Hello, I am a user using whisper Ai with google corab.
An error code occurs when I run Colab with the code. What steps should I take to prevent the error from occurring?
1.from google.colab import drive
drive.mount(‘/content/drive’,force_remount=True)
2.!pip install git+https://github.com/openai/whisper.git
!sudo apt update && sudo apt install ffmpeg
!pip install git+https://github.com/jianfch/stable-ts.git
!pip install tensorflow
!pip install --upgrade setuptools pip wheel
!pip install nvidia-pyindex
!pip install nvidia-cuda-runtime-cu12
!sudo apt-get install docker-ce
2023-02-13 12:30:15.230263: I tensorflow/core/platform/cpu_feature_guard.cc:193] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX2 AVX512F FMA
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2023-02-13 12:30:16.870635: W tensorflow/compiler/xla/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘libnvinfer.so.7’; dlerror: libnvinfer.so.7: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/lib64-nvidia
2023-02-13 12:30:16.870769: W tensorflow/compiler/xla/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘libnvinfer_plugin.so.7’; dlerror: libnvinfer_plugin.so.7: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/lib64-nvidia
2023-02-13 12:30:16.870790: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:38] TF-TRT Warning: Cannot dlopen some TensorRT libraries. If you would like to use Nvidia GPU with TensorRT, please make sure the missing libraries mentioned above are installed properly.
