;
GstMapInfo map;
if (gst_buffer_map(buf, &map, GST_MAP_READ)) {
surface = (NvBufSurface*)map.data;
// gst_buffer_unmap(buf, &map);
} else {
g_printerr("Unable to map GstBuffer to NvBufSurface\n");
return;
int batch_id = 0;
cv::Mat frame = NvBufSurfaceToCvMat(surface, batch_id);
//display the image
struct stat sb;
if(stat(logDir.c_str(), &sb) != 0) {
system(("mkdir -p " + logDir).c_str());
if (!cv::imwrite(logDir + "/" + filename, frame)) {
g_printerr("Failed to save frame to file\n");
} else {
g_print("Frame saved to %s\n", filename.c_str());
Here the beginig of pipeline:
pipeline:
- v4l2src:
device: /dev/video0
- capsfilter:
caps: "image/jpeg, width=1920, height=1080, framerate=30/1"
- jpegdec: {}
- videoconvert: {}
- nvvideoconvert: {}
- capsfilter:
caps: "video/x-raw(memory:NVMM), format=RGBA, width=1920, height=1080"
- mux.sink_0:
nvstreammux:
batch-size: 1
width: 1920
height: 1080
batched-push-timeout: 4000000
live-source: 1
num-surfaces-per-frame: 1
sync-inputs: 0
max-latency: 0
Thanks for any help !
