GPU installed in this system is not supported by the NVIDIA 570.172.08 driver
Following latest doc(Unified Deployment Guide for SecureAI) for CC
Load driver failed in VM
apus@apus:~$ sudo dmesg | grep -i NVRM
[sudo] password for apus:
[   16.808289] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2331)
               NVRM: installed in this system is not supported by the
               NVRM: NVIDIA 570.172.08 driver release.
               NVRM: Please see 'Appendix A - Supported NVIDIA GPU Products'
               NVRM: in this release's README, available on the operating system
               NVRM: specific graphics driver download page at www.nvidia.com.
[   16.809389] NVRM: The NVIDIA probe routine failed for 1 device(s).
[   16.809391] NVRM: None of the NVIDIA devices were initialized.
[   17.058542] NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:2331)
[   17.068806] NVRM: The NVIDIA probe routine failed for 1 device(s).
[   17.068808] NVRM: None of the NVIDIA devices were initialized.
Status for sev-snp looks good
apus@apus:~$ uname -r
6.8.0-79-generic
apus@apus:~$  sudo dmesg | grep -i sev
[    4.610724] Memory Encryption Features active: AMD SEV SEV-ES SEV-SNP
[    4.724495] SEV: APIC: wakeup_secondary_cpu() replaced with wakeup_cpu_via_vmgexit()
[    4.896686] SEV: Using SNP CPUID table, 29 entries present.
[    5.280797] SEV: SNP guest platform device initialized.
[    9.363982] sev-guest sev-guest: Initialized SEV guest driver (using vmpck_id 0)
GPU is H100
apus@apus:~$ lspci -vv -s 01:00.0
01:00.0 3D controller: NVIDIA Corporation GH100 [H100 PCIe] (rev a1)
        Subsystem: NVIDIA Corporation GH100 [H100 PCIe]
        Physical Slot: 0
        Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Interrupt: pin A routed to IRQ 23
        Region 0: Memory at 3002000000 (64-bit, prefetchable) [disabled] [size=16M]
        Region 2: Memory at 4000000000 (64-bit, prefetchable) [disabled] [size=128G]
        Region 4: Memory at 3000000000 (64-bit, prefetchable) [disabled] [size=32M]
        Capabilities: <access denied>
        Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
Can anyone can help check what is the issue ?
What is the VBIOS version?
nvidia-smi -q | grep VBIOS
