GLM-5.3-Flash running on 2x DGX Spark (sm_121) day-0 - 24.7-30.3 tok/s with MTP-5; two silent GB10 gotchas worth knowing
GLM-5.3-Flash (320B/18B-active, released yesterday) is serving on a pair of DGX Sparks — as far as I can find, the first published deployment of this model on GB10. The vendor recipe verifies H100/B200/GB200 only, and the arch (glm5_next: NoPE sparse-MLA + KDA linear attention) fails every attention backend the sm_121 selector offers, out of the box.
Full recipe, the vLLM mod, and honest measured numbers here:
Measured (median of 3, temp 0, single stream): 24.74 code / 30.30 structured / 19.58 prose tok/s with the checkpoint’s own MTP head at num_speculative_tokens=5 (acceptance length ~2.55). No-spec baseline is 14.6 flat — decode is MoE-bandwidth-bound on this box, CUDA graphs bought 2%, the drafter bought 1.3-2x. Needle recall exact at 8,443 tokens deep. Stock DGX Spark OS, stock per-model vLLM image (glm53-flash-arm64-cu130), no kernel builds.
Two findings that generalize beyond this model:
  1. SILENT FP4 MoE corruption on sm_121. The auto-selected FLASHINFER_CUTLASS NvFp4 MoE backend produces degenerate output (repeated-token loops from the first generated token) with zero errors — model loads, /health green, every completion garbage. This is the quiet sibling of the documented cudaErrorNoKernelImageForDevice gap. --moe-backend marlin fixes it. If your GB10 NVFP4 deployment “works” but outputs loops, check which MoE backend engaged before blaming your quant.
  2. A 60+ minute “No available shared memory broadcast block found” loop during engine boot is not necessarily a hang. Check the worker’s CPU first: at 150%+ it’s FlashInfer autotuning a kernel flavor with no cached tune (the tune persists to ~/.cache/vllm, so it pays once). We killed two perfectly healthy boots before figuring this out.
The core of the recipe is a small 4-part Python mod that dresses GLM’s NoPE-MLA (kv_lora 512 + rope 0) in DeepSeek’s fp8_ds_mla layout (512 + 64): construct the attention layer with rope=64, zero-pad q/k_pe at the handoff (zeros are rotation-invariant and add exactly 0 to every logit), and compact the kpool indexer’s 2176-wide top-k table to the compiled kernel’s 2048 (keeping the always-select-tail entries, which by construction never duplicate the main selection). Everything after that is the tested DeepSeek path.
Known limits, honestly: 32K ctx cap at publish time (probing 256K as I write this — the topk.cu shared-memory sizing issue on GB10 at long context is documented in the vllm#45317 thread), text-only (–language-model-only — the multimodal processor balloons the API front-end to 15.7 GB anon and the kernel OOM-kills it), single stream. When TRITON_MLA_SPARSE for SM12x (vllm#38476) or glm5_next mainlining (vllm#53906) lands, the mod retires.
Credits in the repo: LibertAIDAI’s NVFP4 quant (whose model card’s GB10 note was half the answer), the eugr/a3refaat spark-vllm-docker tooling, and the GLM-5.2 GB10 sparse-MLA work from CosmicRaisins/0xdfi that mapped this terrain.
Follow-up on the context cap: 256K is now runtime-proven.
Rebooted the same config at --max-model-len 262144 and ran a needle ladder at temp 0 (unique code planted mid-document, exact-match required):
Great job!
The tough question now - is it better in NVFP4 than Deepseek V4 Flash 0731 Full on 2 Sparks?
My bet - it’s not :)
I had a chances to use 5.2 (NVFP4) and that one was a beast, if 5.3 flash with vision is really better than 5.2, then it will blown DSV4Flash out of the board…
working overtime to make it as best as possible so when we get dflash/dspark should get 50tk/s prose and 70 tk/s with code tasks
lets do it we can divide and Conquer. Give me some areas you think might help improve it. I’m down to work with you.
Send me DM, is more efficient than spamming this thread…
