• Hardware Platform - Jetson
• DeepStream Version - 5.0
How do I access source_id / stream_id inside process_meta function of deepstream_app.c without disabling Tiler?
@prerana5626
My solution was to move the tiler until after I had done what I needed with the metadata. Removing it entirely wasn’t necessary in my case. My app is not deepstream_app, but you might be able to use a similar strategy to accomplish what you want.
May I know where do i have to move the tiler?
I moved below code,
if (!create_processing_instance(appCtx, i))
goto done;
Above tiler and below streammux
Yet no change
By moving the tiler, I mean to change the link order. You’ll have to find where the tiler is linked (with gst_element_link), and change the order. I would recommend following the GStreamer tutorials to gain the necessary knowledge to accomplish this task, and I don’t know whether this approach is applicable to DeepStream app. You’ll have to investigate yourself :)
