Added support for the following GPUs:
GeForce GTX 680MX
Tesla K20Xm
Added support in NV-CONTROL and in nvidia-settings for changing the Double Precision performance boost mode on supported GPUs.
Fixed a bug in nvidia-settings that allowed unavailable features to be selected in some drop-down menus.
Fixed several OpenGL driver bugs related to stencil-only framebuffer objects.
Updated the NVIDIA X driver to reprobe displays when VT-switching to X, to allow reporting of hotplug events when displays are connected or disconnected while VT-switched away from X.
Added unofficial GLX protocol support (i.e for GLX indirect rendering) for the following extension and core commands.
GL_ARB_vertex_array_object
OpenGL 3.0 commands ClearBufferfi, ClearBufferfv, ClearBufferiv,ClearBufferuiv and GetStringi.
Fixed a bug that caused the cursor shadow to be clipped to 32x32 pixels, even on Kepler GPUs that support a 256x256 cursor image.
Fixed a bug that prevented some cursor image updates from taking effect on displays with rotation or other transformations applied.
Fixed cursor alpha blending artifacts on displays with rotation or other transformations applied.
Added support for the GLX_EXT_buffer_age extension.
Improved the performance of glDrawPixels() by up to 450% when the pixel data is of type GL_BYTE.
Fixed a bug when enabling framelock between displays connected to the same GPU as other displays with different refresh rates, which caused the latter to be incorrectly assigned to the framelock group.
Updated the reporting of HDMI 3D framerates and pixel clocks to be more consistent with how they are reported by HDMI 3D displays.
Fixed a bug that sometimes prevented rotation controls in the nvidia-settings control panel from working after changing resolutions.
Fixed a bug that could cause applications using GL_NV_vdpau_interop to crash during modeswitches.
Fixed a regression that could cause OpenGL applications to crash while compiling shaders.
Added a kernel module parameter, "NVreg_EnablePCIeGen3", which can be used to enable PCIe gen 3 when possible. Note that on many systems where the NVIDIA driver does not allow PCIe gen 3 by default, stability problems can be expected when this option is enabled: users should do so at their own risk.
Fixed a VDPAU bug that could cause the X server to hang when decoding some corrupted video streams.
Renamed VGX products to GRID products in the "Supported NVIDIA GPU Products" list.
Added support for X.org xserver ABI 14 (xorg-server 1.14).
Fixed a bug in nvidia-settings that could cause the wrong resolution to be set in basic mode for setups based on one display per X screen.
Fixed libnvidia-encode.so library dependency by linking it with libnvcuvid.so.1 instead of libnvcuvid.so while creating it.
Improved performance of OpenGL framebuffer object binds with Xinerama enabled by 2000-3000% when the application's windows do not span screen boundaries.
Fix performance issues when using some versions of HyperMesh with Quadro GPUs.
Long term support drivers 310.32 have been released:
GeForce GTX 680MX
Tesla K20Xm
It would be nice to have in that forum a post having current releases like you had on nvnews.
Now nvidia.com driver search page returns only the LTS version and not the latest stable version.
Fixed a bug that could lead to rendering corruption after an X server generation (i.e., leaving an X server running after all of its clients have exited).
Removed a spurious dependency on libpangox from the nvidia-settings binary shipped as part of the driver package.
Fixed a bug that could cause the X server to crash when performing an RandR 1.0 rotation (e.g., `xrandr --orientation left`) after unplugging the last connected monitor.
Fixed a bug that caused the nvidia-xconfig(1) man page to be blank.
Fixed font rendering performance and corruption problems on X servers with backported support for the new glyph cache functionality added to Pixman 0.27.
Fixed a potential X server crash during initialization, when a graphics card with a TV connector has no TV connected.
Added a new X configuration option, "UseHotplugEvents", to allow the suppression of RandR events when adding or removing non-DisplayPort displays. See the "X Config Options" appendix of the README for details.
