GA104M no devices were fond on nvidia-smi, i installed nvidia-driver-550,
wangsx@AIdm:/data/3320$ sudo ubuntu-drivers devices
udevadm hwdb is deprecated. Use systemd-hwdb instead.
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd0000249Csv000010DEsd00000000bc03sc00i00
vendor : NVIDIA Corporation
model : GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
driver : nvidia-driver-470 - distro non-free
driver : nvidia-driver-550 - distro non-free recommended
driver : nvidia-driver-470-server - distro non-free
driver : nvidia-driver-570-server-open - distro non-free
driver : nvidia-driver-570-server - distro non-free
driver : nvidia-driver-535-open - distro non-free
driver : nvidia-driver-535 - distro non-free
driver : nvidia-driver-535-server - distro non-free
driver : nvidia-driver-550-open - distro non-free
driver : nvidia-driver-535-server-open - distro non-free
driver : xserver-xorg-video-nouveau - distro free builtin
wangsx@AIdm:/data/3320$ sudo dmesg | grep -i nvidia
[ 3.272319] nvidia: loading out-of-tree module taints kernel.
[ 3.272327] nvidia: module license ‘NVIDIA’ taints kernel.
[ 3.272330] nvidia: module license taints kernel.
[ 3.610302] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 3.611716] nvidia 0000:01:00.0: enabling device (0000 → 0003)
[ 3.611794] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 3.655526] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.120 Fri Sep 13 10:10:01 UTC 2024
[ 3.668065] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input3
[ 3.668096] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input4
[ 3.668118] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input5
[ 3.668138] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input6
[ 3.669517] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.120 Fri Sep 13 10:01:25 UTC 2024
[ 3.683225] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 4.607236] [drm:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NvKmsKapiDevice
[ 4.607350] [drm:nv_drm_register_drm_device [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to register device
[ 4.736820] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 4.770209] nvidia-uvm: Loaded the UVM driver, major device number 509.
[ 7033.191363] nvidia-modeset: Unloading
[ 7033.208853] nvidia-uvm: Unloaded the UVM driver.
[ 7033.251662] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 7109.445443] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 7109.446971] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=none,decodes=none:owns=none
[ 7109.497208] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.120 Fri Sep 13 10:10:01 UTC 2024
[ 7109.513421] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.120 Fri Sep 13 10:01:25 UTC 2024
[ 7109.531175] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 7110.527362] [drm:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NvKmsKapiDevice
[ 7110.527556] [drm:nv_drm_register_drm_device [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to register device
[ 7110.739331] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 7110.785472] nvidia-uvm: Loaded the UVM driver, major device number 509.
[ 7154.608371] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
wangsx@AIdm:/data/3320$ nvidia-smi
No devices were found
nvidia-bug-report.log.gz (169.6 KB)
