Nvidia Linux 334.21 drivers
http://www.nvidia.com/download/driverResults.aspx/73665/en-us
http://www.nvidia.com/download/driverResults.aspx/73666/en-us
Looks like there is finally some support for linux 3.13/3.14 ! The current patches seem no longer needed. It doesn’t compile on 3.14-rc5 though, so it might still need some changes.
EDIT: Seem like it’s 3.13 compatible, for 3.14 this is needed:
http://pastebin.com/UgnyrrH5
towo:Defiant> inxi -SG
System:    Host: Defiant Kernel: 3.14-rc5-siduction-amd64 x86_64 (64 bit)
           Desktop: Xfce 4.11.2 Distro: siduction 13.2.0 December - xfce - (201312310323)
Graphics:  Card: NVIDIA GM107 [GeForce GTX 750 Ti] X.Org: 1.15.0 driver: nvidia Resolution: 1920x1080@60.0hz
           GLX Renderer: GeForce GTX 750 Ti/PCIe/SSE2 GLX Version: 4.4.0 NVIDIA 334.21
Only the little include-patch is needed for 3.14.
Which driver version is the right one for scientific linux 6.5-i686/x86_64 ?
card #1: MSI GTX 750 Ti Gaming 2GB in PCIex16_1
card #2: NVidia Quadro 1800 FX installed in PCIex16_2
Do I have to
a) first boot just with Quadro 1800 FX
b) update drivers ready for MSI-GeForce-GTX-750-Ti-Gaming >> http://www.nvidia.com/download/driverResults.aspx/73666/en-us
c) install MSI-GeForce-GTX-750-Ti-Gaming
d) boot from hard disk
Would the following be wise:
#yum --enable elrepo install nvidia-detect
./nvidia-detect
#yum --enable elrepo install …
i.e. will there be a risk to get non-working updates ?
Problems:
BUG: unable to handle kernel NULL pointer
IP: [xxxxxxxx] nouveau_pm_fini +0x37x10x160 {nouveau]
PGD 0
Ooops: 0000[#1] SMP
last sysfile: /sys/devices/virtual/block/ramb/queue/scheduler
Modules linked in: nouveau(+) ttm drm_kms_helper drm i2c_algo_bit i2c_com mxm_wmi video outpu wmi ipv6 iscsi_ibft
Pid 355 work_for_cpu Not tainted 2.6.32-358.c16.x86
System Manufacturer Sys Prod / M4A79 Deluxe
Call Trace
[xxxxxxxx] nouveau_card_init + 0x145f / 0x1868 [nouveau}
Kernel panic - not syncing - Fatal exception
Booting from DVD fails once Linux start to detect hardwara it dies(tilts)
I could not update drivers from MSI DVD, because Linux kernel died once the process
handling this new GPU card died.
Current non-working configuration
Quadro 1800 FX installed in PCIex16_1 (blue socket) with one LCD via DisplayPort and another via DVI-D port
OK serving one LCD via DisplayPort and another via DVI-D port
MSI-GeForce-GTX-750-Ti-Gaming in PCIex16_2 (blue socket), no monitors connected
OS: scientific linux 6.5-i686/x86_64 with old GPU-drivers
Example 1 : failed DVD Boot
right monitor connected via DVI-D to MSI-GeForce-GTX-750-Ti-Gaming card
Sci-Linux seemed to detect existing hardware and software
left monitor dark - connected via DisplayPort to NVidia Quadro 1800 FX in PCIex16_2 (blue)
running /sbin/loader
detecting hardware <-- *** dies(tilts) here ***
Example 2: booting from hard disk and DVD with only new GPU
*** nouveau E[ PMC unknown interrupt ] ***
Example 3: Quadro 1800 FX in PCIex16_1 serving both displays, 750-Ti in PCIex16_2 without display
both screen show Linux start <=> Quadro 1800 FX works as before!
Linux kernel in panic! => Linux did not start => unable to continue and therefore unable to update GPU-drivers
See: https://devtalk.nvidia.com/default/topic/696720/linux/nvidia-geforce-gtx-750-ti-troubles/post/4150799/#4150799
One post should be enough. ;)
