I have a camera producing an eglstream with the Jetson MM API (using libargus and inspiration from the argus player I’ve created a preview stream),
I’ve followed the eglstream cube example to create a pipeline that can communicate via unix sockets.
Now I want to extract images from the stream and I’m wondering if there is an elegant solution for that? (i.e. is there an example I an use like an implementation of NV_stream_consumer_eglimage or is there a different method? )
My Final Aim is to create a gstreamer DL pipeline (for a High FPS and high res Images as I can push)
I will need to consume the same image in different nodes therefore need to avoid replication as much as I can as I’m dealing with multiple image streams from sources.
Cheers,
Ganindu.
