I have a camera that produces real-time AV feed and I connect it to ClearClick to convert AV in to USB and connect it to Jetson ORIN NX 16G. When I use OBS Studio on Jetson to test the connectivity to record a video, the mkv video is black.
My eventual goal is to save photos of the video feed on Jetson and process them with Python OpenCV.
Is ClearClick the correct converter for this purpose? Do you suggest a different converter?
ClearClick Video to USB 1080P Audio Video Capture & Live Streaming Device - Input HDMI, AV, RCA, S-Video, VCR, VHS, Camcorder, Video8, Hi8, DVD, Gaming Systems - USB-C Plug & Play
Thanks for your response. Does it mean ClearClick should be able to transfer the AV in (via yellow) video feed to USB to Jetson?
I wasn’t sure what you meant by supporting “UVC” driver and its relation to AV in and ClearClick.
And see if your device is listed. If it is listed, you should be able to capture frame data through v4l2-ctl command or gstreamer command with v4l2src plugin.
