How to use gpioet to control gpios?
Refer this link
Hi zhang.xiang,
Are you using the devkit or custom board for Orin Nano?
If you want to control PZ.06, please remember to configure it Output/Drive 0
as following in pinmux spreadsheet before use.
Can you take a look at this problem? The gpioset command setting each gpio has no effect.
Do you mean Jetpack 6.2 (L4T r36.4.3)?
Please run cat /etc/nv_tegra_release
on your board to check.
You can’t configure nvidia,function
property as spi1
here if you want to use it as GPIO and control it.
Pleas share the result of the following command on your board.
$ sudo busybox devmem 0x0243d008
It seems 0x448 is not the expected result if you want to use it as GPIO.
Please configure nvidia,function = "rsvd1";
instead.
We would suggest using pinmux spreadsheet to configure the pin before use.
Also use the previous gpio control mode.
