I have a CUDA-based EGLStream producer that needs to connect to a consumer based on NvVideoEncoder. The CUDA producer connects to a EGLStreamKHR that will be provided to the encoder consumer for it to also connect to, but I cannot figure out how to acquire frames out of the EGLStreamKHR stream, and map them to an NvBuffer.
The only examples showing consumers using a EGLStreamKHR are based on GL textures, which seems to have specific calls for mapping EGL frames from the stream to GL and acquiring them, e.g. eglStreamConsumerGLTextureExternalKHR() and eglStreamConsumerAcquireKHR().
The “EGL_KHR_stream - Khronos Group” spec mentions acquiring frames via eglStreamConsumerAcquireAttribKHR(), but is not clear on how to get the actual pointer to the frame. The 10_camera_recording example is helpful, but only covers how to map between Argus::Buffer and NvBuffer, while I am looking for a more generic solution that deals with EGLStreamKHR directly.
Please note that I realize that I can use Gstreamer via nveglstreamsrc to consume the frames, however I would prefer to use NvVideoEncoder directly. Can anyone please explain how to acquire a frame out of an EGLStreamKHR stream and map it to an NvBuffer, so it can be encoded by NvVideoEncoder?
