After upgrading from 17.10 to 18.04.1 everything was fine (means my X-session came up in mode 3840x2160_30) when I had installed the Nvidia 390 driver.
After a second reboot the GDM3 login screen was still fine but when logging in into my userid (501) screen went black and did not recover. This is reproducible.
Reverting to Nouveau driver seemed to solve the problem, but after a couple of reboots (3-5) Nouveau comes up with mode 1024x768 without any choice.
Now I updated to Nvidia 396.54 downloaded from PPA, it works up to GDM3 login screen but after the login it goes black again.
Following is the Xorg.1.log
Any help or advice much apprechiated.
Karl
root@lnx54srv14:/var/log# cat Xorg.1.log
[ 27.970] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 27.970] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 27.970] (--) Log file renamed from "/var/log/Xorg.pid-2846.log" to "/var/log/Xorg.1.log"
[ 27.971]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 27.971] X Protocol Version 11, Revision 0
[ 27.971] Build Operating System: Linux 4.4.0-119-generic x86_64 Ubuntu
[ 27.971] Current Operating System: Linux lnx54srv14 4.15.0-33-generic #36-Ubuntu SMP Wed Aug 15 16:00:05 UTC 2018 x86_64
[ 27.971] Kernel command line: BOOT_IMAGE=/vmlinuz-4.15.0-33-generic root=UUID=634e378b-6aa0-4a93-8922-abece17ec21a ro quiet splash vt.handoff=1
[ 27.971] Build Date: 13 April 2018 08:07:36PM
[ 27.971] xorg-server 2:1.19.6-1ubuntu4 (For technical support please see http://www.ubuntu.com/support)
[ 27.971] Current version of pixman: 0.34.0
[ 27.971] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 27.971] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 27.972] (==) Log file: "/var/log/Xorg.1.log", Time: Fri Sep 7 22:12:56 2018
[ 27.972] (==) Using config file: "/etc/X11/xorg.conf"
[ 27.972] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 27.972] (==) ServerLayout "Layout0"
[ 27.972] (**) |-->Screen "Screen0" (0)
[ 27.972] (**) | |-->Monitor "Monitor0"
[ 27.973] (**) | |-->Device "Device0"
[ 27.973] (**) |-->Input Device "Keyboard0"
[ 27.973] (**) |-->Input Device "Mouse0"
[ 27.973] (==) Automatically adding devices
[ 27.973] (==) Automatically enabling devices
[ 27.973] (==) Automatically adding GPU devices
[ 27.973] (==) Automatically binding GPU devices
[ 27.973] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 27.973] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 27.973] Entry deleted from font path.
[ 27.973] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 27.973] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 27.973] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 27.973] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 27.973] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 27.973] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 27.973] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 27.973] (WW) Disabling Keyboard0
[ 27.973] (WW) Disabling Mouse0
[ 27.973] (II) Loader magic: 0x55fd7a20a020
[ 27.973] (II) Module ABI versions:
[ 27.973] X.Org ANSI C Emulation: 0.4
[ 27.973] X.Org Video Driver: 23.0
[ 27.973] X.Org XInput driver : 24.1
[ 27.973] X.Org Server Extension : 10.0
[ 27.974] (++) using VT number 2
[ 27.978] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[ 27.978] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 27.979] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 27.983] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
[ 27.989] (--) PCI:*(0:2:0:0) 10de:1287:1043:8525 rev 161, Mem @ 0xc1000000/16777216, 0xc8000000/134217728, 0xc4000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/131072
[ 27.989] (II) LoadModule: "glx"
[ 27.989] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglx.so
[ 27.994] (II) Module glx: vendor="NVIDIA Corporation"
[ 27.994] compiled for 4.0.2, module version = 1.0.0
[ 27.994] Module class: X.Org Server Extension
[ 27.994] (II) NVIDIA GLX Module 396.54 Tue Aug 14 22:37:05 PDT 2018
[ 27.994] (II) LoadModule: "nvidia"
[ 27.994] (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
[ 27.994] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 27.994] Module class: X.Org Video Driver
[ 27.994] (II) NVIDIA dlloader X Driver 396.54 Tue Aug 14 22:15:03 PDT 2018
[ 27.994] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 27.994] (II) systemd-logind: releasing fd for 226:0
[ 27.995] (II) Loading sub module "fb"
[ 27.995] (II) LoadModule: "fb"
[ 27.995] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 27.995] (II) Module fb: vendor="X.Org Foundation"
[ 27.995] compiled for 1.19.6, module version = 1.0.0
[ 27.995] ABI class: X.Org ANSI C Emulation, version 0.4
[ 27.995] (II) Loading sub module "wfb"
[ 27.995] (II) LoadModule: "wfb"
[ 27.995] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 27.995] (II) Module wfb: vendor="X.Org Foundation"
[ 27.995] (II) Loading sub module "ramdac"
[ 27.995] (II) LoadModule: "ramdac"
[ 27.995] (II) Module "ramdac" already built-in
[ 27.996] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 27.996] (==) NVIDIA(0): RGB weight 888
[ 27.996] (==) NVIDIA(0): Default visual is TrueColor
[ 27.996] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 27.996] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 27.996] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 27.996] (**) NVIDIA(0): Enabling 2D acceleration
[ 27.998] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:2:0:0
[ 27.998] (--) NVIDIA(0): CRT-0
[ 27.998] (--) NVIDIA(0): DFP-0
[ 27.998] (--) NVIDIA(0): DFP-1 (boot)
[ 28.000] (II) NVIDIA(0): NVIDIA GPU GeForce GT 730 (GK208) at PCI:2:0:0 (GPU-0)
[ 28.000] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 28.000] (--) NVIDIA(0): VideoBIOS: 80.28.b8.00.13
[ 28.000] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[ 28.000] (EE) NVIDIA(GPU-0): Failed to acquire modesetting permission.
[ 28.000] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 28.001] (II) UnloadModule: "nvidia"
[ 28.001] (II) UnloadSubModule: "wfb"
[ 28.001] (II) UnloadSubModule: "fb"
[ 28.001] (EE) Screen(s) found, but none have a usable configuration.
[ 28.001] (EE)
Fatal server error:
[ 28.001] (EE) no screens found(EE)
[ 28.001] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 28.001] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
[ 28.001] (EE)
[ 28.040] (EE) Server terminated with error (1). Closing log file.
nvidia-installer.log (4.75 KB)
nvidia-uninstall.log (12.7 KB)
nvidia-bug-report.log.gz (129 KB)
