can you provide a comprehensive, step-by-step solution for kernel compile, adding correct driver, update device tree , etc for use tc358743(B101) in jetson nano (with developer kit A02)?
You will be of great help to me if you can provide a comprehensive solution.
I wish you all the best:)
BTW,
here’s user able to stream tc358743 on Nano, you may also refer to Topic 116101 for reference.
due to tc358743 is one HDMI2CSI bridge driver, it always helps to enable a test-pattern-generator, which could help to narrow down the issue.
thanks
