Hi.
So I have been using the WD SN550 NVMe SSD (Model number: WDS250G2B0C)for testing on both the Xavier NX and the Jetson Nano. This is a Gen 3 PCIe NVMe SSD with x4 lanes.
This is the lspci output snippet from the Nano:
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L1 <8us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (downgraded), Width x4 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
This is the lspci output snippet from the Xavier NX:
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (ok), Width x4 (ok)
As can been seen in the snippets, both Nano and NX use 4 lanes for data transfer. The Nano supports upto Gen2 (500 MB/s/lane) speeds. Whereas the NX supports Gen4 (1.97 GB/s/lane) speed.
I get higher sequential r/w speeds on the Xavier NX. But for random r/w the IOPS is lower on the Xavier NX.
According to the datasheet the SSD should hit the following speeds:
Random Read 4KB IOPS up to (Queues=32, Threads=16) - 165K
Random Write 4KB IOPS up to (Queues=32, Threads=16) - 160K
Actual speeds on Nano:
Random Read 4KB IOPS up to (Queues=32, Threads=16) - 157K
Random Write 4KB IOPS up to (Queues=32, Threads=16) - 162K
Actual speeds on Xavier NX:
Random Read 4KB IOPS up to (Queues=32, Threads=16) - 79.1K
Random Write 4KB IOPS up to (Queues=32, Threads=16) - 63.4K
Both the tests were conducted using our Custom Carrier Board. Can someone please comment on why this might be happening?
Complete lspci -vvvvv output on the Nano:
01:00.0 Non-Volatile memory controller: Sandisk Corp Device 5019 (rev 01) (prog-if 02 [NVM Express])
Subsystem: Sandisk Corp Device 5019
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 83
Region 0: Memory at 13000000 (64-bit, non-prefetchable) [size=16K]
Region 4: Memory at 13004000 (64-bit, non-prefetchable) [size=256]
Capabilities: [80] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [90] MSI: Enable- Count=1/32 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [b0] MSI-X: Enable+ Count=17 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=4 offset=00000000
Capabilities: [c0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
DevCap2: Completion Timeout: Range B, TimeoutDis+, NROPrPrP-, LTR+
10BitTagComp-, 10BitTagReq-, OBFF Not Supported, ExtFmt+, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-, TPHComp-, ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [150 v1] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [1b8 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [300 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
LaneErrStat: 0
Capabilities: [900 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1- ASPM_L1.2+ ASPM_L1.1- L1_PM_Substates+
PortCommonModeRestoreTime=32us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2+ ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=98304ns
L1SubCtl2: T_PwrOn=70us
Kernel driver in use: nvme
Complete lspci -vvvvv output on the Xavier NX:
0005:01:00.0 Non-Volatile memory controller: Sandisk Corp Device 5019 (rev 01) (prog-if 02 [NVM Express])
Latency: 0
Interrupt: pin A routed to IRQ 35
Region 0: Memory at 1f40000000 (64-bit, non-prefetchable) [size=16K]
Region 4: Memory at 1f40004000 (64-bit, non-prefetchable) [size=256]
MaxPayload 256 bytes, MaxReadReq 512 bytes
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
LaneErrStat: 0
