Description
I have a Jetson Xavier NX. I am trying to run instan ce segmentation using tensor rt . However, I am getting the rror as shown below. I am following he exact instructions as shown in the github readme of the same. I want to run instance segmentation on the coco dataset. I have installed all the necesasry modules . I am unsure why it is not able to convert the model
Environment
GPU Type: Jetson Xavier NX GPU
Nvidia Driver Version: -
CUDA Version: 10.2.89
CUDNN Version: 8.0.0
Operating System + Version: Ubuntu 18.04 LTS
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 1.15.4
PyTorch Version (if applicable): -
Baremetal or Container (if container which image + tag): -
Relevant Files
Steps To Reproduce
Followed the steps as mentioned in Segmentation using Tensor RT
Please include:
This is the error
File “mrcnn_to_trt_single.py”, line 164, in
main()
File “mrcnn_to_trt_single.py”, line 113, in main
model = modellib.MaskRCNN(mode=“inference”, model_dir=LOG_DIR, config=config).keras_model
File “/usr/local/lib/python3.6/dist-packages/mask_rcnn-2.1-py3.6.egg/mrcnn/model.py”, line 1837, in init
File “/usr/local/lib/python3.6/dist-packages/mask_rcnn-2.1-py3.6.egg/mrcnn/model.py”, line 1901, in build
File “/usr/local/lib/python3.6/dist-packages/mask_rcnn-2.1-py3.6.egg/mrcnn/model.py”, line 180, in resnet_graph
File “/home/nvidia/.local/lib/python3.6/site-packages/keras/engine/topology.py”, line 590, in call
self.build(input_shapes[0])
File “/home/nvidia/.local/lib/python3.6/site-packages/keras/layers/convolutional.py”, line 129, in build
raise ValueError('The channel dimension of the inputs ’
ValueError: The channel dimension of the inputs should be defined. Found None
