On OpenSUSE Leap 42.1 I get:
Oct 22 00:40:07 linux-af78 kernel: NVRM: The Unknown NVIDIA G8x Series GPU installed in this
NVRM: system is not supported through the 367.57 NVIDIA
NVRM: driver. You can try the NVIDIA 340.xx Legacy drivers.
NVRM: Please visit http://www.nvidia.com/object/unix.html
NVRM: for download information. The 367.57 NVIDIA driver
NVRM: will ignore this GPU. Continuing probe…
/sbin/lspci -d “10de:*” -v -xxx
01:00.0 VGA compatible controller: NVIDIA Corporation GF108 [GeForce GT 730] (rev a1) (prog-if 00 [VGA controller]
Flags: fast devsel, IRQ 16
Memory at e2000000 (32-bit, non-prefetchable)
Memory at d0000000 (64-bit, prefetchable)
Memory at e0000000 (64-bit, non-prefetchable)
I/O ports at 2000
Expansion ROM at [disabled]
Capabilities: [60] Power Management version 2
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel modules: nouveau, nvidia_drm, nvidia
00: de 10 02 0f 03 00 10 00 a1 00 00 03 10 00 00 00
10: 00 00 00 e2 0c 00 00 d0 00 00 00 00 04 00 00 e0
20: 00 00 00 00 01 20 00 00 00 00 00 00 00 00 00 00
30: 00 00 fe ff 60 00 00 00 00 00 00 00 0b 01 00 00
40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50: 01 00 00 00 01 00 00 00 ce d6 23 00 20 00 00 00
60: 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 10 00 01 00 e0 84 2c 01
80: 10 29 00 00 01 3d 01 00 48 00 01 11 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I have run nvidia-bug-report.log.gz, but I did not find out how to attach it, should I paste it plain text?
Notice that I had to comment the line in /etc/modprobe.d/50-nvidia.conf, otherwise the system would loop infinitely giving the “The Unknown NVIDIA G8x Series GPU installed…” message.
Thanks in advance.
nvidia-bug-report.log.gz (48.4 KB)
