I’m trying to use RDMA to send data to or from a FPGA PCIe card.
The test platform is an Intel CPU PC with a cx4121a card and a FPGA PCIe card. OS is Ubuntu 22.04 x86_64, with MLNX_OFED_LINUX-5.8-2.0.3.0.
I wrote a kernel driver for the FPGA card to implement a peer_memory_client, which heavily referenced nv_peer_memory.
It worked fine on IBV_WR_RECV, cx4121a could successfully write the data it received to FPGA card’s BAR2 address (which was mapped to DDR on FPGA card). But when doing IBV_WR_SEND (using cx4121a to send data from FPGA card’s BAR2 address to remote), I got a local protection error. And there was no warning or error message in kernel log.
It was the same buffer address/length and same memory region used in both IBV_WR_SEND and IBV_WR_RECV, so I have no clue why IBV_WR_RECV worked but IBV_WR_SEND not.
Any help would be appreciated, thanks!
Here are some details:
- I implement mmap in my driver to map FPGA card’s BAR2 into user space, get an virtual address
vma->vm_flags |= VM_IO | VM_PFNMAP | VM_DONTEXPAND | VM_DONTDUMP;
vma->vm_page_prot = pgprot_noncached(vm_get_page_prot(vma->vm_flags));
ret = remap_pfn_range(vma, vma->vm_start,
pfn + vma->vm_pgoff,
user_size,
vma->vm_page_prot);
- fill this virtual address to struct ibv_sge, then pass it to ibv_post_send or ibv_post_recv
ib_res.buf = mmap(NULL, length, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0);
struct ibv_sge list = {
.addr = (uint64_t)ib_res.buf,
.length = size,
.lkey = ib_res.mr->lkey
struct ibv_send_wr *bad_wr, wr = {
.wr_id = SEND_WRID,
.sg_list = &list,
.num_sge = 1,
.opcode = IBV_WR_SEND,
.send_flags = IBV_SEND_SIGNALED,
.next = NULL
ibv_post_send(ib_res.qp, &wr, &bad_wr);
- ib core driver will find out this user virtual address is not normal memory, so it will try to get pages from peers
- I implement peer_memory_client in my driver and register it to ib core. when ib core asks to do a dma_map, I fill the physical address of FPGA card’s BAR2 into the sg table.
for_each_sg(sg_head->sgl, sg, hello_mem_context->npages, i) {
sg_set_page(sg, NULL, hello_mem_context->page_size, 0);
sg->dma_address = bar2_phys_addr[hello_mem_context->belongs_to_card] + ((i++) * hello_mem_context->page_size);
sg->dma_length = hello_mem_context->page_size;
If I replaced FPGA card’s BAR2 with a kmalloc buffer in driver, every thing worked fine. So I assume the driver in general is good, just something is wrong with PCIe BAR address mapping in driver?