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=40us
Complete fio output:
On the Nano with the fio utility I get the below speeds for Random Read 4KB IOPS up to (Queues=32, Threads=16):
fio --loops=1 --size=256m --filename=/dev/nvme0n1p6 --stonewall --ioengine=libaio --direct=1 --name=4kQD32T16RandRead --bs=4096 --rw=randread --iodepth=32 --numjobs=16 --group_reporting
4kQD32T16RandRead: (g=0): rw=randread, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=libaio, iodepth=32
fio-3.17
Starting 16 processes
Jobs: 12 (f=11): [r(1),f(1),r(1),_(1),r(1),_(2),r(8),_(1)][40.0%][r=665MiB/s][r=170k IOPS][eta 00m:09s]
4kQD32T16RandRead: (groupid=0, jobs=16): err= 0: pid=4841: Fri Sep 23 06:30:33 2022
read: IOPS=157k, BW=613MiB/s (642MB/s)(4096MiB/6685msec)
slat (usec): min=9, max=98778, avg=18.41, stdev=291.38
clat (usec): min=73, max=128679, avg=2858.22, stdev=2535.26
lat (usec): min=88, max=128691, avg=2877.22, stdev=2563.12
clat percentiles (usec):
| 1.00th=[ 363], 5.00th=[ 502], 10.00th=[ 1319], 20.00th=[ 1942],
| 30.00th=[ 2212], 40.00th=[ 2442], 50.00th=[ 2638], 60.00th=[ 2900],
| 70.00th=[ 3195], 80.00th=[ 3621], 90.00th=[ 4293], 95.00th=[ 4883],
| 99.00th=[ 7308], 99.50th=[ 8717], 99.90th=[40109], 99.95th=[58459],
| 99.99th=[92799]
bw ( KiB/s): min=488021, max=1060836, per=100.00%, avg=681457.09, stdev=15736.47, samples=178
iops : min=121999, max=265208, avg=170363.24, stdev=3934.14, samples=178
lat (usec) : 100=0.01%, 250=0.38%, 500=4.58%, 750=1.84%, 1000=1.26%
lat (msec) : 2=13.98%, 4=64.30%, 10=13.31%, 20=0.12%, 50=0.16%
lat (msec) : 100=0.06%, 250=0.01%
cpu : usr=4.99%, sys=15.60%, ctx=72393, majf=0, minf=831
IO depths : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=100.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.1%, 64=0.0%, >=64=0.0%
issued rwts: total=1048576,0,0,0 short=0,0,0,0 dropped=0,0,0,0
latency : target=0, window=0, percentile=100.00%, depth=32
Run status group 0 (all jobs):
READ: bw=613MiB/s (642MB/s), 613MiB/s-613MiB/s (642MB/s-642MB/s), io=4096MiB (4295MB), run=6685-6685msec
Disk stats (read/write):
nvme0n1: ios=1043772/0, merge=0/0, ticks=2184252/0, in_queue=2212208, util=99.30%
For Random Write 4KB IOPS up to (Queues=32, Threads=16):
fio --loops=1 --size=256m --filename=/dev/nvme0n1p6 --stonewall --ioengine=libaio --direct=1 --name=4kQD32T16RandWrite --bs=4096 --rw=randwrite --iodepth=32 --numjobs=16 --group_reporting
4kQD32T16RandWrite: (g=0): rw=randwrite, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=libaio, iodepth=32
fio-3.17
Jobs: 14 (f=13): [_(1),f(1),w(6),_(1),w(7)][87.5%][w=617MiB/s][w=158k IOPS][eta 00m:01s]
4kQD32T16RandWrite: (groupid=0, jobs=16): err= 0: pid=4863: Fri Sep 23 06:31:41 2022
write: IOPS=162k, BW=632MiB/s (662MB/s)(4096MiB/6485msec); 0 zone resets
slat (usec): min=8, max=84853, avg=31.68, stdev=606.43
clat (usec): min=24, max=105581, avg=2973.86, stdev=5548.81
lat (usec): min=38, max=170046, avg=3006.24, stdev=5593.56
| 1.00th=[ 515], 5.00th=[ 523], 10.00th=[ 523], 20.00th=[ 529],
| 30.00th=[ 668], 40.00th=[ 1713], 50.00th=[ 2245], 60.00th=[ 2343],
| 70.00th=[ 2802], 80.00th=[ 2933], 90.00th=[ 4113], 95.00th=[ 9896],
| 99.00th=[24511], 99.50th=[33424], 99.90th=[81265], 99.95th=[84411],
| 99.99th=[86508]
bw ( KiB/s): min=363328, max=835232, per=100.00%, avg=668391.54, stdev=8919.44, samples=189
iops : min=90832, max=208808, avg=167097.61, stdev=2229.86, samples=189
