I am having difficultuy setting compiling the kernel from source.
I have followed the guide to manually downloading the kernel; following all the steps listed in an explict manner. This does compile, but when it is flashed onto the unit it experiances a range of problem. I have tried both the tarball available on the Nvidia site and also the Git respository.
Please could you advise, is there a step that I might be missing?
Maybe you should provide what is the problem you have.
It does not provide much info with just the link to the document.
For example, why other people can work fine with same document but you cannot? I don’t know either.
I need your log or symptom of your problem to tell what might happen.
Could you flash your device back to original jetpack again, rebuild the kernel with step 1~8 and directly copy the Image to /boot/Image on your device and then reboot?
I mean we don’t use flash.sh to re-flash system to update kernel this time.
The quiet mode is not for dmesg. It is for the uart log. What you are sharing now is just kernel part. It is helpful but not complete. How to dump the uart log is listed in previous link.
And from the dmseg, I have few questions for your log.
Didn’t you see the kernel panic from the nvgpu as your log shared 6 hour ago? Is that panic still happened?
How do you update the kernel now? Directly change the /boot/Image?
From your bad and working case, it seems still the gpu driver issue. The bad one does not have nvgpu running. Without gpu driver, desktop cannot come up.
To answer both questions, this is using a freshly compiled Image that was place onto the Jetson in the boot folder. The Kernel panic was occuring when the unit was flashed with ./flash utility, but seems ok now by mannually installing the kernel Image.
It seems sometimes after a reboot the HDMI outputs a console, but no graphical interface.
Can you just share a full log at once? I don’t know if you do this on purpose or this is just no log coming out.
After the bootloader log coming out, there should be kernel log following up. When “quiet” is set, this part of log will be in silent. That is why I asked you to remove it. But now you only shared partial kernel log.
I just want a full log which includes bootloader + kernel parts. Can you provide such log?
