Hello.
I’ve using ‘Video_Codec_SDK_11.1.5’.
I have problem with to get frame rate of the specific video file.
When I play with ‘ffmpeg’, ‘vlc’, that’s codec info show 30fps and ‘MediaInfo’ shows same.
It’s info of that video’s ‘MediaInfo’.
This is from 'FFmpeg".
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2mp41
encoder : Lavf58.12.100
Duration: 00:48:06.23, start: 0.000000, bitrate: 2171 kb/s
Stream #0:0[0x1](und): Video: mpeg4 (Advanced Simple Profile) (mp4v / 0x7634706D), yuv420p, 640x480 [SAR 1:1 DAR 4:3], 2054 kb/s, 30 fps, 30 tbr, 15360 tbn (default)
Metadata:
handler_name : VideoHandler
vendor_id : [0][0][0][0]
Stream #0:1[0x2](und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 110 kb/s (default)
Metadata:
handler_name : SoundHandler
And real fps of that video file is 30.
But,
On NvDecoder, was 3fps get.
→ m_videoFormat.frame_rate.numerator : 30
→ m_videoFormat.frame_rate.denominator : 10
This is output of “GetVideoInfo()”
Codec : MPEG-4 (ASP)
Frame rate : 30/10 = 3 fps
Sequence : Progressive
Coded size : [640, 480]
Display area : [0, 0, 640, 480]
Chroma : YUV 420
Bit depth : 8
Video Decoding Params:
Num Surfaces : 4
Crop : [0, 0, 0, 0]
Resize : 640x480
Deinterlace : Weave
How can i get real fps from this video?
Do I have to modified fps formula for each video codec?