lat (usec) : 50=0.01%, 100=0.01%, 250=0.01%, 500=0.03%, 750=33.96%
lat (usec) : 1000=0.20%
lat (msec) : 2=8.64%, 4=46.68%, 10=5.51%, 20=3.34%, 50=1.23%
lat (msec) : 100=0.41%, 250=0.01%
cpu : usr=4.96%, sys=14.35%, ctx=30412, majf=0, minf=357
issued rwts: total=0,1048576,0,0 short=0,0,0,0 dropped=0,0,0,0
WRITE: bw=632MiB/s (662MB/s), 632MiB/s-632MiB/s (662MB/s-662MB/s), io=4096MiB (4295MB), run=6485-6485msec
nvme0n1: ios=134/1036966, merge=0/0, ticks=16/1262248, in_queue=1289604, util=99.29%
For the Xavier NX with the fio utility I get the below speeds for Random Read 4KB IOPS up to (Queues=32, Threads=16):
fio-3.17
Jobs: 4 (f=4): [_(2),r(1),_(1),r(1),_(1),r(1),_(5),r(1),_(3)][86.7%][r=312MiB/s][r=79.7k IOPS][eta 00m:02s]
4kQD32T16RandRead: (groupid=0, jobs=16): err= 0: pid=9101: Thu Sep 22 13:58:18 2022
read: IOPS=79.1k, BW=309MiB/s (324MB/s)(4096MiB/13258msec)
slat (usec): min=4, max=268105, avg=147.07, stdev=2301.29
clat (usec): min=14, max=288124, avg=5764.67, stdev=13569.68
lat (usec): min=98, max=288130, avg=5914.19, stdev=13722.22
| 1.00th=[ 306], 5.00th=[ 355], 10.00th=[ 379], 20.00th=[ 408],
| 30.00th=[ 433], 40.00th=[ 461], 50.00th=[ 498], 60.00th=[ 562],
| 70.00th=[ 873], 80.00th=[ 2147], 90.00th=[ 26084], 95.00th=[ 41681],
| 99.00th=[ 56361], 99.50th=[ 61604], 99.90th=[ 74974], 99.95th=[ 85459],
| 99.99th=[154141]
bw ( KiB/s): min=231623, max=657886, per=100.00%, avg=335004.23, stdev=6833.24, samples=379
iops : min=57905, max=164469, avg=83750.37, stdev=1708.28, samples=379
lat (usec) : 20=0.01%, 100=0.01%, 250=0.16%, 500=50.41%, 750=18.51%
lat (usec) : 1000=1.32%
lat (msec) : 2=6.90%, 4=7.13%, 10=1.38%, 20=2.79%, 50=9.41%
lat (msec) : 100=1.96%, 250=0.02%, 500=0.01%
cpu : usr=1.52%, sys=6.33%, ctx=9445, majf=0, minf=860
READ: bw=309MiB/s (324MB/s), 309MiB/s-309MiB/s (324MB/s-324MB/s), io=4096MiB (4295MB), run=13258-13258msec
nvme0n1: ios=1038873/0, merge=0/0, ticks=190372/0, in_queue=189852, util=99.32%
fio-3.17
Jobs: 8 (f=8): [_(1),w(1),_(1),w(2),_(3),w(1),_(2),w(2),_(1),w(2)][88.9%][w=205MiB/s][w=52.4k IOPS][eta 00m:02s]
4kQD32T16RandWrite: (groupid=0, jobs=16): err= 0: pid=9122: Thu Sep 22 13:58:35 2022
write: IOPS=63.4k, BW=247MiB/s (259MB/s)(4096MiB/16551msec); 0 zone resets
slat (usec): min=4, max=190152, avg=162.65, stdev=2482.81
clat (usec): min=4, max=206981, avg=7282.10, stdev=15583.39
lat (usec): min=20, max=206987, avg=7448.28, stdev=15746.29
| 1.00th=[ 429], 5.00th=[ 441], 10.00th=[ 449], 20.00th=[ 457],
| 30.00th=[ 465], 40.00th=[ 474], 50.00th=[ 486], 60.00th=[ 545],
| 70.00th=[ 668], 80.00th=[ 8225], 90.00th=[ 31851], 95.00th=[ 44303],
| 99.00th=[ 61604], 99.50th=[ 74974], 99.90th=[119014], 99.95th=[141558],
| 99.99th=[196084]
bw ( KiB/s): min=79238, max=442459, per=100.00%, avg=271356.11, stdev=6378.75, samples=480
iops : min=19809, max=110613, avg=67837.91, stdev=1594.69, samples=480
lat (usec) : 10=0.01%, 20=0.01%, 50=0.01%, 100=0.01%, 250=0.01%
lat (usec) : 500=55.64%, 750=15.14%, 1000=1.87%
lat (msec) : 2=1.57%, 4=1.83%, 10=4.86%, 20=5.35%, 50=10.97%
lat (msec) : 100=2.59%, 250=0.19%
cpu : usr=1.37%, sys=5.60%, ctx=15455, majf=0, minf=344
WRITE: bw=247MiB/s (259MB/s), 247MiB/s-247MiB/s (259MB/s-259MB/s), io=4096MiB (4295MB), run=16551-16551msec
nvme0n1: ios=224/1035930, merge=0/0, ticks=24/705740, in_queue=706248, util=95.46%
