GNOME applications seem to not start with nvidia driver. Particularly Videos (Totem), and I also suspect Cheese is also the case. The application neither start from the desktop environment nor command line.
Totem developers, based on GNOME/Videos stacktrace, suggest it is a bug in nvidia libGL implementation, could you please verify that?
GNOME/Videos stacktrace used:
Thread 1 (Thread 0x7ffff7fb0a40 (LWP 3521)):
#0 0x000000318280b17e in __pthread_mutex_unlock_usercnt (decr=1,
mutex=0x3182220908 <_rtld_local+2312>) at pthread_mutex_unlock.c:57
#1 __GI___pthread_mutex_unlock (mutex=0x3182220908 <_rtld_local+2312>)
at pthread_mutex_unlock.c:310
#2 0x0000003182001099 in tls_get_addr_tail (ti=0x3184620f58,
dtv=0x7ffff7fb1350, the_map=0x7ffff7fc8560) at dl-tls.c:730
#3 0x0000003184410d0e in getprocattrcon_raw () from /lib64/libselinux.so.1
#4 0x000000318440aa6e in is_selinux_enabled () from /lib64/libselinux.so.1
#5 0x000000318aca5da6 in ?? () from /usr/lib64/nvidia-304xx/libGL.so.1
#6 0x000000318ac8505b in ?? () from /usr/lib64/nvidia-304xx/libGL.so.1
#7 0x000000318200f29d in call_init (l=0x7ffff7fbf4e0, argc=argc@entry=1,
argv=argv@entry=0x7fffffffe218, env=env@entry=0x7fffffffe228)
at dl-init.c:67
#8 0x000000318200f3c3 in call_init (env=,
argv=, argc=, l=)
at dl-init.c:34
#9 _dl_init (main_map=0x3182221168, argc=1, argv=0x7fffffffe218,
env=0x7fffffffe228) at dl-init.c:130
#10 0x000000318200122a in _dl_start_user () from /lib64/ld-linux-x86-64.so.2
#11 0x0000000000000001 in ?? ()
#12 0x00007fffffffe509 in ?? ()
—Type to continue, or q to quit—
#13 0x0000000000000000 in ?? ()
(gdb)
Related bugreport can be found in https://bugzilla.gnome.org/show_bug.cgi?id=734044
Thank you for any help.
nvidia-bug-report.log.gz (73.1 KB)
