Linux Kernel 3.1
I’m trying to figure out the latest nvidia card that is compatible with Linux kernel 3.1.
Thank You
Generally, you can start to browse from Linux AMD64 Display Driver Archive | NVIDIA and look to “Minimum Requirements” in the README for each one of these drivers.
From Linux x64 (AMD64/EM64T) Display Driver 510.85.02 | Linux 64-bit | NVIDIA you can see it still supports 3.1. Later drivers may support only 4.x.
Once you have identified the driver that still supports linux 3.1 (from Minimum requirements) you look in the Appendix A. Supported NVIDIA GPU Products of the same README and you get the list of cards that are supported.
