I am using ubuntu 18.04 machine.
File “/home/ayyappan/ingame/ptp/nvidia_nx_baseline_bsp/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash.py”, line 1280, in
tegraflash_run_commands()
File “/home/ayyappan/ingame/ptp/nvidia_nx_baseline_bsp/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash.py”, line 1149, in tegraflash_run_commands
interpreter.onecmd(command)
File “/usr/lib/python3.10/cmd.py”, line 217, in onecmd
return func(arg)
File “/home/ayyappan/ingame/ptp/nvidia_nx_baseline_bsp/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash.py”, line 665, in do_sign
tegraflash_sign_binary(exports, args)
File “/home/ayyappan/ingame/ptp/nvidia_nx_baseline_bsp/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 757, in tegraflash_sign_binary
filename = tegraflas_oem_sign_file(temp_file, magicid)
File “/home/ayyappan/ingame/ptp/nvidia_nx_baseline_bsp/L4T_dev/L4T_bsp/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2109, in tegraflas_oem_sign_file
for file_nodes in xml_tree.getiterator(‘file’):
AttributeError: ‘ElementTree’ object has no attribute ‘getiterator’
Error: Unable to find the signed file generated by tegraflash.py
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0012 ] Generating signature
[ 0.0016 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0019 ] Assuming zero filled SBK key
[ 0.0020 ]
[ 0.0021 ] header_magic: d00dfeed
[ 0.0023 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-p3668-all-p3509-0000.dtb
[ 0.0026 ]
[ 0.0029 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_tegra194-p3668-all-p3509-0000.dtb zerosbk
[ 0.0032 ] adding BCH for 1_tegra194-p3668-all-p3509-0000.dtb
[ 0.0075 ]
[ 0.0081 ] tegrasign_v2 --key --list 1_tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0084 ] Assuming zero filled SBK key
[ 0.0088 ]
return func(arg)
cp: cannot stat ‘kernel/Image.sig’: No such file or directory
cp: cannot stat ‘kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.sig’: No such file or directory
