Redirect GUI through PCIe interface: GPUDirect vs DRM
I wish to redirect all GPU output through a PCIe interface to an external device instead of DP.
Here I asked regarding general GPU data redirection:
My question now is regarding redirecting the GUI frames. I know the GPU draws the GUI and outputs the frames via DP.
If I wish to output the GUI frames via PCIe interface instead DP, should I use GPUDirect RDMA as well or this case requires modifying the DRM Module and X11/wayland servers?
GPU direct usually requires an FPGA connection.
Please see below for info:
Thank you for your help. I’ll try using this demo.
