GPU Direct for VIDEO
This is for GPU Direct for VIDEO
I am using NVIDIA RTX A4000 GPU card i want to use GPUDirect video for FPGA and GPU card
Regarding that i didn’t get anything form dvp programming guide any reference is there regarding that i have some queries
  • If I am using custom EXT IO device what prerequisites should be done.
  • I go through DVP programming guide but not getting.
  • In custom EXT I/O device Inside FPGA DMA is present it is sending a data to FPGA DDR ?
  • whether 3rd party input data is written to system memory or read the data from the FPGA DDR and copy to system memory ?
  • Using DVP programming I should create a driver and extsdk.cpp.
  • I have Xilinx DMA / QDMA driver for x86 whether it is possible to use as a EXT device driver.
  • FPGA(ext device) → System memory → GPU memory → system memory → FPGA (ext device).
Best Regards
Raizz
Your topic may be in the wrong category. Please check if this forum post helps guide you to solution.
