I use gpio by Jetson GPIO Python library,the code is here
import Jetson.GPIO as GPIO
import time
edge_pin=15
plus_pin=31
def wait_egde(c):
GPIO.output(plus_pin,GPIO.HIGH)
time.sleep(0.001)
GPIO.output(plus_pin,GPIO.LOW)
def gpio_init():
GPIO.setmode(GPIO.BOARD)
GPIO.setup(edge_pin,GPIO.IN)
GPIO.setup(plus_pin,GPIO.OUT,initial=GPIO.LOW)
GPIO.add_event_detect(edge_pin,GPIO.RISING,callback=wait_egde)
def main():
gpio_init()
while True:
if name == ‘main’:
main()
I want to detect plus rising edge by gpio 15 interrupt,the plus frequency is 80Hz,in interrupt callback funtion output a plus by gpio 31.It seems that the plus frequency of gpio 31 is also 80Hz,but it’s not,it’s a unregular plus.Is there any solution?
