GCC-14 on Jetson Orin Nano
Hi, are there gcc-14 packages available for Jetson Orin Nano running JetPack 6.x? Gcc-14 seems to be not available on Ubunut 22.04, and I really would like to avoid building gcc from source.
Thank you!
The question is asking about the availability of GCC 14 packages for Jetson Orin Nano running JetPack 6.x.
Unfortunately, the provided context does not explicitly mention the availability of GCC 14 packages for Jetson Orin Nano. However, it does mention the Jetson Linux Toolchain, which is a set of tools for building and debugging applications on Jetson platforms.
In the context, there is a mention of “Working With Sources” which might imply that building GCC from source is an option. However, the question explicitly states that they would like to avoid building GCC from source.
It’s worth noting that the context mentions “Software Packages and the Update Mechanism” which might imply that there is a way to update or install packages on the Jetson Orin Nano. However, without more information, it’s unclear if GCC 14 packages are available through this mechanism.
In general, GCC 14 might not be available on Ubuntu 22.04, as the default GCC version on Ubuntu 22.04 is GCC 11. However, it’s possible that GCC 14 packages might be available through a third-party repository or a package manager like apt.
To answer the question comprehensively, it would be necessary to check the official NVIDIA documentation or the JetPack 6.x documentation to see if GCC 14 packages are available for Jetson Orin Nano. Alternatively, you could try searching for third-party repositories or package managers that might provide GCC 14 packages for Ubuntu 22.04.
In comparison, the context does mention the Jetson Linux Toolchain, which might provide a way to build and debug applications on Jetson Orin Nano. However, without more information, it’s unclear if this toolchain includes GCC 14 or if it can be used to install GCC 14 packages.
In summary, while the context does not explicitly mention the availability of GCC 14 packages for Jetson Orin Nano, it does provide some hints about the Jetson Linux Toolchain and the software package update mechanism. However, without more information, it’s unclear if GCC 14 packages are available for Jetson Orin Nano running JetPack 6.x.
Sorry, we don’t provide support since our JP 6.x version uses Ubuntu 22.04.
Thank you for your understanding and appreciation.
