The symptom:
When I purge then install the activate NVidia drivers (430 and 440 tried so far) and then reboot, the computer shows a black screen. I can’t activate a console with alt+ctrl+F6 (or the other equivalents). The machine has to be restarted the traditional way (i.e. by pressing on the power button until it powers off). To get to a console, I have to repower the machine, hit esc when the machine loads up to the BIOS, enter grub, enter the advanced options, put in nomodeset, reboot computer, select “intel” and then reboot again. I can then enter the GUI as per normal but without any NVidia drivers active.
This is reproducible.
Other symptoms:
Even with an NVidia driver selected, no game I run to test it out sees the discreet graphics card. It only sees the APU.
I cannot run nvidia-settings. It gives me:
ERROR: Unable to load info from any available system
A short description of specifics:
ASUS-TUF Gaming laptop:
AMD Ryzen 5 CPU, AMD Raven APU, GeForce 1650 GTX discreet graphics card. I’ve only had this machine for 3 weeks so it’s a fairly fresh install. The graphics drivers did not work from the start, as soon as I put Ubuntu on it. -
Drivers tried:
NVidia 430 and 440 (currently 440 since the 430 that came by default did not work either) -
OS:
Ubuntu 18.04 with a kernel recently upgraded to 5.0 -
Other graphics drivers:
Xorg and the Mesa APU drivers -
Steps taken to reproduce this problem:
- purge all NVidia
- purge ppa
- reboot
- set ppa
- upgrade apt
- install graphics driver
- reboot
- check to see if installed then activate with prime-select
- test in some game if it sees the right graphics card
- reboot or shut down comp (black screen of death when reboot)
- Steps taken to try to solve this problem:
- remove xorg.conf and have nvidia-xorg recreate it
- add custom xorg.conf that tells Linux that the GeForce must be the main GPU and put in modesetting option in the AMD APU config
- blacklist Nouveau, make sure NVidia is not blacklisted by removing any blacklist-nvidia files
- try different mode settings in Grub
- updated kernel
- checked on SecureBoot in BIOS: it is off
- a bunch of stuff I’m probably forgetting since I’ve tried so many things
lspci | grep ‘VGA’ gives:
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f91 (rev a1)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso (rev c2)
sudo lshw
tuf-gaming-fx505dt-fx505dt
description: Ordinateur Bloc-notes
produit: TUF Gaming FX505DT_FX505DT
fabriquant: ASUSTeK COMPUTER INC.
version: 1.0
numéro de série: K9NRCV050153389
bits: 64 bits
fonctionnalités: smbios-3.2 dmi-3.2 smp vsyscall32
configuration: boot=normal chassis=notebook family=TUF Gaming uuid=C96778B2-85D8-406C-9C72-06AB457633CF
*-core
description: Carte mère
produit: FX505DT
identifiant matériel: 0
version: 1.0
numéro de série: K937NRCV0097UDMB
emplacement: Default string
*-firmware
description: BIOS
fabriquant: American Megatrends Inc.
version: FX505DT.306
date: 07/12/2019
taille: 64KiB
capacité: 15MiB
fonctionnalités: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
*-memory
description: Mémoire Système
identifiant matériel: a
emplacement: Carte mère
taille: 16GiB
*-bank:0
description: SODIMM DDR4 Synchrone Unbuffered (Unregistered) 2667 MHz (0,4 ns)
produit: M471A1K43DB1-CTD
fabriquant: Samsung
numéro de série: 32FD7D54
emplacement: DIMM 0
taille: 8GiB
bits: 64 bits
horloge: 2667MHz (0.4ns)
*-bank:1
fabriquant: Samsung
identifiant matériel: 1
numéro de série: 32FD7C34
emplacement: DIMM 0
taille: 8GiB
bits: 64 bits
*-cache:0
description: L1 cache
identifiant matériel: c
emplacement: L1 - Cache
taille: 384KiB
capacité: 384KiB
horloge: 1GHz (1.0ns)
fonctionnalités: pipeline-burst internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
identifiant matériel: d
emplacement: L2 - Cache
taille: 2MiB
capacité: 2MiB
configuration: level=2
*-cache:2
description: L3 cache
identifiant matériel: e
emplacement: L3 - Cache
taille: 4MiB
capacité: 4MiB
configuration: level=3
*-cpu
description: CPU
produit: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
fabriquant: Advanced Micro Devices [AMD]
identifiant matériel: f
information bus: cpu@0
version: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
numéro de série: Unknown
emplacement: FP5
taille: 1451MHz
capacité: 3700MHz
bits: 64 bits
horloge: 100MHz
fonctionnalités: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_pstate sme ssbd sev ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 xsaves clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca cpufreq
configuration: cores=4 enabledcores=4 threads=8
*-display
description: VGA compatible controller
produit: NVIDIA Corporation
fabriquant: NVIDIA Corporation
information bus: pci@0000:01:00.0
version: a1
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
ressources: irq:74 mémoire:f6000000-f6ffffff mémoire:c0000000-cfffffff mémoire:d0000000-d1ffffff portE/S:f000(taille=128) mémoire:f7000000-f707ffff
*-display
produit: Picasso
fabriquant: Advanced Micro Devices, Inc. [AMD/ATI]
information bus: pci@0000:05:00.0
version: c2
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm pciexpress msi msix vga_controller bus_master cap_list rom
configuration: driver=amdgpu latency=0
ressources: irq:72 mémoire:e0000000-efffffff mémoire:f0000000-f01fffff portE/S:c000(taille=256) mémoire:f7500000-f757ffff mémoire:c0000-dffff
glxinfo|egrep “OpenGL”
OpenGL vendor string: X.Org
OpenGL renderer string: AMD RAVEN (DRM 3.27.0, 5.0.0-37-generic, LLVM 9.0.0)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 19.2.1
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.5 (Compatibility Profile) Mesa 19.2.1
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 19.2.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
sudo modprobe nvidia doesn’t return anything and doesn’t return any errors.
/etc/X11/xorg.conf
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
/etc/X11/xorg.conf.d/10-amdgpu.conf
Section "OutputClass"
Identifier "AMDgpu"
MatchDriver "amdgpu"
Driver "modesetting"
EndSection
/etc/X11/xorg.conf.d/10-nvidia-gpu.conf
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "Primary GPU" "Yes"
ModulePath "/usr/lib/x86_64-linux-gnu/nvidia-440/xorg"
EndSection
sudo nvidia-smi
Sat Dec 21 17:10:16 2019
| NVIDIA-SMI 440.33.01 Driver Version: 440.33.01 CUDA Version: 10.2 |
| 0 GeForce GTX 1650 Off | 00000000:01:00.0 Off | N/A |
| N/A 40C P0 3W / N/A | 0MiB / 3911MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
uname -r
5.0.0-37-generic
/etc/default/grub
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="nouveau.modeset=0 rd.driver.blacklist=nouveau"
GRUB_CMDLINE_LINUX=""
I updated grub after editing this file.
NVidia Bug Report coming soon.
It just seems like there is a conflict between the Raven and the GeForce with the Raven always winning out no matter what I try. Not sure how to get these two things to play nice.
NOTE: apologies for the mishmash of French and English in the logs.
nvidia-bug-report.log.gz (1.08 MB)
