Deepstream6.4 runtime add delete error
Quadro RTX 6000 * 2
• DeepStream Version
deepstream6.4
When I added the first source:
Warning: gst-stream-error-quark: No decoder available for type ‘application/x-rtp, media=(string)application, payload=(int)107, clock-rate=(int)90000, encoding-name=(string)VND.ONVIF.METADATA, decodertag=(string)“h3c-v3\ RTCP=0”, a-recvonly=(string)“”, ssrc=(uint)31766572, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false’. (6): …/gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-01
When I added the second source:
Warning: gst-stream-error-quark: No decoder available for type ‘application/x-rtp, media=(string)application, payload=(int)107, clock-rate=(int)90000, encoding-name=(string)VND.ONVIF.METADATA, decodertag=(string)“h3c-v3\ RTCP=0”, a-recvonly=(string)“”, ssrc=(uint)154311474, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false’. (6): …/gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-02
At this point, in addition to the initialized flow, there are two flows in the pipeline that are being analyzed normally.
Then,
When I deleted one of the streams
The following error occurred,
But in fact, I think the pipeline has successfully deleted this
(python3:4739): GStreamer-CRITICAL **: 14:39:57.109: Element Stream-muxer already has a pad named sink_2, the behaviour of gst_element_get_request_pad() for existing pads is undefined!
stop sikpad= <gi.GstNvStreamPad object at 0x7fdc95a6d480 (GstNvStreamPad at 0x7fda2c011180)>
Error: gst-resource-error-quark: Unhandled error (9): …/gst/rtsp/gstrtspsrc.c(6795): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-02/GstRTSPSrc:source:
ServerInternal (500)
After that, I won’t be able to add source to the pipeline anymore
When I added the source, the following error occurred. The source was indeed not added, but the source of the original pipeline is still being analyzed normally
Error: gst-resource-error-quark: Could not write to resource. (10): …/gst/rtsp/gstrtspsrc.c(8346): gst_rtspsrc_close (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-02/GstRTSPSrc:source:
Could not send message. (Generic error)
Warning: gst-resource-error-quark: Could not read from resource. (9): …/gst/rtsp/gstrtspsrc.c(5819): gst_rtspsrc_loop_udp (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-03/GstRTSPSrc:source:
The server closed the connection.
add_source 、stop_source just like this
    def _stop_source(self, task_data, content=None):
        if task_data["source_id"] == 0 :
            return
        pad_name = "sink_%u" % task_data["source_id"]
        sinkpad = self.streammux.get_static_pad(pad_name)
        re_sinkpad = self.streammux.request_pad_simple(pad_name)
        print("stop sikpad=", sinkpad)
        #sinkpad = re_sinkpad
        if sinkpad:
            state_return = self.g_source_bins[task_data["source_id"]].set_state(Gst.State.NULL)
        else:
            print('cant not get sinkpad,stop error:{0}'.format(content), re_sinkpad)
            #self.out_queue.put(FrameCommon.response_status(task_data["datas"], 'remove', -1, 'cant not get sinkpad,stop error:{0}'.format(content)))
            return
        if state_return == Gst.StateChangeReturn.SUCCESS:
            print("STATE CHANGE SUCCESS\n")
            self.logger.info("task_id: {} STATE CHANGE SUCCESS".format(task_data['task_id']))
            print(pad_name)
            # Retrieve sink pad to be released
            # if not sinkpad:
            #     self.out_queue.put(FrameCommon.response_status(task_data["datas"], 'remove', -1, 'cant not get sinkpad,stop error:{0}'.format(content)))
            #     Gst.State.PLAYING
            #     state_return = self.g_source_bins[task_data["source_id"]].set_state(Gst.State.PLAYING)
            #     return
            # Send flush stop event to the sink pad, then release from the streammux
            sinkpad.send_event(Gst.Event.new_flush_stop(False))
            self.logger.info("task_id: {} sinkpad send event success".format(task_data['task_id']))
            self.streammux.release_request_pad(sinkpad)
            print("streammux release SUCCESS\n")
            self.logger.info("task_id: {} streammux release success".format(task_data['task_id']))
            # Remove the source bin from the pipeline
            self.pipeline.remove(self.g_source_bins[task_data["source_id"]])
