Release highlights since 334.21:
- Added support for the following GPUs:
- GeForce 830M
- GeForce 840M
- GeForce 845M
- GeForce GTX 850M
- GeForce GT 705
- GeForce GT 720
- GeForce GTX 860M
- GeForce GTX 870M
- GeForce GTX 880M
- Fixed a bug that could cause OpenGL programs to freeze under some low memory conditions.
- Updated the display configuration page in nvidia-settings to uniquely identify DisplayPort 1.2 monitors by displaying the monitor GUIDs.
- Fixed a bug that could cause ECC settings to be displayed incorrectly in nvidia-settings when changing ECC settings on a multi-GPU system.
- Removed the "OnDemandVBlankInterrupts" X configuration option: this option has been enabled by default since version 177.68 of the NVIDIA Unix driver, and the documentation had not been updated to reflect the new default value.
- Fixed a bug that caused GPU errors when hotplugging daisy-chained DisplayPort 1.2 displays.
- Updated the color correction settings page in the nvidia-settings control panel to reflect gamma changes made by other RandR clients while the control panel was already running.
- Fixed a bug that prevented the use of multiple simultaneous X servers on UEFI systems.
- Updated the nvidia-settings source package to build libXNVCtrl when building nvidia-settings, instead of relying on a pre-built library.
- Added the ability to over- and under-clock certain GeForce GPUs in the GeForce GTX 400 series and later. For GPUs that allow it, an offset can be applied to clock values in some clock domains of some performance levels. This clock manipulation is done at the user's own risk. See the README documentation of the "CoolBits" X configuration option for more details.
- Updated the minimum required version of GTK+ from 2.2 to 2.4 for nvidia-settings.
- Renamed the RandR output property _GUID to GUID now that it is an official property documented in randrproto.txt: http://cgit.freedesktop.org/xorg/proto/randrproto/commit/?id=19fc4c5a72eb9919d720ad66734029d9f8e313b1
- Reduced CPU utilization and GPU memory utilization of the NVIDIA EGL driver.
- Added support for the following EGL extensions:
- EGL_EXT_buffer_age;
- EGL_EXT_client_extensions;
- EGL_EXT_platform_base;
- EGL_EXT_platform_x11.
- Renamed the "Clone" setting of the "MetaModeOrientation" X configuration option to "SamePositionAs", to make clear that this setting applies to the position only, and not to the resolution of modes in the MetaMode.
- Added NV-CONTROL attribute NV_CTRL_VIDEO_ENCODER_UTILIZATION to query utilization percentage of the video encoder engine.
- Added support for the GLX_NV_delay_before_swap extension. For more details, see the extension specification: http://www.opengl.org/registry/specs/NV/glx_delay_before_swap.txt
- Report correct buffer sizes for RGB GLX visuals, GLXFBConfigs, and EGLConfigs. Previously, RGB10 and RGB8 formats were reported as having 32 bits, and RGB5 formats were reported as having 16 bits. Now they are correctly reported as 30, 24, and 15 bit formats respectively as required by the GLX and EGL specifications.
- Fixed a bug that could lead to crashes when running Left 4 Dead 2 with threaded optimizations enabled.
- Updated the makefile for the NVIDIA kernel module to work around a bug in older versions of GNU Make that prevented the NVIDIA kernel module from building correctly. This bug was fixed in version 3.81 of GNU Make.
- Fixed a bug that causes some X clients to be disconnected from the X server when the screen is resized while RandR 1.4 display offloading is in use.
- Fixed a bug that could cause display corruption when resuming from suspend on systems using RandR 1.4 display offloading with recent Linux kernels.
- Added support for Tridelity SL stereo mode.
- Updated the behavior of the nvidia-settings PowerMizer Preferred Mode drop-down menu, to make the setting apply consistently across all GPUs in an SLI group.
- Updated nvidia-settings to use libjansson commit 88aa6a9e30e7465196a737bd0f82eb17f393a120 from the repository at: https://github.com/akheron/jansson.git This commit contains the relevant fixes for CVE-2013-6401.
- Fixed a crash when using WebGL in Firefox with a Geforce 6 GPU.
[README | Linux x86 | Linux x86_64 | Linux ARM | Solaris | FreeBSD x86 | FreeBSD x86_64]
