I got the following error when I dynamically delete a running uridecodebin for a camera.
Calling Stop 3
STATE CHANGE SUCCESS
STATE CHANGE SUCCESS 0x7e800221b0
ERROR from element source: Unhandled error
Error details: gstrtspsrc.c(6161): gst_rtspsrc_send (): /GstPipeline:dstest-pipeline/GstURIDecodeBin:source-bin-03/GstRTSPSrc:source:
Option not supported (551)
Returned, stopping playback
Deleting pipeline
I saw some others post this issue long time ago on DS5.0.1. Now I am facing the same issue on DS6.1.1. Have you figuring out any update/patch for this issue yet ? Thank you very much !
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I am running example runtime_source_add_delete (https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/runtime_source_add_delete) using deepstream:6.1.1-triton docker image.
I tried DS6.2 but still the same issue. My issue is similar to another post on forum: Delete source dynamically error
I also tried to follow the recommendations from this post but none of those work for me, so I repost to ask for help.
I read very carefully the source: deepstream_test_rt_src_add_del.c and I saw that the delete_source callback only delete the rtsp streams which have EOS signal.
We have tested with our RTSP sources, we can not reproduce your failure. Can you tell us how to reproduce your issue?
=> Hi Fiona, to reproduce the issue: please recompile the example https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps/tree/master/runtime_source_add_delete and try with RTSP input source from Hikvision camera.
I created a streaming server to streamout rtsp from video file and it ran ok without this issue. So the issue occurs only with camera (hikvision).
We don’t have such cameras. It seems RTSP server(camera) compatibility issue. Is there detailed debug log for the failure? Please use “export GST_DEBUG=rtspsrc:7” to enable the debug log.
=> Yes, I create a function which call eos signal on the camera source pad. And I saw the “bus_callback” catched the eos signal corresponding to the camea source. After that the “stop_release_source” function was invoked and flush → release request pad ok. But then after that I got the same issue above:
Calling Stop 3
Deleting pipeline
=> This must be caused by the camera source streaming protocol incompatibility.
The log shows the RTSP server(the camera) send a “Option not supported” response with the client(DeepStream app)'s request for closing. Please check your RTSP server(the camera). The RTSP client(GStreamer rtspsrc) is strictly following RFC2326. RFC 2326: Real Time Streaming Protocol (RTSP) (rfc-editor.org)
