system info:
kernel:
uname -a
Linux ripper101 5.15.0-107-generic #117-Ubuntu SMP Fri Apr 26 12:26:49 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
nvdia card:
hwinfo --gfxcard --short
graphics card:
nVidia GP104 [GeForce GTX 1070]
Primary display adapter: #52
distro:
cat /etc/issue
Ubuntu 22.04.4 LTS \n \l
nvdia drivers:
ubuntu-drivers list
nvidia-driver-550, (kernel modules provided by linux-modules-nvidia-550-generic)
nvidia-driver-535-server, (kernel modules provided by linux-modules-nvidia-535-server-generic)
nvidia-driver-470, (kernel modules provided by linux-modules-nvidia-470-generic)
nvidia-driver-520, (kernel modules provided by nvidia-dkms-520)
nvidia-driver-525, (kernel modules provided by nvidia-dkms-525)
nvidia-driver-515, (kernel modules provided by nvidia-dkms-515)
nvidia-driver-545, (kernel modules provided by nvidia-dkms-545)
nvidia-driver-390, (kernel modules provided by linux-modules-nvidia-390-generic)
nvidia-driver-535, (kernel modules provided by linux-modules-nvidia-535-generic)
nvidia-driver-450-server, (kernel modules provided by linux-modules-nvidia-450-server-generic)
nvidia-driver-470-server, (kernel modules provided by linux-modules-nvidia-470-server-generic)
nvidia-driver-418-server, (kernel modules provided by nvidia-dkms-418-server)
x11 logs
cat /var/log/Xorg.0.log | grep EE
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 28.695] (EE) [drm] Failed to open DRM device for pci:0000:41:00.0: -19
[ 28.695] (EE) open /dev/dri/card0: No such file or directory
[ 28.696] (EE) Unable to find a valid framebuffer device
[ 28.697] (EE) Screen 0 deleted because of no matching config section.
[ 28.704] (II) Initializing extension MIT-SCREEN-SAVER
kernel messages
sudo dmesg | grep nvidia
[ 7.007888] audit: type=1400 audit(1715979079.054:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1373 comm="apparmor_parser"
[ 7.007893] audit: type=1400 audit(1715979079.054:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1373 comm="apparmor_parser"
[ 7.023052] nvidia: loading out-of-tree module taints kernel.
[ 7.023066] nvidia: module license 'NVIDIA' taints kernel.
[ 7.120343] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 7.134353] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 7.135440] nvidia 0000:41:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 7.277506] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.239.06 Sat Feb 3 06:03:51 UTC 2024
[ 7.285749] [drm] [nvidia-drm] [GPU ID 0x00004100] Loading driver
[ 7.580838] caller os_map_kernel_space.part.0+0x83/0xb0 [nvidia] mapping multiple BARs
[ 8.055386] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:41:00.0 on minor 0
[ 8.089113] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 8.097013] nvidia-uvm: Loaded the UVM driver, major device number 509.
idk what i tried.
maybe simply apt upgrade -y triggered the issue. but im not sure.
Maybe the tainted kernal and the kernel module verfication is a hint?
Any help is appreciated
hint0:
reinstalling of driver apt purge *nvidia*, apt autoremove, apt autoclean, apt -f install, apt-add-repository -r ppa:graphics-drivers/ppa, apt install nvidia-driver-460
leads to this normal outpout
libnvidia-decode-550:amd64 (550.54.15-0ubuntu1) wird eingerichtet ...
xserver-xorg-video-nvidia-550 (550.54.15-0ubuntu1) wird eingerichtet ...
nvidia-dkms-550 (550.54.15-0ubuntu1) wird eingerichtet ...
update-initramfs: deferring update (trigger activated)
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
Loading new nvidia-550.54.15 DKMS files...
Building for 5.15.0-107-generic
Building for architecture x86_64
Building initial module for 5.15.0-107-generic
Secure Boot not enabled on this system.
Done.
nvidia.ko:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/5.15.0-107-generic/updates/dkms/
nvidia-modeset.ko:
- Original module
- Installation
nvidia-drm.ko:
- Original module
- Installation
nvidia-uvm.ko:
- Original module
- Installation
nvidia-peermem.ko:
- Original module
- Installation
depmod...
libnvidia-encode-550:amd64 (550.54.15-0ubuntu1) wird eingerichtet ...
libx11-6:i386 (2:1.7.5-1ubuntu0.3) wird eingerichtet ...
nvidia-driver-550 (550.54.15-0ubuntu1) wird eingerichtet ...
libxext6:i386 (2:1.3.4-1build1) wird eingerichtet ...
libnvidia-fbc1-550:i386 (550.54.15-0ubuntu1) wird eingerichtet ...
libnvidia-gl-550:i386 (550.54.15-0ubuntu1) wird eingerichtet ...
libnvidia-decode-550:i386 (550.54.15-0ubuntu1) wird eingerichtet ...
libnvidia-encode-550:i386 (550.54.15-0ubuntu1) wird eingerichtet ...
Trigger für bamfdaemon (0.5.6+22.04.20220217-0ubuntu1) werden verarbeitet ...
Rebuilding /usr/share/applications/bamf-2.index...
Trigger für desktop-file-utils (0.26-1ubuntu3) werden verarbeitet ...
Trigger für initramfs-tools (0.140ubuntu13.4) werden verarbeitet ...
update-initramfs: Generating /boot/initrd.img-5.15.0-107-generic
Trigger für gnome-menus (3.36.0-1ubuntu3) werden verarbeitet ...
Trigger für libc-bin (2.35-0ubuntu3.7) werden verarbeitet ...
Trigger für man-db (2.10.2-1) werden verarbeitet ...
Trigger für mailcap (3.70+nmu1ubuntu1) werden verarbeitet ...
dkms status
nvidia/550.54.15, 5.15.0-107-generic, x86_64: installed
hint1:
apt-get install -V nvidia-kernel-source-550-open cuda-drivers-550
reboot
dmesg | grep nvidia
messes kernel log
` 391.138186] nvidia: probe of 0000:41:00.0 failed with error -1
[ 391.138428] nvidia-nvlink: Unregistered Nvlink Core, major device number 510
[ 391.269652] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ 391.271158] nvidia 0000:41:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
NVRM: nvidia.ko because it does not include the required GPU
NVRM: www.nvidia.com.
did not fix it.
tysm
update: installed manual 535.171 production driver. no changes see bug-report
nvidia-bug-report.log.gz (422.0 KB)
