Hi Everyone,
My setup is pretty simple: TX1 dev board + Samsung X941 AHCI SSD.
Drive is detected and working at x4, drive is tested on other systems with >1GB/s speeds.
When mounted to the TX1, the read speed I get is good, around 800MB/s, but the write speed is really bad, ~270MB/s.
Now, I saw some other folks have PCIe FPGA mounted with similar issue, see here:
https://devtalk.nvidia.com/default/topic/939528/jetson-tx1/pcie-data-transfer-speed/
So I wonder if this is a TX1 problem. Since the problem looks unidirectional.
I’m also getting an NVMe drive soon and I’ll post results if I see anything better.
Read Test:
ubuntu@tegra-ubuntu:/media/ubuntu/SamXP941AHCI5$ sudo hdparm -Tt /dev/sda
[sudo] password for ubuntu:
/dev/sda:
Timing cached reads: 3804 MB in 2.00 seconds = 1903.91 MB/sec
Timing buffered disk reads: 1528 MB in 3.00 seconds = 509.11 MB/sec
ubuntu@tegra-ubuntu:/media/ubuntu/SamXP941AHCI5$ sudo /sbin/sysctl -w vm.drop_caches=3
vm.drop_caches = 3
ubuntu@tegra-ubuntu:/media/ubuntu/SamXP941AHCI5$ dd if=tempfile of=/dev/null bs=1M count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.1 GB) copied, 1.22961 s, 873 MB/s
Write Test:
ubuntu@tegra-ubuntu:/media/ubuntu/SamXP941AHCI5$ sudo dd bs=1M count=256 if=/dev/zero of=test > ~/dd1M.txt
256+0 records in
256+0 records out
268435456 bytes (268 MB) copied, 0.998564 s, 269 MB/s
lspci -vv :
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: 13000000-130fffff
Prefetchable memory behind bridge: 0000000020000000-00000000200fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v0] #00
Capabilities: [140 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
Kernel driver in use: pcieport
01:00.0 SATA controller: Samsung Electronics Co Ltd XP941 PCIe SSD (rev 01) (prog-if 01 [AHCI 1.0])
Subsystem: Samsung Electronics Co Ltd Device a811
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 130
Region 5: Memory at 13000000 (32-bit, non-prefetchable)
[virtual] Expansion ROM at 20000000 [disabled]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
Capabilities: [50] MSI: Enable- Count=1/2 Maskable+ 64bit+
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR+, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
Capabilities: [d0] Vital Product Data
Not readable
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [150 v1] Power Budgeting <?>
Capabilities: [160 v1] Latency Tolerance Reporting
Max snoop latency: 256ns
Max no snoop latency: 256ns
Kernel driver in use: ahci
