In the GST Plugin DS-Example. I could get NvDsBatchMeta of PGIE(and get its tensor metadata ) but I also want the infer tensor metadata of SGIE in the same gst-plugin.
what is your pipeline, the ds-example should be after the sgie plugin if you want to access the sgie metadata
pgie>sgie>dsexample. I was able to find the sgie tensor meta data inside obj_user_meta_list even though I set SGIE process-mode to 1. Now my problem is that SGIE does not run if PGIE(yolo detector) fails. Is there any way to decouple them?
Hey abrar, Pls create a new topic for the new problem.
