Unexpectedly low read throughput on pcie slot ssd vs m2 slot ssd
We are working with the Nvidia Orin 64GB developer kit on qualifying the performance of applications using the PCIEx16 slot. In one of our test use cases of simulated camera data, we saw unexpectedly low throughput. To further explore whether it was problem with our pcie driver or application, we conducted SSD read benchmarks using FIO, and noticed something odd. For the ssd attached to the m2 slot, we saw in the area of 1900 MiB/s read throughput. For another ssd of the same model connected using a m2-pcie gen3 x4 adapter card, we only got 950 MiB/s read throughput, which is roughly what we achieved with our original camera data test case. We don’t think we are limited by the adapter card, as a gen3 x4 should have far higher bandwidth than 1GB/s. We also tried setting power mode to MAXN, but this had no effect. Does anyone have any thoughts on what might be going on here?
Version info and benchmark results follow:
rmperez@ubuntu:~$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug  1 19:57:35 UTC 2023
rmperez@ubuntu:~$ uname -r
5.10.120-tegra
Read benchmark using pciex16 slot+adapter ssd
rmperez@ubuntu:/media/rmperez/237c20c2-115e-4867-8510-cfbc3c156f12/tmp$ fio --name=fiotest --filename=/media/rmperez/237c20c2-115e-4867-8510-cfbc3c156f12/tmp/read_test --size=16Gb --rw=read --bs=1M --direct=1 --numjobs=8 --ioengine=libaio --iodepth=8 --group_reporting --runtime=60 --startdelay=60
fiotest: (g=0): rw=read, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=libaio, iodepth=8
fio-3.16
Run status group 0 (all jobs):
   READ: bw=950MiB/s (996MB/s), 950MiB/s-950MiB/s (996MB/s-996MB/s), io=55.7GiB (59.8GB), run=60067-60067msec
Benchmark using m2 slot ssd
rmperez@ubuntu:/media/rmperez/Users/rmperez/tests$ fio --name=fiotest --filename=/media/rmperezUsers/rmperez/tests/read_test --size=16Gb --rw=read --bs=1M --direct=1 --numjobs=8 --ioengine=libaio --iodepth=8 --group_reporting --runtime=60 --startdelay=60
fio-3.16
   READ: bw=1884MiB/s (1975MB/s), 1884MiB/s-1884MiB/s (1975MB/s-1975MB/s), io=110GiB (119GB), run=60034-60034msec
lspci dump
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 64
	Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
	I/O behind bridge: 00001000-00001fff [size=4K]
	Memory behind bridge: 40000000-400fffff [size=1M]
	Prefetchable memory behind bridge: [disabled]
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
	Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0
			ExtTag- RBE+
		DevCtl:	CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 16GT/s, Width x1, ASPM not supported
			ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk-
			ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt-
		LnkSta:	Speed 2.5GT/s (downgraded), Width x1 (ok)
			TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
		RootCap: CRSVisible+
		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP+, LTR+
			 10BitTagComp+, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS-, LN System CLS Not Supported, TPHComp-, ExtTPHComp-, ARIFwd+
			 AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
			 AtomicOpsCtl: ReqEn- EgressBlck-
		LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
			 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
	Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
		Vector table: BAR=0 offset=00000000
		PBA: BAR=0 offset=00000000
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
		AERCap:	First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
			MultHdrRecCap+ MultHdrRecEn- TLPPfxPres- HdrLogCap-
		HeaderLog: 00000000 00000000 00000000 00000000
		RootCmd: CERptEn+ NFERptEn+ FERptEn+
		RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
			 FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
		ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
	Capabilities: [148 v1] Secondary PCI Express
		LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
		LaneErrStat: 0
	Capabilities: [158 v1] Physical Layer 16.0 GT/s <?>
	Capabilities: [17c v1] Lane Margining at the Receiver <?>
	Capabilities: [190 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
			  PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
		L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
			   T_CommonMode=10us
		L1SubCtl2: T_PwrOn=10us
	Capabilities: [1a0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
	Capabilities: [2a0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
	Capabilities: [2d8 v1] Data Link Feature <?>
	Capabilities: [2e4 v1] Precision Time Measurement
		PTMCap: Requester:- Responder:+ Root:+
		PTMClockGranularity: 16ns
		PTMControl: Enabled:- RootSelected:-
		PTMEffectiveGranularity: Unknown
	Capabilities: [2f0 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
	Capabilities: [358 v1] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
	Kernel driver in use: pcieport
0001:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
	Subsystem: AzureWave RTL8822CE 802.11ac PCIe Wireless Network Adapter
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Latency: 0, Cache Line Size: 32 bytes
	Interrupt: pin A routed to IRQ 330
	Region 0: I/O ports at 1000 [size=256]
	Region 2: Memory at 20a8000000 (64-bit, non-prefetchable) [size=64K]
		Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
	Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 000000000f410040  Data: 0272
	Capabilities: [70] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
		DevCtl:	CorrErr- NonFatalErr- FatalErr- UnsupReq-
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
			ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s (ok), Width x1 (ok)
