I started to have the problem:
GPG error: Kitware APT Repository focal InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 1A127079A92F09ED
I saw a solution posted on github
opened 12:59PM - 22 Jan 23 UTC
closed 04:52PM - 07 Feb 23 UTC
bug
verify to close
I am trying to run apt update.
Sending build context to Docker daemon 4… 3.05MB
Step 1/14 : ARG BASE_IMAGE
Step 2/14 : FROM ${BASE_IMAGE}
---> 3671296a1bac
Step 3/14 : RUN apt-get update && apt-get install -y curl gnupg2 lsb-release && rm -rf /var/lib/apt/lists/* && apt-get clean
---> Running in 27f60d4ba1cd
Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
Get:3 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Hit:5 http://ppa.launchpad.net/mosquitto-dev/mosquitto-ppa/ubuntu focal InRelease
Get:6 http://archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
Hit:7 http://packages.ros.org/ros2-testing/ubuntu focal InRelease
Hit:1 https://repo.download.nvidia.com/jetson/x86_64/focal r35.1 InRelease
Get:8 https://apt.kitware.com/ubuntu focal InRelease [15.5 kB]
Hit:9 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64 InRelease
Err:8 https://apt.kitware.com/ubuntu focal InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 42D5A192B819C5DA
Hit:10 https://packagecloud.io/github/git-lfs/ubuntu focal InRelease
Reading package lists...
W: GPG error: https://apt.kitware.com/ubuntu focal InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 42D5A192B819C5DA
E: The repository 'https://apt.kitware.com/ubuntu focal InRelease' is not signed.
The command '/bin/bash -c apt-get update && apt-get install -y curl gnupg2 lsb-release && rm -rf /var/lib/apt/lists/* && apt-get clean' returned a non-zero code: 100
Failed to build base image: isaac_ros_dev-x86_64, aborting.
It fails due to some GPG error. Any image I based on this image will have errors running apt update, which means that apt update && ... always fails.
After quick web surfing, I found a popular fix:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 42D5A192B819C5DA
sudo apt-get update
But it didn't help..
But it’s not clear where I add it as the docker file appears to be built via script.
Thanks @lowellm
I’m following your issue with the engineering.
Raffaello
I should say after that I get:
6.803 E: The repository ‘Kitware APT Repository focal InRelease’ is not signed.
So basically it doesn’t work to download the key, people talked about modifying the docker file but as far as I see the docker file doesn’t exist, it’s built by the build script.
Hi @lowellm
I’m building an Isaac ROS docker from scratch and don’t see the GPG error on Kitware.
How are you making/building your docker?
I followed the instructions back when I first installed it, I believe I downloaded the premade docker image? I corrected the error via the github link via modifying the docker file but it shouldn’t be required.
maybe it was stored on your device in an old docker version.
Using the latest image everything works correctly.
system
Closed
May 17, 2024, 2:28pm
7
