I am modifying an acquisition board Linux driver in order to make the acquisition board transfer the data directly to my GTX 1080. For that, I use the GPU Direct RDMA technology described in the CUDA Toolkit v8.0.
Badly, when the driver calls nvidia_p2p_get_pages in order to retrieve physical addresses for the buffer the application allocated on the GTX 1080 memory, the function return -EINVAL (-22).
I really don’t understand why this function return -EINVAL.
- The first two parameters (p2p_token and va_space_token) are 0. I don’t want to use the deprecated tokens and the same process allocate the buffer and call the driver calling nvidia_p2p_get_pages.
- virtual_address parameter is the virtual address the application received from cudaMalloc. This address is 64 KiB aligned.
- length parameter is the size of the allocated buffer (2 * 1024 * 1024 bytes)
- page_table parameter is the address of a (nvidiat_p2p_page_table *) variable initially NULL as in the sample I found.
- free_callback parameter is the address of a function
- data parameter is the address of my context structure
Do y have to configure the NVIDIA driver in some “mode” in order to use the GPU Direct RDMA technology?
Do you know something that could make nvidia_p2p_get_pages fail and returns -EINVAL?
Any hint will be greatly appreciated.
Thanks in advance,
Martin
