Getting the jetson FFMpeg compiling
Hi Everyone,
I tried installing the hardware-accelerated ffmpeg working for the Jetson, available here: GitHub - jocover/jetson-ffmpeg: ffmpeg support on jetson nano
I have gotten this working before, but now when I try and run the cmake, I get this error:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
LIB_V4L2
    linked by target "nvmpi" in directory /home/tombert/jetson-ffmpeg
-- Configuring incomplete, errors occurred!
See also "/home/tombert/jetson-ffmpeg/build/CMakeFiles/CMakeOutput.log".
See also "/home/tombert/jetson-ffmpeg/build/CMakeFiles/CMakeError.log".
Is there some library that I need to install?
You may have a look to this script.
Thank Honey_Patouceul for the suggetion.
One potential issue is mismatch of header files. Please remember to update the header files to the release version. Reference:
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