            del self.g_source_bins[task_data["source_id"]]
        elif state_return == Gst.StateChangeReturn.FAILURE:
            print("STATE CHANGE FAILURE\n")
            content = "STATE CHANGE FAILURE, occur action: {}".format(content)
            self.out_queue.put(FrameCommon.response_status(task_data["datas"], 'add', -1, content))
            return False
        elif state_return == Gst.StateChangeReturn.ASYNC:
            self.logger.info("task_id: {} state change async".format(task_data['task_id']))
            state_return = self.g_source_bins[task_data["source_id"]].get_state(Gst.CLOCK_TIME_NONE)
            print(pad_name)
            print("STATE CHANGE ASYNC\n")
        return True
    def _add_source(self, source_id, video_url):
        source_name = 'source-' + str(source_id)
        print('adding source ', source_name)
        # Create a uridecode bin with the chosen source id
        source_bin = self._create_uridecode_bin(source_id, video_url)
        if (not source_bin):
            self.logger.error("task_id: {}, stream_url: {}, Failed to create source bin. Exiting.".format(self.stream_data[source_id]['task_id'], video_url))
            del self.stream_data[source_id]
            return
        # Add source bin to our list and to pipeline
        self.g_source_bins[source_id] = source_bin
        self.pipeline.add(source_bin)
        print("source_bin=", source_bin)
        # Set state of source bin to playing
        state_return = self.g_source_bins[source_id].set_state(Gst.State.PLAYING)
            self.logger.error("task_id: {}, stream_url: {}, STATE CHANGE FAILURE.".format(
            self.out_queue.put(FrameCommon.response_status(self.stream_data[source_id], 'add', -1,
                                                           'STATE CHANGE FAILURE:{0}'.format(video_url),
                                                           target_type="video"))
            del self.g_source_bins[source_id]
            return
            state_return = self.g_source_bins[source_id].get_state(Gst.CLOCK_TIME_NONE)
        elif state_return == Gst.StateChangeReturn.NO_PREROLL:
            print("STATE CHANGE NO PREROLL\n")
            self.logger.error("task_id: {}, stream_url: {}, STATE CHANGE NO PREROLL.".format(
        return True
Can you give me some ideas to solve the problem?
Will this problem occur if the two problematic streams had not been added, like just add the normal stream?
Also can you provide your simplified python demo and the detailed operation procedure? We can try that on our side.
If I use the official example directly:
python3 deepstream_rt_src_add_del.py rtsp://admin:damin_1357@36.124.202.15/media/video1
The situation is consistent with what I mentioned earlier
First , when i added the first souce :
Warning: gst-stream-error-quark: No decoder available for type 'application/x-rtp, media=(string)application, payload=(int)107, clock-rate=(int)90000, encoding-name=(string)VND.ONVIF.METADATA, decodertag=(string)"h3c-v3\ RTCP\=0", a-recvonly=(string)"", ssrc=(uint)31766572, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false'. (6): ../gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-00
At this point, the pipeline is being analyzed normally,
When starting to delete, the following error occurred:
Error: gst-resource-error-quark: Unhandled error (9): ../gst/rtsp/gstrtspsrc.c(6795): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstURIDecodeBin:source-bin-01/GstRTSPSrc:source:
Exiting app
I have tested and not every stream will cause such problems,
but I do not have a suitable method to determine what kind of stream will have problems.
Even problematic streams can be played using ffmpeg
Could you share more information about the rtsp source? If it is a IP camera, please share brand and model ID.
You can also dump the stream from the rtsp source and attach that. Our hardware decoder may not decode that correctly.
the rtsp source just like :
I tried using ffmpeg to change this RTSP stream to RTMP, and under RTMP, pipeline deletion and addition are both very normal
ffmpeg -re -rtsp_transport tcp -i rtsp://xxxxx -c copy -f flv rtmp://xxxx
OK. This looks more like a problem with Gstreamer’s rtsp plugin. You can do the following experiment in your own code to check that.
Simplifies the pipeline to source->sink and see if there are any problems with the same steps.
