I’ve kind of made some lead way as far as the RTSP Stream output from Nvidia Deepstream Starting up slowly. I have edited the following file apps-common/deepstream_sink_bin.c to add idframeinterval ever 5 frames and it starts up much faster!
In this method:
static gboolean
create_udpsink_bin (NvDsSinkEncoderConfig * config, NvDsSinkBinSubBin * bin)
I edited the following line and it starts much quicker!
if (prop.integrated) {
if (config->enc_type == NV_DS_ENCODER_TYPE_HW) {
g_object_set (G_OBJECT (bin->encoder), "preset-level", 1, NULL);
g_object_set (G_OBJECT (bin->encoder), "insert-sps-pps", 1, NULL);
#ifdef IS_TEGRA
g_print("System is TEGRA! Setting idrinterval! \n");
g_object_set (G_OBJECT (bin->encoder), "idrinterval", 5, NULL);
#endif
} else {
g_object_set (G_OBJECT (bin->transform), "gpu-id", config->gpu_id, NULL);
The part I added was:
#ifdef IS_TEGRA
#endif
Which basically says if the systems architecture is Tegra then add the idrinterval at an interval of 5! I got this idea from the following forum post:
https://forums.developer.nvidia.com/t/deepstream-6-2version-seems-not-produce-idr-periodically/251958/5
