GPU-compatible surface gripper module
Hello!
I discovered that the ‘surface gripper’ module in the isaacsim / isaaclab environment requires operations within the CPU (creating and removing 6D joints between the gripper and the target object) that are difficult to parallelize on the GPU. Is there a plan or work related to a GPU-compatible surface gripper module that can leverage the accelerated RL training environment by CUDA?
Hello!
The current approach with Joint approximation prevents us from enabling a fully GPU-based pipeline, since any changes to the simulation topology (creating / modifying joint constraints) triggers a CPU synchronization indeed.
We are researching alternative methods that would allow a full-GPU pipeline, but on the meanwhile this CPU sync method has been throughly optimized to minimize the time spent on the synchronization step and should still be performant enough for training pipelines.
