I want to build a simple video logging system that can read GMSL2 camera and log the raw image stream. I wonder if a Jetson TX2/TX1 platform can support this application. Moreover can some one suggest any material that can help me out in calculating maximum amount of data/sec one can log? I also want to identify the major bottleneck in the system.
may I have more details about which JetPack release you’re working with.
may I know which data you would like to calculated? for example, pixel clock?
I am not using any JetPack release yet neither I have any hardware at this stage. I was just trying to evaluate if it is possible to log a camera giving up to 6Gbps (on GMSL2) using a Jetson evaluation kit.
