Hi all,
On my quest to use a surface gripper in a parallellized simulation, I’ve stumbled upon another weird issue: The gripper fails to close when using device="cuda:0" and closes when using device="cpu".
I’m using Isaac Sim 2022.2.0 and Orbit to spawn a bunch of UR10s with surface grippers attached to pick up objects. Simplified code is attached below, and the full standalone script is attached to this post.
Problem Description:
When I run with
SimulationContext(physics_dt=0.001, rendering_dt=0.01, backend="torch", device="cuda:0")
the gripper fails to close:
[omni.isaac.manipulators.grippers.surface_gripper] gripper didn't close successfully
This error seems to come from inside omni.isaac.surface_gripper._surface_gripper, as the close()-function I have access to in surface_gripper.py executes the way It’s supposed to.
When I run with
SimulationContext(physics_dt=0.001, rendering_dt=0.01, backend="torch", device="cpu")
everything works. The gripper closes, and the object is picked up.
Code:
My (very abbreviated) code is as follows:
from omni.isaac.manipulators.grippers.surface_gripper import SurfaceGripper
sim = SimulationContext(physics_dt=0.001, rendering_dt=0.01, backend="torch", device="cuda:0")
# Scene setup
kit_utils.create_ground_plane("/World/defaultGroundPlane", z_position=0.0)
robot_cfg = UR10_CFG
robot_cfg.data_info.enable_jacobian = True
robot_cfg.rigid_props.disable_gravity = True
robot = SingleArmManipulator(cfg=robot_cfg)
robot.spawn("/World/envs/env_0/Robot", translation=(0.0, 0.0, 0.0))
model_usd_path = "/home/*/Documents/Omniverse/Content/Models/My_USD/my_model.usd"
prim_utils.create_prim("/World/envs/env_0/Model_0", usd_path=model_usd_path, position=(0.485, 0.0, 0.184/2), orientation=(0.707, 0, 0.707, 0))
gripper = SurfaceGripper(
end_effector_prim_path=f"/World/envs/env_0/Robot/ee_link", translate=0.1611, direction="x"
robot.initialize("/World/envs/env_0/Robot")
gripper.initialize()
count = 0
# Simulate physics
while simulation_app.is_running():
if count == 300:
gripper.close()
if count % 500 == 0:
count = 0
gripper.open()
count += 1
Full script:
play_suction.py.zip (3.4 KB)
Btw, please ignore the very hacky way I’ve modified the Orbit IK example to pick up an object and follow a trajectory - this was only supposed to be a quick demo.
Anyway, any ideas what is going wrong? What are the differences between running surface_gripper on a gpu vs a cpu? Is it the thing I am trying to pick? Is there source code for omni.isaac.surface_gripper._surface_gripper available?
If I can provide more Information/code, I’m very happy to do so.
