Release highlights since 325.15:
- Added support for the following GPUs:
- GeForce GTX 760 Ti OEM
- GeForce GT 740A
- GeForce GT 745A
- GeForce GT 755M
- GeForce GTX 645
- Quadro K6000
- Fixed a bug that caused the X server to fail to initialize when DisplayPort 1.2 monitors were assigned to separate X screens on the same GPU.
- Fixed a bug that could cause a deadlock when forking from OpenGL programs which use some malloc implementations, such as TCMalloc.
- Fixed a bug that prevented Warp & Blend settings from being retained across display configuration changes.
- Fixed a bug that prevented some settings changes made via the nvidia-settings command line interface from being reflected in the nvidia-settings graphical user interface.
- Changed the clipping behavior of the NVIDIA X driver on Trapezoids and Triangles for some RENDER operations to match the behavior in newer versions of Pixman:
http://lists.freedesktop.org/archives/pixman/2013-April/002755.html - Fixed a bug in MetaMode tracking that could cause spurious error messages to be printed when attempting to add or delete Metamodes via NV-CONTROL.
- Fixed a bug that caused the NVIDIA X driver to attempt to load the X11 "shadow" module unconditionally, even in situations where the driver had no need to use the module. This could result in the printing of spurious error messages, on X servers where the module was not present.
- Fixed a bug that prevented display configuration changes made with xvidtune(1) from working correctly.
- Fixed a bug that occasionally caused display corruption in GLX applications while changing the display configuration.
- Fixed a bug that prevented glReadPixels from working correctly when reading from Pixel Buffer Objects over indirect rendering, when the image width is not a multiple of 4.
- Added a new NV-CONTROL attribute, NV_CTRL_BACKLIGHT_BRIGHTNESS, for controlling backlight brightness.
- Fixed a bug that prevented nvidia-settings from creating display device configuration pages for newly connected DisplayPort 1.2 Multi Stream Transport downstream devices.
- Added GPU utilization reporting to the nvidia-settings control panel.
- Fixed a bug in the nvidia-settings control panel that prevented users from configuring stereo, when stereo was not already configured.
- Added support for reporting the tachometer-measured fan speed on capable graphics boards via nvidia-settings and the NV-CONTROL API. The preexisting mechanism for reporting fan speed reports the speed of the fan as programmed by the driver. For example, `nvidia-settings --query=[fan:0]/GPUCurrentFanSpeedRPM`.
- Fixed a regression that caused GPUs that do not support graphics to not appear in nvidia-settings.
- Fixed a bug that caused DisplayPort 1.2 multi-stream devices to stop working if they were unplugged and plugged back in while they were active in the current MetaMode.
- Added support for multiple NVIDIA kernel modules. This feature allows users to assign different GPUs in the system to different NVIDIA kernel modules, potentially reducing the software overhead of coordinating access to multiple GPUs.
- Added support for the EGL API on 32-bit platforms. Currently, the supported client APIs are OpenGL ES 1.1, 2.0 and 3.0, and the only supported window system backend is X11.
- Add a new option, AllowEmptyInitialConfiguration, which allows the X server to start even if no connected display devices are detected at startup. This option can be enabled by running "sudo nvidia-xconfig --allow-empty-initial-configuration"
This option is useful in RandR 1.4 display offload configurations where no display devices are connected to the NVIDIA GPU when the X server is started, but might be connected later. - Updated nvidia-installer to provide a scrollable text area for displaying messages from the /usr/lib/nvidia/alternate-install-present and /usr/lib/nvidia/alternate-install-available distro hook files. This allows for longer messages to be provided in these files.
- Updated nvidia-installer to avoid recursing into the per-kernel "build" and "source" directories when searching for conflicting kernel modules in /lib/modules.
- Added a system memory cache to improve the performance of certain X rendering operations that use software rendering fallbacks. The X configuration option "SoftwareRenderCacheSize" may be used to configure the size of the cache.
- Removed the "DynamicTwinView" X configuration option: dynamic reconfiguration of displays is always possible, and can no longer be disabled.
- Fixed a bug that caused nvidia-settings to display incorrect information in its display configuration page when all displays on an X screen were turned off.
- Updated nvidia-installer to only install the libraries libvdpau and libvdpau_trace if an existing installation of libvdpau is not detected on the system. This behavior can be overridden with the --install-vdpau-wrapper and --no-install-vdpau-wrapper options.
Future NVIDIA Linux installer packages will no longer include copies of libvdpau or libvdpau_trace: VDPAU users are recommended to install these libraries via other means, e.g. from packages provided by their distributors, or by building them from the sources available at: <a target='_blank' rel='noopener noreferrer' href='http://people.freedesktop.org/~aplattner/vdpau/'>http://people.freedesktop.org/~aplattner/vdpau/</a> - Fixed a bug that prevented SDI output from working when two or more non-SDI displays were being driven by the same GPU.
- Fixed a bug that could cause OpenGL applications to crash during the initialization of new threads.
- Fixed a bug that caused the GPU and Memory clock frequencies for some PowerMizer performance levels on Kepler boards to be reported incorrectly in the nvidia-settings control panel.
- Fixed a bug that caused the X server to fail to start on certain laptops when the boot display was on an external DisplayPort monitor, for example if the laptop was booted while the lid was closed.
- Fixed a bug that caused DisplayPort monitors connected to Quadro FX 3800, 4800, or 5800 to remain off after DPMS.
- Added the NVIDIA OpenGL-based Inband Frame Readback (NvIFROpenGL) library to the Linux driver package. This library provides a high performance, low latency interface to capture and optionally encode an individual OpenGL framebuffer. NvIFROpenGL captures pixels rendered by OpenGL only and is ideally suited to application capture and remoting.
- Updated the NVIDIA OpenGL driver to write temporary files to $TMPDIR if it is set, instead of unconditionally writing to /tmp.
- Updated a fallback of writing temporary files to $HOME/.nvidia to use $HOME/.nv instead, as the latter path is already used for other NVIDIA driver related files.
README: http://us.download.nvidia.com/XFree86/Linux-x86/331.13/README/index.html
Linux x86: http://www.nvidia.com/object/linux-display-ia32-331.13-driver.html
Linux x86_64: http://www.nvidia.com/object/linux-display-amd64-331.13-driver.html
Linux ARM: http://www.nvidia.com/object/linux-display-32bit-arm-331.13-driver.html
Solaris: http://www.nvidia.com/object/solaris-display-331.13-driver.html
FreeBSD x86: http://www.nvidia.com/object/freebsd-x86-331.13-driver.html
FreeBSD x86_64: http://www.nvidia.com/object/freebsd-x64-331.13-driver.html
