Missing NVIDIA 331.67 Linux drivers announcement
Aaron,
I have found these drivers on your FTP server, yet I cannot find any information about them anywhere. What gives?
Are you serious? ;) There are even two threads in this forum and more information on phoronix.com as usual.
http://www.phoronix.com/scan.php?page=news_item&px=MTY1NzE
http://www.phoronix.com/scan.php?page=news_item&px=MTY1ODg
http://www.phoronix.com/scan.php?page=news_item&px=MTY1OTM
https://devtalk.nvidia.com/default/topic/724627/where-are-the-337-10-drivers-/
https://devtalk.nvidia.com/default/topic/725204/
From http://www.nvidia.com/download/driverResults.aspx/75019/en-us
Added support for the following GPUs:
GeForce GT 705
GeForce GT 720
GeForce GTX 860M
GeForce GTX 870M
GeForce GTX 880M
GeForce GTX TITAN Black
Fixed a bug that could lead to crashes when running Left 4 Dead 2 with threaded optimizations enabled.
Updated the makefile for the NVIDIA kernel module to work around a bug in older versions of GNU Make that prevented the NVIDIA kernel module from building correctly. This bug was fixed in version 3.81 of GNU Make.
Fixed a bug that causes some X clients to be disconnected from the X server when the screen is resized while RandR 1.4 display offloading is in use.
Fixed a bug that could cause display corruption when resuming from suspend on systems using RandR 1.4 display offloading with recent Linux kernels.
Added support for Tridelity SL stereo mode.
Fixed a bug that could cause nvidia-settings to crash or display incorrect information after switching virtual terminals while a color correction confirmation countdown was active.
Added a missing 32-bit compatibility library for libnvidia-fbc.so to the x86_64 Linux installer package.
sascha,
Obviously you cannot quite read the numbers.
I was asking about 331.67 drivers.
jwcalla,
Thank you! I’ve no idea how you found this page - Google doesn’t “see” it.
lol, indeed! :) If you type the numbers into the NVIDIA search you get exactly one hit for 331.67… http://www.nvidia.com/object/nv_search_us.html?cx=009029091075083507105%3A9leknaf7r_8&cof=FORID%3A11%3BNB%3A1&ie=UTF-8&hl=en&gl=us&q=linux+331.67
Sorry, I was busy and missed posting the announcement for this one. I’ll post it now.
FYI: 750ti/750 aren’t listed under the supported products tab.
Is there anything 331.67 does that 337.10 can’t? Just asking… :) 337.10 supports GTX 750 / Ti.