			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis+, NROPrPrP-, LTR+
			 10BitTagComp-, 10BitTagReq-, OBFF Via message/WAKE#, ExtFmt-, EETLPPrefix-
			 FRS-, TPHComp-, ExtTPHComp-
			 AtomicOpsCap: 32bit- 64bit- 128bitCAS-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+, LTR+, OBFF Disabled
		LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
			MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
	Capabilities: [148 v1] Device Serial Number 00-e0-4c-ff-fe-c8-22-01
	Capabilities: [158 v1] Latency Tolerance Reporting
		Max snoop latency: 0ns
		Max no snoop latency: 0ns
	Capabilities: [160 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
			  PortCommonModeRestoreTime=30us PortTPowerOnTime=60us
			   T_CommonMode=0us LTR1.2_Threshold=0ns
	Kernel driver in use: rtl88x2ce
	Kernel modules: rtl8822ce
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 66
	I/O behind bridge: [disabled]
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
		Masking: 00000000  Pending: 00000000
			ExtTag- RBE+
			MaxPayload 256 bytes, MaxReadReq 512 bytes
		LnkCap:	Port #0, Speed 16GT/s, Width x4, ASPM not supported
		LnkSta:	Speed 8GT/s (downgraded), Width x4 (ok)
			TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt+
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
			 EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
	Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
		Vector table: BAR=2 offset=00000000
		PBA: BAR=2 offset=00010000
		LaneErrStat: 0
	Capabilities: [168 v1] Physical Layer 16.0 GT/s <?>
	Capabilities: [18c v1] Lane Margining at the Receiver <?>
	Capabilities: [1ac v1] L1 PM Substates
			   T_CommonMode=60us
	Capabilities: [1bc v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
	Capabilities: [2bc v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
	Capabilities: [2f4 v1] Data Link Feature <?>
	Capabilities: [300 v1] Precision Time Measurement
		PTMCap: Requester:+ Responder:+ Root:+
	Capabilities: [30c v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
	Capabilities: [374 v1] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
0004:01:00.0 Non-Volatile memory controller: Toshiba Corporation Device 0116 (prog-if 02 [NVM Express])
	Subsystem: Toshiba Corporation Device 0001
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Latency: 0
	Region 0: Memory at 2428000000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [40] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L1 <32us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 8GT/s (ok), Width x4 (ok)
		DevCap2: Completion Timeout: Range AB, TimeoutDis+, NROPrPrP-, LTR+
			 10BitTagComp-, 10BitTagReq-, OBFF Not Supported, ExtFmt+, EETLPPrefix-
		LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
	Capabilities: [80] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
	Capabilities: [90] MSI: Enable- Count=1/32 Maskable+ 64bit+
	Capabilities: [b0] MSI-X: Enable+ Count=32 Masked-
		Vector table: BAR=0 offset=00002000
		PBA: BAR=0 offset=00003000
		UESvrt:	DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		AERCap:	First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
	Capabilities: [260 v1] Latency Tolerance Reporting
	Capabilities: [300 v1] Secondary PCI Express
		LaneErrStat: 0
	Capabilities: [400 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1- ASPM_L1.2+ ASPM_L1.1- L1_PM_Substates+
			  PortCommonModeRestoreTime=60us PortTPowerOnTime=100us
	Kernel driver in use: nvme
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1) (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 68
			ExtTag- RBE+
		LnkCap:	Port #0, Speed 16GT/s, Width x8, ASPM not supported
		LnkSta:	Speed 8GT/s (downgraded), Width x4 (downgraded)
		LaneErrStat: 0
	Capabilities: [190 v1] Lane Margining at the Receiver <?>
	Capabilities: [1c0 v1] L1 PM Substates
			   T_CommonMode=60us
	Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
	Capabilities: [2d0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
	Capabilities: [308 v1] Data Link Feature <?>
	Capabilities: [314 v1] Precision Time Measurement
	Capabilities: [320 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
	Capabilities: [388 v1] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
0005:01:00.0 Non-Volatile memory controller: Toshiba Corporation Device 0116 (prog-if 02 [NVM Express])
	Latency: 0
	Region 0: Memory at 2b28000000 (64-bit, non-prefetchable) [size=16K]
		LaneErrStat: 0
Are you talking about a specific SSD may have low performance?
I’m more concerned why SSDs of the same model perform so differently when connected via the m2 slot or pcie slot. This to me implies the pcie route may have performance limitations when used for other purposes. I can find out the exact model of SSD if it helps.
Please also try other kind of SSD and see if you observe the same thing.
We do see some cases that the GPIO on M.2 slot makes specific SSD becomes lower perf due to those pins are in use by such SSD.
Interesting. Using a different SSD from XPG does give better performance, roughly equivalent at 1.7 GB/s using either the adapter card or the m2 slot. So your suggestion about the GPIO appears to be correct.
However, I will add that the same ssd using the adapter card on a different x86 system gave considerably better performance at 2.3 GB/s, which I am not sure if it is particularly unusual. Our endgoal is to port our application processing camera data from a different platform, which was somewhat unsuccessful due to degraded performance. But perhaps that is better addressed in a separate post now that this test of using SSD benchmarks does not actually show similar degradation.
