I want to directly transfer video frames from a framegrabber to GPU memory. The suggested methods are
1)Using GPUDirect RDMA by referring GitHub - NVIDIA/jetson-rdma-picoevb: Minimal HW-based demo of GPUDirect RDMA on NVIDIA Jetson AGX Xavier running L4T and
2)Another method is making use of below APIs
glGenBuffers , glBindBuffer , glBufferData ,glMapbuffer and pass the address to kernel in User_ptr method.
I want to difference between these two methods
GPUDirect requires PCIe hardware but EGL doesn’t.
If without GPUDirect and PCIe , i can able access GPU memory using EGL means then what’s the advantage of going to GPUDirect ? why nvidia releases such feature like GPUDirect?
GPUDirect is used for two device transfer buffers through PCIe.
But you cannot transfer a video frame to another Jetson with the EGL approach.
Can i make use of a GPUDirect RDMA in an X86 system where a nvidia’s GPU inserted in one PCIe slot and framegrabber in another slot?
Do you mean you want to transfer buffer between two dGPU cards?
It should work: GPUDirect | NVIDIA Developer
For more information, please file a new topic to the corresponding category.
system
Closed
October 26, 2022, 3:29am
9
