Hi @Morganh ,
I have converted one model from tlt to onnx. But when I am performing inference then It is giving me multiple b-boxes. Please suggest where I am making mistake. Below is the code.
`import onnxruntime as ort
import onnx
import cv2
import numpy as np
def validate_onnx_model(model_onnx_path):
try:
onnx_model = onnx.load(model_onnx_path)
onnx.checker.check_model(onnx_model)
print("ONNX model is valid.")
return True
except Exception as e:
print(f"ONNX model validation failed: {e}")
return False
def model_detection_init(model_onnx_path):
try:
session = ort.InferenceSession(model_onnx_path)
input_name = session.get_inputs()[0].name
output_names = [output.name for output in session.get_outputs()]
input_shape = session.get_inputs()[0].shape
detection_height, detection_width = input_shape[2], input_shape[3]
return session, input_name, output_names, detection_height, detection_width
print("Exception in Detection model load:", e)
return None
model_h = 544
model_w = 960
stride = 16
box_norm = 35.0
grid_h = int(model_h / stride)
grid_w = int(model_w / stride)
grid_size = grid_h * grid_w
grid_centers_w = [(i * stride + 0.5) / box_norm for i in range(grid_w)]
grid_centers_h = [(i * stride + 0.5) / box_norm for i in range(grid_h)]
def applyBoxNorm(o1, o2, o3, o4, x, y):
o1 = (o1 - grid_centers_w[x]) * -box_norm
o2 = (o2 - grid_centers_h[y]) * -box_norm
o3 = (o3 + grid_centers_w[x]) * box_norm
o4 = (o4 + grid_centers_h[y]) * box_norm
return o1, o2, o3, o4
def postprocess(outputs, min_confidence, analysis_classes, wh_format=True):
bbs = []
class_ids = []
scores = []
for c in analysis_classes:
x1_idx = c * 4 * grid_size
y1_idx = x1_idx + grid_size
x2_idx = y1_idx + grid_size
y2_idx = x2_idx + grid_size
boxes = outputs[0]
for h in range(grid_h):
for w in range(grid_w):
i = w + h * grid_w
score = outputs[1][c * grid_size + i]
if score >= min_confidence:
o1 = boxes[x1_idx + w + h * grid_w]
o2 = boxes[y1_idx + w + h * grid_w]
o3 = boxes[x2_idx + w + h * grid_w]
o4 = boxes[y2_idx + w + h * grid_w]
o1, o2, o3, o4 = applyBoxNorm(o1, o2, o3, o4, w, h)
xmin = int(o1)
ymin = int(o2)
xmax = int(o3)
ymax = int(o4)
if wh_format:
bbs.append([xmin, ymin, xmax - xmin, ymax - ymin])
else:
bbs.append([xmin, ymin, xmax, ymax])
class_ids.append(c)
scores.append(float(score))
return bbs, class_ids, scores
NUM_CLASSES = 3
threshold = 0.01
def vehicle_detection(frames, session, input_name, output_names, detection_height, detection_width):
try:
input_images = np.stack([cv2.resize(image, (detection_width, detection_height)) for image in frames])
input_images = input_images.transpose((0, 3, 1, 2)).astype(np.float32)
results = session.run(output_names, {input_name: input_images})
score_info = results[1].reshape(6120)
output_tensor = np.squeeze(results[0])
outputs = output_tensor.reshape(24480)
bboxes, class_ids, scores = postprocess([outputs, score_info], threshold, list(range(NUM_CLASSES)))
print("bboxes : ",class_ids)
# Filter out boxes with low confidence scores
filtered_bboxes = []
filtered_class_ids = []
filtered_scores = []
for i, score in enumerate(scores):
print("score : ",score)
if score >= threshold:
filtered_bboxes.append(bboxes[i])
filtered_class_ids.append(class_ids[i])
filtered_scores.append(score)
# Apply NMS
if len(filtered_bboxes) > 0:
# Adjust these parameters based on your requirements
nms_threshold = 0.4 # overlapThreshold
score_threshold = threshold # scoreThreshold
# Convert bounding boxes to the format required by NMSBoxes
bboxes = np.array(filtered_bboxes)
scores = np.array(filtered_scores)
# Apply NMS
indices = cv2.dnn.NMSBoxes(bboxes.tolist(), scores.tolist(), score_threshold, nms_threshold)
print("indices : ",indices)
# Draw remaining boxes after NMS
for idx in indices:
idx = int(idx)
xmin, ymin, w, h = filtered_bboxes[idx]
print("xmin, ymin, w, h ",xmin, ymin, w, h)
if xmin > 0 and ymin > 0:
class_id = filtered_class_ids[idx]
color = [255, 0, 0] if class_id else [0, 0, 255]
cv2.rectangle(frames[0], (xmin, ymin), (xmin + w, ymin + h), color, 2)
cv2.imwrite("image1.jpg", frames[0])
else:
print("No valid detections after score filtering.")
print("Exception in vehicle detection:", e)
# Path to the ONNX model file
detection_model_onnx_path = '/home/smarg/Documents/openvino_container/MODEL/VehicleDetection_MobileNetV1_ReTrained_V1.6.onnx'
if validate_onnx_model(detection_model_onnx_path):
session, input_name, output_names, detection_height, detection_width = model_detection_init(detection_model_onnx_path)
if session:
img = './input_image.jpg'
frames = [cv2.imread(img)]
else:
print("Failed to initialize the detection model.")
else:
print("ONNX model validation failed.")
Below is the output image.
Please suggest.
